Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Canon inkjet mfor mx860
How do you add inkjet in canon mx 860?
rajeshpait
  • 542 Answers
SOURCE: I cannont scan from my
Download and install the scanner drivers for windows7 will resolve your problem.
Revert back for more assistance.
Posted on Feb 03, 2010
Grubhead
  • 5190 Answers
SOURCE: Do I have to reset chip on the Canon Pixma MX860
If you can yes!
Posted on Feb 13, 2010
SOURCE: I have a Canon PIXMA MX 860. Why am I getting U052
says code uo52
Posted on Sep 05, 2010
  • 5189 Answers
SOURCE: have a 5100 error on
There are a few issues that cause a 5100 error code. 1) The encoding strip may need cleaning. 2) There is a paper jam. 3) The printer may need to be reset by turning it on and off. 4) The ink tanks may need to be properly snapped into their carrier. 5) The printer may need service.
The solutions to try
1) Cleaning the encoder strip. Use a cotton swab and isopropanol (rubbing alcohol) or window cleaner. A flashlight will help you see any grease on the encoding strip. With the printer on, open the printer by lifting the scanner unit until it locks. Unplug the power cord from the printer and wait until the LEDs are no longer lit. At this point you will be able to slide the cartridge carrier back and forth. To start, slide the carrier to the right. Look for the clear plastic strip (the encoding strip) in front of the carriage drive belt and look for any grease or other dirt on the strip. Remove the grease with a cotton wab moistened with the isopropanol. Look at the strip from several angles to check for any grease along the entire strip. Make sure you do not remove the grease from the chassis (metal rail). Move the cartridge carrier to the left and check the right side of the strip. When all of the grease is removed, lift the scanner unit support and close the unit. Plug in the power cord and turn the unit back on. Often grease gets on the encoder strip when you remove a paper jam. If you proceed to the next step, you may have to repeat this cleaning.
2) A paper jam
Carefully pull any sheet from the rear tray or paper output slot. Detach the rear cover and fully extend the rear tray support and try to pull the paper out slowly. Otherwise try turning the printer off and on - the sheet may be ejected. Remove the paper cassette and pull any paper out slowly that is in the front area. If needed, try removing the paper cassette and any paper in the rear tray. Then turn off the printer and unplug it. Set the unit upright on the left side and try to pull the paper out. Return the printer to the usual position when done. Replace the cassette, plug in the power cord and then turn on the printer. This will delete any documents in the printer queue. Check for foreign objects around the paper output slot. Remove any foreign objects with the unit off. Close the rear cover completely. Make sure that the paper isn't curled up.
3) Turn the unit off, unplug the power cord and wait 10 seconds or longer. Plug in the power cord and press the On button. Wait until the printer completes the cycling process before trying to print again.
4) Verify that the ink tanks are properly seated. With the printer on, lift the scanning unit up until it locks. Press on the black circle on each ink tank until it snaps firmly into place. Check if the ink lamps light up red. Make sure the protective shipping covers was removed from the ink tanks. If the unit has the remaining ink level detection feature disabled, replace the ink tanks. Close the scanning unit.
5) If none of the above solutions work, contact Canon if the unit is under warranty. Otherwise, decide if the service is worthwhile for an out-of-warranty printer.
I hope this helps.
If the paper tears when you try to remove it, open the scanning unit with the printer on and unplug the printer. Then look for and remove the paper. Use a flashlight to check for paper and other foreign objects in the corners. Slide the cartridge carrier back and forth to check the corners completely.
For pictures check the support site: http://www.usa.canon.com/cusa/consumer/products/printers_multifunction/office_all_in_one_inkjet_printers/pixma_mx860#ServiceAndSupport . Search for the error code 5100 and then follow the links.
Posted on Jan 09, 2011
We have mx 860 and there is no pdf option for scanning to. how do we get that option?
If from the MX860 you have proceeded through the scan menu and selected your computer, and you don't see PDF as an option, you will need to re-install your PDF software onto your computer. This will most likely solve the problem. If this does not work, you may want to try cycling of your PC and the Printer. If this does not work, you should also re-install or update the MX860 software.
Jul 13, 2014 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Canon pixma MX 860.Its not printing anymore.when it tries it make a loud rattling noice and an error code 5c20 comes up. Cartgridges have been removed and put back.Dont know how to check on the printerhead
Hello.
To check the print head remove the cartridges. To the left of right of the cartridge holder there is a orange or grey lever. lift this and remove the print head. The rattling noise could also be the belt that moved the cartridge carriage back and forward. this belt is directly behind the carriage. This belt may have slipped from its wheels at each end of the printer. look inside it with a torch for a clear view. Before doing this please remove the power cord from the back of the printer to ensure your safety.
I hope this helps Regards GM
May 26, 2011 | Canon PIXMA MX860 All-In-One InkJet...
Why can"t I scan from
Many printers simply don't support the scan function when they are wireless.
Check your manual.
You may simply need to hook it up USB to scan.
Mar 05, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
How do I reset the ink cartridge once I have refilled it canonmx 860
You can't reset the cartridge unless you check on line and get either a chip to install or a chip resetter. Canon built in a chip to say when they're empty and you can only refill them if you refill before they say they are empty.
Jan 14, 2010 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Error c000 on my pixma mx 860
your printer puge unit ching new purgeunite okyour printer
Oct 09, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
I added a printer (MX860) at my other house and now I can't scan on my MP830 it has scanner selector set on MX860 and I can't change it.
Ok. I guess you should try unplugging the usb to the 860 and only have the 830 plugged. Click on start, control panel, printers and faxes, then select the 830, then a window should come up, click the word PRINTER, then select default. try restarting pc and doing a scan. I hope this works. I cannot be certain as other factors may be involved.
Sep 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
53 people viewed this question
old marine
old marine
