Question about Maytag MMV5165 Microwave Oven
Removal of front glass panel
Is there a way to get the front glass out for cleaning ... it appears that spots of liquid has gotten between the front and rear.
  • 52 Answers
The glass is not removable, due to safety reasons when the unit is being used.
Posted on Feb 07, 2010
How do I clean inside of glass on door of AMV5164BAQ?
You can use normal glass cleaner or bleach with anything but metal abrasive pads
Mar 02, 2015 | Amana AMV5164 Microwave Oven
How do I increase the intensity of the green in the display on my Sharp Carousel R-1460A microwave oven?
This model does not have a brightness adjustment for the VFD display.
It may be a weak VFD tube due to aging or it may be that the rear of the display window and front of the display glass are very dusty.
Sometimes you can clean it inside to brighten it up.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Some connectors have a lock.
positivelock.jpgIf that cleaning didn't help, then you have a weak VFD.
We can replace yours for $74.95. Details are here.
Oct 24, 2012 | Sharp R-1460 Microwave Oven
The inner glass door on my oven exploded over christmas sending glass all over the kitchen no one was in the kitchen at the time or we would have been injured
That can happen with tempered glass. It sometimes happens with car windows too. Tempered glass is treated so that when it breaks, it shatters into little mainly rectangular pieces instead of very sharp shards and splinters. Because of the treatment, it's under stress and can sometimes break if there's a scratch or nick or sudden temperature change. It's possible that over time your oven's inner door had gotten scratched by things in the oven rubbing it, or it had been heated in spots where food spatters absorbed lots of microwave energy. It's a rare thing to happen, not really a result of anything you did, and not likely to happen again.
Jan 11, 2011 | Microwave Ovens
A kettle of soup boiled over on my new Kenimore Elite Electric Range. Some of the liquid that fell down the front went into the vents at the top of the door and dripped down onto the inside of the glass...
This question was asked almost 2 years ago, but thought I'd respond anyway. On the bottom of your oven door there are slots. Pull out the drawer beneath the oven door so you can work under it. Find something that will fit through the slots, a yard stick worked for me, or maybe a wire coathanger. Attach a paper towel or cloth securely to it and put it though the slots to reach the soiled area. It will take some manuvering. I would not recommend taking the door apart. When I did some research on this some time ago, I read that it can be difficult or impossible to get it back together again.
Oct 11, 2010 | Microwave Ovens
Touchpad is not working
Hello :
If touch pad has gotten wet, then allow to dry for several days. Avoid spraying cleaning liquid near touch pad.
Check for insect infestation. Insects (cockroaches most frequently) will appear under clear surface of touch pad or under readout window; they like the warmth of the circuit boards.
Place window mesh over vent to keep insects out.
good luck .
please rate !
Mar 29, 2010 | GE Microwave Ovens
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace the handle. Can you give step by step help?
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Jul 07, 2009 | GE JVM1650 1000 Watts Microwave Oven
Black circle
hi my name is mark, the spot probably is a hot spot. something is absorbing some of the microwave energy.or something that food was cooked on in oven got hot enough to cause spot. you can check taking a glass or bowl of water setting it off to the side of the spot, and after it times out, carefully feel spot to see if it heated up. thanks for your question.
Mar 15, 2009 | Microwave Ovens
There are spots in the glass in the door can you take it appart
There is a screen behind the outer glass of the door which protects you from harmful microwave emmisions. Residue will build up here over time. Trying to clean this screen may damage it and subject you to serious problems. I have been using Microwave ovens for 35 years with no problems. I dont worry about this because germs will be eliminated by the emmisions.
Nov 13, 2008 | Frigidaire PLMV169DC Microwave Oven
Maytag MMV5165 Microwave Oven Logo
123 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
