Question about JVC KD-G310 CD Player
Were the remot lead go's for the amp - JVC KD-G310 CD Player
  • 102 Answers
Hi if you have a amp the blue remote wire goes to the remote turn on terminal or wire on the amp. If you do not have an amp, cap the remote wire you will not need it. Thank you for using Fixya.com
Posted on Feb 07, 2010
Where do i connect the remote wire from the amp to??
The stereo on the remote lead, make sure its not the power lead, the remote is what clicks your amp on when you start your car. So it goes from stereo to amp
Dec 05, 2011 | Kicker (ZX750.1) Car Audio Amplifier
MY PUNCH IS IN THE TRUNK OF G35 INFINITI WHEN I TURN CAR OFF THE AMP IS STILL RUNNING AND DRAINING MY BATTERY I SEE A RED LIGHT ON THE AMP WHILE POWER IS OFF IN CAR
Most amps have a remote on terminal, which takes a small current wire to "turn on" the amp, and when you stop current to that terminal, it turns off the amp. It sounds like this current is still live when you turn the car off, so your amp doesn't know to turn off.
With the car off, test the lead at the remote on terminal (usually blue wire, as I do it) with a dc meter or test probe. If it reads +12v, it shouldn't. Find a new "remote on" power lead. This is generally provided by the "power antenna on" lead out of the deck. Run a wire to the amp from the power antenna on lead, and retest.
I'll bet on success after this.
Bruce
May 05, 2011 | Rockford Fosgate Punch 200a4 Car Audio...
DVD player has no sound but there is sound when it is on radio, I get the picture on DVD but no sound, y just sound on radio & not when I'm playing a DVD ?
are you running the system through an amplifier? if so, you may be using the antenna remote lead to turn on the amp instead of the amp remote lead. the antenna remote is solid blue and turns off when leaving tuner mode. the amp remote turn on should be blue/white.
Nov 05, 2010 | Car Audio & Video
No sound
if it is a aftermarket radio recently installed then most likely hooked up the power antenna wire to factory amp turn on lead instead of remote turn on lead so what happens is when the tuner is on the power ant lead supplies power the amp remote on wire but when you insert a disc that cuts power to the antenna lead and turns the amplifier off
Mar 12, 2010 | Car Audio & Video
Remote wiring for amp
Hello sugarands265,
If you have an aftermarket head unit, it will most likely have a dedicated remote lead, usually blue or blue/white in color.
If the amp is being run from a stock receiver that does not have a remote lead, use any switched 12V+ source.
Hope this helps.
Oct 10, 2009 | Sony Car Audio & Video
Why do my subs work when the radios on but when i play a cd the subs dont come on
Hello m_renner67,
Most likely the amp remote terminal was connected to the head unit power antenna lead rather than the amp turn-on lead.
If the head unit does not have a dedicated turn-on lead, you can wire the amp remote terminal to any switched 12V source.
Hope this helps.
Aug 26, 2009 | Alpine Car Audio & Video
My amp is working fine but turns off when i insert a CD
Hello pumpin_up_da,
The most likely cause for the problem you describe is that the remote turn-on lead to the amp is functional only when the head unit is operating in tuner mode. This could be caused by using a power antenna lead instead of a remote lead. Some head units have both, some only one or the other. Check the wire going to the amp remote terminal with a voltmeter. If it shows 12V when the radio is operated in tuner mode but 0V when you switch to CD, then check the wiring. If this is the cause, and your head unit has a dedicated amp turn-on lead, then connect it to the amp terminal. Most head units that have both power antenna and remote leads code them "Blue" and "Blue/White". If your head unit does not have an amp turn-on lead, you need to wire it to a 12V switched source, usually the "red" wire on most aftermarket receivers. You can then put a SPST toggle switch (available at Radio Shack or most auto parts stores) in line with the wire and turn it on and off as desired.
If the correct wire from your head unit is currently connected, then the receiver is defective and needs repair or replacement. Or, if everything else still functions normally, and really don't want to bother with repair or replacement, you can still use the 12V switched source as described above.
Hope this helps.
Jul 09, 2009 | Ultra Linear UL-2200D Car Audio Amplifier
Amp turns on with the tuner setting and plays, when i switch to ubs mode the amp shuts off
Hello daweeksy115x,
You did not specify your install specifics, but the trouble is probably the head unit "remote turn-on" lead. Some head units will have both a power antenna and a remote lead. If you inadvertently wired the amp turn-on to the power antenna lead, it can cause the problem you described.
If you head unit does not have a dedicated remote lead, the best solution is to wire the amp turn-on terminal to a switched accessory 12V source.
Hope this helps.
May 24, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
Remote wire hook up
The Remote wire should connect to the remote turn on lead from you radio(most aftermarket radios use a blue and white or a blue wire for the remote turn on). This wire will send a 12v signal to the amp from the radio when the radio is turned on. You can disconnect the remote turn on lead from the amp and jump a wire from the terminal marked battery to the remote turn on terminal just to see if the amp powers up. Do not leave it this way however because your amp will not shut off and your battery will go dead.
Aug 19, 2007 | Rockford Fosgate Punch 301S Car Audio...
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
JVC KD-G310 CD Player Logo
102 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
