Question about Pitco Frialator SG14 Deep Fryer
Pitco sg14 Why does the temperture dial not go over 350. the knob says 400 but cannot go there??
  • 640 Answers
On certain models the thermostat at the factory is set at 375 and even though it reads 400 the factory says the unit cannot exceed 400 degrees.If you wanted to go higher you can remove the knob,you will see the stem and inside you will see a little screw.If you hold the stem and turn the screw counterclockwise this will increase the temp.If you turn clockwise it decreases the temp.1/8th turn of the screw equals 30 degrees.If you do this be very careful because if you set it too high the high limit will trip (saftey device) and then youll have a bigger problem.
Posted on Feb 23, 2008
Just replaced thermopile, hi limit and thermostat and the fryer still cutting out at certain temp. Seems like when it hits 400 it will cut out. What could be the issue? Do we need to lower the temp? I...
Hi there.
Better check the calibration of the thermostat. Hi limit trips at 450F.
For the best factory recommended thermostat calibration procedure, you can visit http://www.pitco.com
Regards.
Jul 11, 2011 | Pitco Frialator SG14 Deep Fryer
Fryer smokes at 350 with new shorting and we fryed chicken at 350 and it got to done on the outside and raw on inside also the thermostat is not screwed down to the holder whats going
Hi there.
You may need to check the calibration of your fryer in to verify if the thermostat regulates the oil temperature as set on its dial. As for the thermostat body, it should be mounted properly to avoid movement that which could break the capillary.
You can download Pitco Fryer Owner's Manual which includes calibration procedure at http://www.pitco.com
Regards.
Oct 21, 2010 | Pitco Frialator SG14 Deep Fryer
I have a pitco deep fryer sg16. the problem is the pilot turn but when i try to turn the knob to turn it up, it's not starting and i hear a 'click' and then the pilot turn off . please help...
I think that the gas valve is defective and needs replacement. Visit http://www.middleby.com and go to PITCO web, you will be able to locate there the nearest authorized parts and service dealer in case you need parts and service.
Apr 05, 2010 | Pitco Frialator SG14 Deep Fryer
Pilot is off.
Most fryers have pilot lighting instructions on the inside of the door. If yours doesn't then find the gas valve, turn the knob to the pilot position, push in on the knob and light the pilot. Keep the knob pushed in after you lite the pilot for at least another 30 seconds. The pilot should stay lit.
Feb 22, 2010 | Pitco Frialator SG14 Deep Fryer
Solid state thermostat won't calibrate.
I believe at 350 the probe should read 942 ohms with a variation of 2%. Hope this helps.
Apr 06, 2009 | Pitco Frialator SG14 Deep Fryer
Not turning on
Sounds like you have a bad t-stat. You could take a reading through it when you turn the temp up to see if it is operating.
Apr 03, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco sg14 commercial frier
id say change the valve that runs the gas has to be leaking
Feb 15, 2008 | Pitco Frialator SG14 Deep Fryer
Pitco Frialator SG14 Deep Fryer Logo
108 people viewed this question
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Treefrog15
Treefrog15
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
