Kenwood Trio Turntable belt broken.
I have an old Kenwood Trio Belt Drive Turntable Model No.KD-1033 which needs a new drive belt. Where can I get one please? john.kerridge1@btinternet.com
    Problem Solver:
  • 7 Answers
I have them listed as item 250423608612 on Ebay .. softwaredivision
Posted on Feb 12, 2010
How do i get my auto return to work on my kenwood kd 2055 turntable?
Hi Terry ,
I need more information from you.Your Kenwood is a two speed belt drive that features several auto functions.Are all the functions except the auto return function working? Could you elaborate a bit more on the problem?
Thank you
Feb 14, 2015 | Kenwood Audio Players & Recorders
Kenwood DP-R892
May be a broken belt. See if the turntable lifts out. There may be a circlip that holds it in or turn the player upside down taking care with the arm not to damage it. If the base comes off you may be able to see the belt. They are usually only the size of a skinny elastic band. If your turntable is a direct drive ( No belt) the motor may have failed.
Jun 27, 2014 | Kenwood Audio Players & Recorders
Prolectrix usb turntable
Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
Feb 27, 2014 | Audio Players & Recorders
I have two problems. One: Does the Kenwood KD34R Turntable does it need a system cord? Two: I have a Kenwood KD491/492F turntable, it drags. It has a new belt. Please help. Thank you.
just had that problem when i replaced my belt on a pioneer pl600 turns out there was residue from the old belt on the drive pulley making the belt ride on the edge of the pulley instead of in the groove there is also two adjuster screws under the turntable that u took off to replace the belt with these u can adjust the speed manually was told that by a repair person from vintage electronics great place online for help
Sep 29, 2013 | Kenwood Audio Players & Recorders
My turntable on my kenwood kd-3070 stopped spinning when i turn it on. If there is a quick fix for this, please help! I'd like to avoid taking it into the shop.
Is it a belt drive?
If it is then unplug it take the rubber mat off use the holes in the platter to lift it off,then you'll see the belt lieing around somewhere put it back round the edge of the platter then the motor wheele. i'll finish this when u tell me wether or not it's a belt drive.
Aug 08, 2009 | Sony PS-LX250H Turntable
Trying to get the belt around the gears of my
I know this isn't the same model as yours, however it shows what I would describe to you on page 7. Hope this helps.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/kd-491f.pdf
Jul 30, 2009 | Kenwood Audio Players & Recorders
My KD-291RC has power but my turntable wont turn. I touch the needle and I can hear its on and when I move the arm towards the record or set it on it it will not turn. Help?
Your turntable is belt-driven, it's likely that the belt just fell off. The belt lives under the turntable. On my turntable (a totally different model) the turntable lifts off.
Apr 13, 2009 | Kenwood KD-291RC Turntable
Stylus for a Kenwood Belt Drive Turn table
I suggest try 'Lpgear@yahoo.com' There is a long list of Kenwoob turntable cartridges & needels. I hope you find your needel.
Sep 18, 2008 | Kenwood KD-291RC Turntable
Fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Jun 15, 2007 | Kenwood KD-291RC Turntable
158 people viewed this question
 Grubhead
Grubhead
