Question about Euro-Pro UV209 Upright Vacuum
Repair were does the little belt hook up to
    Problem Solver:
  • 3 Answers
It hokes up to the motor and the brush.
Posted on Feb 07, 2010
Kenmore upright Model 116 31912101 Brush doesn't turn. Little red reset pin doesn't move.
Something is jammed in it or the belt is bad.Turn it upside down.You will see 4-6 screws.Remove the screws and the plate they are holding.Now the brush is exposed.The belt hooks on to the brush and a small wheel on the other end.Remove the brush and belt.Make sure the area is free of debris.While you have it off,replace the belt.
May 16, 2011 | Kenmore 31913 Progressive Direct Drive...
How do I replace drive belt
turn the vacuum over,were u are looking that the bottom of it there is a plate that covers the brushes and pulley for the motor remove this plate should be three to four screws the plate will lifted from the back it has two hooks on the front,,after u have done this u take the brush roller out by pulling straight up on it notice how it comes out it should have hexagon ends on it it will side back in the same way,,now take the belt off clean off any debris if necessary put the new belt back on the motor pulley and roller brush, side roller brush back in(this might be a little hard scene u have the new belt on)and be sure that ends of the roller brush sets all the way down on the sides,then put back the plate start from the front putting the hooks on first on the front then replacing the screws, u shuold be good to go, Hope this was helpful
Apr 06, 2011 | Hoover U6630-900 WindTunnel Bagless...
I keep replacing the belt and keeps melting and breaks. what do i need to do? everything else is working, the little piece of metal that hooks on the belt gets too hot and melt the belt
i think your talking about the motor spindel,,(the little metal bit?) if the motor is that hot its going to burn out soon, check that the brush is free to turn if its tight free it off its full of grit or fluff also check that the motor turns freely
Dec 02, 2010 | Dirt Devil M084600 Dynamite Bagless...
The small belt that makes the beater bars spin broke. It is only two years old; repair shops tell me this involves replacing two belts because of some kind of clutch to the tune of $150! Is this possible...
A very easy replacement. The belts cost about £3 each. Yes, there are two belts and even if the clutch needed replacement, this is about £20 for clutch and both belts http://www.dysonpartsdirect.co.uk/dysonparts/dc07belts.shtml - this is a UK site, but I am sure you will find similar prices in the US/Canada. So, total price about $30 USD. What a rip-off - $150! It is very straight forward and just requires turning the turnbuckles that hold the bottom plate that covers the brush bar - then lift out the brush bar and you will then be able to pull out the old belt - hooking the new belt on the clutch mechanism is a bit tricky and requires a bit of dexterity and patience. Once re-assembled, make sure the brush bar rotates the correct way - it should brush to the back of the machine, i.e. when looking at it side on with the front of the machine pointing to the right, the brush bar should rotate clockwise. If not, turn unhook the belt from the clutch mechanism and hook it on the other way. Fiddly, but not difficult. I've done a few now and it takes about 15 mins.
Aug 03, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I need to replace the belt on my kirby.
If this is like my Kirby, there are colored slots on each end that slides the brush in and out and they are different sizes but the belt is connected in the middle. First take the bottom cover off. It should be made out of rubber and metal, and it pops off, you then slide out the brush, take the old belt off and look up inside where you took it off and there is s hook so you first hook the belt on there and stretch it and slide the brush back thru it and then stretch it a little so as to slide it back into the slots on each sde when it is in place you then put the cover back on and your done.
May 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Howdo I replace dyson belt??
Replacing the belt on the DC-17 is not complicated at all. Once I understood how, the process took about 5 minutes. My best suggestion is to call Dyson and they will quickly and cheerfully walk you through it without making you feel stupid. Here is what they told me: 1. Remove the bottom plate that covers the beater bar, using a flat head screwdriver; pull the beater bar out so that it is only attached by the belt. 2. Use the flat head screwdriver to wedge the belt off the beater bar. It takes a little bit of wiggling, but it is not difficult. 3. Once the belt is free of the beater bar, use the screwdriver to unhook it from the gear that is attached to the motor inside. 4. With the new belt, repeat the steps in reverse, hooking the new belt onto the motor gear, over the beater bar, etc.
Apr 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Cant seem to get the green light going on vacuum head,hook seems to be wrong way when its should be hooking the band off its doing the opposite
1)First, you turn the square belt lifter on the front of the power nozzle until the red arrows line up (belt off)
2)Remove the power head from the front of the machine. Now turn the belt lifter the other way and line the green arrows up again (belt on).
3)Turn it upside down and release the two clips that hold the metal baseplate on and remove the baseplate.
4)Grab the brushroll and pull it out of the power head. Slide the new belt onto the center of the brushroll. It will hang loose...it doesn't have to stretch around anything yet. MAKE SURE THAT THE BRUSHROLL SPINS FREELY!! If it doesn't, you'll burn all new belts quickly due to the added strain on the belt. New brushrolls are available here...  NEW KIRBY BRUSHROLLS
5)Look at the ends of the brushroll. The brushroll has three height settings...you should see notches AND  NUMBERS on the sides of the brushroll's end caps. ONE notch (also #1) FACE UP on BOTH sides is the first setting and should be used when the roller is new. Three notches is the last setting used before a new roller is needed and should be used if the brushes are short and worn. Put the brushroll back in, making ABSOLUTELY SURE sure that the SAME NUMBER of notches and the same raised number on the edge are FACE UP on BOTH sides. This is important, as the brushroller will be unbalanced if inserted wrong.
6)Replace the baseplate by fitting the front clips into place and then push it down in back and secure it with the two rear swivel clips. Make sure it fits securely down over the bumper on all sides with no suction leakage.
7)Turn the belt lifter to where the RED arrows line up, making sure that the inner "hook" grabs the belt and stretches it up while you are turning it. Once you have the belt stretched up, put the power nozzle back onto the Kirby and lock it in place.
8)NOW...turn the belt lifter back to GREEN. If the little green light on the power nozzle lights up when you turn it on, CONGRATULATIONS!!! The brushroll is spinning!!
Apr 18, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Replace belt on cartpet attachment (kenmore)
on the newer models remove 2 screws on the bottom of the powerhead,also you need to pry the cover of in the back and sides.
they slip over a little ledge and hook to hold in place
Feb 08, 2009 | Kenmore 22812 Bagged Canister Vacuum
Dyson upright not turning brush belt not broke
that belt is hooked into a clutch, the clutch often fails and the only thing to do is replace it. i would take it to vacuum repair shop because it is not an easy fix
Sep 17, 2008 | Vacuums
How to repair a kirby tradition (3cB) vacuum cleaner brushroll belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=849256
Generic problem for all Vacuums
How to repair a Kirby
Posted by matt700 on July 29, 2008
How to repair a Kirby Tradition (3CB) vacuum cleaner brushroll belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 29, 2008 | Vacuums
Euro-Pro UV209 Upright Vacuum Logo
47 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
