Question about Sony Ericsson Walkman® W995 Cell Phone
Hello the shell of my phone is scratched.where can i get a replacment and how do i change it
Mossberg 817 magazine
Not much can go wrong. Have you checked your extractor? If it's intact and not broken, try moving it with your thumbnail. Is it loose? That's a spring problem. If it's tight and intact, WITH THE BOLT OUT, try slipping a small diam wooden dowel down the barrel to see how hard it is to push a spent shell out. If it's tight, you've got a burr in the chamber or dirt/varnish buildup. Examine the shell for scratches. If the shell's good and no scratches, clean the chamber with a brass brush mounted in a drill.
Apr 21, 2014 | Mossberg Optics
My outer face plate on the gz one is scratched up can it be repla
You can buy the face plate from:
http://www.1800mobiles.com/verizon-gzone-boulder-accessories.html
Dec 06, 2008 | Casio G''zOne Type S Cellular Phone
Tip
Tips for Mobile Phone Maintenance ?
Now mobile phones are used more and more frequent. But the problem is that it won't take long to find something wrong with our mobile phone. How to make our phone has a long life performance? Here are some tips for mobile phone maintenance.
1.Using mobile phone shells
Using mobile phone shell can reduce the friction of mobile phone shell and protect the surface of phone from scratch, scuffs or paint loss when your phone is knocked against something hard or falls on the ground.
2.Do Not Placed the Phone in Damp Environment
Don't use your phone in damp environment, such as bath crock, laundry chute, damp basement, swimming pool, etc. for a long time unless it is waterproof. You might not know it will cause the short-circuit trouble of printed electric-board due to moisture permeation. And what's worse is that your phone falls into the water accidentally. I am sure many of you have such experience.
3.Protect the Charging Port
A lot of people complained about the bad quality of the data line when they found it don't work well after a period of time use. However, rough use of the date line may be the real reasons. Remember that the charging port contacting with metals will jamming the phone. Keeping the charging port clean all the time!
4.Away from the Magnetic Environment
The Phone transmits voice via wireless signal propagation, and the phone itself has magnetic properties. Both microphones and phone stereo are relating with electromagnetic principle. So protect your phone from dust environment. Otherwise the earpiece voice of your phone will become smaller and smaller, even can't hear because of a lot of dust filling the tiny holes of cell phone radio.
5.Use the OEM charger and USB
An unstable current would greatly damage the life of the electronic components; especially some fake charger for it cannot control circuit effectively. A lot of accidents are caused by Battery Charging.
6.Clean SIM Card
Metal contacts on the SIM card are very important, please protect it from dust pollution and clean carefully. Doing this can delay its oxidation, and prevent the missing of IM card, network interruption or screen display. Generally speaking, the service life of SIM card is over 4 years as long as you won't buy new phones frequently.
7.Pay Attention to the Carry Methods
Many people like to stick the phone in a pocket. But actually it is easy causing damage of mobile phones such as crush when sitting or fell to the ground when walking or running.
Also many people used to throw the mobile phone in the bag, who knows the key or other hard matter in the package is very easy to cause scratches on the phone! Big scratches occur on my new phone because of that! Don't gloat, I have already learn the mobile phone maintenance. How about you!
on Aug 11, 2015 | Cell Phones
I have a maxi cozy car seat but on handle I have scratch it is there anywhere I can get it fix?
Short of replacing the carseat shell, as the handle is part of the shell, there would not be a way of fixing this.
As the shell is plastic, you may find that using furniture polish and a soft cloth to wipe over the handlebar will help make the scratch less noticeable.
Apr 07, 2012 | Maxi-Cosi Baby Gear
Line on left side of printed page toner has been changed and did not fix problem
A line there might not be the toner but the laser drum unit.
The operation below is dangerous - on warm printers you can badly burn yourself, and on all printers you risk severe damage to the drum, requiring replacement.
Opening the printer should show both the toner unit and the drum unit, with a usually green metallic drum cylinder. Taking the utmost care never to touch the drum with your fingers, extract the drum unit and check for anomalies on the RIGHT (where the left side of page goes) side:
- scratches: unfortunately, nothing to do. Drum replacement is your only option.
- black sooty lines: wipe them with a clean, dry, lint-free paper towel. Usually caused by:
- small specks of dirt lodged between the drum and the drum shell. You can remove them with a wooden toothpick. Never use anything sharp near the drum, it scratches very easily and scratches aren't repairable. Sometimes it is possible to raise slightly the shell so that a gap appears between shell and drum, and a folded dry lint-free napkin can be shuttled back and forth to clean the groove from dirt and ink clots.
Replace the drum and print two test pages. The first will usually be very dirty because of the toner loosened in the drum.
Nov 02, 2009 | HP Office Equipment & Supplies
I have a samsung a877 cell phone which got a huge scratch on the touch scree. How much will this cost to repair ?
lots of protectors on ebay. not sure if you can buy a replacement shell for that phone but keep an eye on ebay. only the screen part of the case would need replacement and there are often videos on youtube that show you how it's done
Oct 22, 2009 | Samsung SGH-A877 Impression Cell Phone
How do I change the lamp in a hitachi microwave MCB130V
hello there:
unplug the microwave
remove all of the screws that hold the outer shell on, you dont have to remove the front ok now just remove the shell and you will see the light bulb it will be in the top towards the front ok than replace the old bulb with a new one and put the shell back on and reinstall all of the screws and optest
best regards mike
Aug 06, 2009 | Microwave Ovens
Lg 8300
I wouldn't recommend taking this phone apart as the side buttons never seem to go back together correctly thus creating more problems then before.
What you can try to do is go to an auto parts store and look for Meguars PLASTIX or any kind of automotive plastic polish and try to buff the scratches out. But if we're talking deep gouches then it may be best to just grin and bear it :)
Hope this helps.
Mar 26, 2008 | LG VX8300 Cellular Phone
Replacement of body shell for 7373
well aparently the front clicks off with a screw driver, according to nokia, but i have not tried it yet, so dont blame me if it does not work. about the rest of the phone i have no idea..sorry!!!!
Oct 21, 2007 | Nokia 7373 Cellular Phone
Sony Ericsson Walkman® W995 Cell Phone Logo
23 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
