Question about Honeywell Programmable Thermostat Heater
I have set the timer to come on at certain times and it is not, it comes on when it feels like it. I have the date and times all correct.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
The only reliable place (?) to get specific operations and program manuals for your particular product, would be from "customer support" at the "manufacturers" web site or phone number. The "Model", "Serial" and "Product" numbers of your particular thermostat are usually printed on a small piece of paper pasted in its cover somewhere. That said, here are a couple things that seem to be fairly standard. Remove the thermostat from its base plate and remove its battery's. Its best to start with a clean program to eliminate the possibility of having entered something wrong previously that may cause you trouble later. Its also much easier to do all this while sitting at a table and not hunched over at the wall. The battery's are used to store your programming so be sure to put good ones back in before starting. A "SET" button or touch sensitive area on the display screen will normally put a thermostat in its programming mode. With most thermostats, the display will blink to let you know you are programming. While in this mode, use the temperature set arrows ( up and down) to scroll through all the different things that can be set. When you hit one you are looking for, press the left and right arrows to put that function, schedule or time where you need it. Press the up and down arrows to get to the next adjustment, left and right arrows to set. Keep doing this until you have gone through all the various set points. When you think you are all done, Press the "RUN" button to lock it all in and start running all the programs. Be careful of overlapping the times in the schedules. That can keep your system running all the time or maybe even not at all. This may help some or not at all. Thermostats is a deep subject and specific factory information is needed for most of them. I hope this helps though. At least a little anyway. Roger.
Posted on Jan 11, 2014
Is the timer button for lengh of usage or to set to come on at a certain time
Timer is normally for Length of use. Generally a run down clock.
and Alarm is when it comes on at a certain time using the present clock.
Try it out with a small number for example 1 or 2 minutes
Sep 22, 2016 | Hardware & Accessories
How do I change the day, date etc on a GENEVA 7391 watch
read the instruction manual, Geneva Watches with Two or Three Hands
  1. Pull the crown out until you feel a click.
  2. Turn the crown counterclockwise until you have the correct time.
  3. Push the crown back in to set the time.
Geneva Watches with Two or Three Hands and a Date Window
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the time.
  2. Turn the crown counter clockwise until you have the correct time. Push the crown all the way in to set the time.
  3. Pull the crown out until you feel one click. This first click position allows you to set the date.
  4. Turn the crown counterclockwise until you have the correct date. Push the crown back in to set the date.
Multi-Function Geneva Watches
  1. Pull the crown out until you feel two clicks. This second click position allows you to set the day.
  2. Rotate the crown counter clockwise until you have the correct day. Push the crown in to set the day.
  3. Pull the crown out until you feel a second click to set the time or the 24-hour hand.
  4. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  5. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
Geneva Chronograph Watches
  1. Pull the crown out two clicks. This second click position allows you to set the time.
  2. Turn the crown clockwise until you have the correct time, then push the crown in to set it.
  3. Pull the crown out just one click to set the date. Turn the crown clockwise until you have the correct date, then push the crown in to set it.
  4. Stop and start the chronograph by pressing the PA button, located above the crown.
  5. Reset the chronograph by pressing the PB button just below the crown. The PB button returns the chronograph second and minute hands to their original positions of zero.
Automatic Geneva Watches
  1. Wind the mainspring by turning the crown 15 to 20 times clockwise.
  2. Pull the crown out until it clicks.
  3. Turn the crown counterclockwise until you have the correct time, then push the crown in to set the time.
Tips & Warnings
  • Do not set the date or time between 8 p.m. and 3 a.m. to avoid damage to your Geneva watch. The gears sit too close together during these times.
  • If your Geneva watch becomes wet, wipe it dry as soon as possible. Keep your watch away from saunas and hot tubs, as the extreme heat diminishes the watch's water resistance.
Read more : http://www.ehow.com/how_6134550_set-date-time-geneva-watch.html
Jul 13, 2015 | Geneva Watches
How do I change the time on my CopyStar CS-1820
Setting the Time Zone
1 Access Time Zone.
If you are unsure how to use this route map refer to Accessing Menu Items on
page 3-3.
2 Press arrow keys to select the time zone that you are in.
3 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
4 Press right Select. The message display returns to the basic screen.
NOTE: Periodically check the time that is shown in the message display and adjust
as necessary to match the current time.
1 Access Year/Time.
page 3-3.
2 To set the date, for each field press arrow keys as many times as necessary to
display the correct value then press arrow keys to move to the next field.
3 When the date is correct, press Enter. The time setting screen
(hour:minute:second) is displayed.
4 To set the time, for each field press arrow keys as many times as necessary to
5 Press Enter. The message display shows Completed and returns to the Date/
Timer Set. screen.
6 Press right Select. The message display returns to the basic screen.
Mar 17, 2011 | Copystar CS-1820 Copier
L.S.My Pioneer DVR-550H does not record when programmed with the timer. After setting a timerprogram one can see the small red clock in the display but that disapears after some time and so the DVR does...
Make sure you have the right date and time set. You cannot set a timer program until you have the correct time and date set. Let me know if that helps.
Feb 20, 2011 | Pioneer DVR-550HS HDD Recorder
Unable to set the correct date. Able to get to menu:additional functions,timer settings and the date and time settings, but unable to change the time
Type everything in and then press OK. If its showing up on scan time then go to Add Funct-System-Date and Time. Make sure time zone is set correctly
Nov 30, 2009 | Canon imageRUNNER 1023iF Black and White...
How can I set the correct date and time on my Logitech MX 3200 wireless keyboard?
"To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Nov 10, 2009 | Logitech Wireless Access Duo Optical...
..not able to set timer to come on and go off a certain time
the pin for the timer and be any color.
if you have the pin in the right place, and turn the timer dial to the time you plug into the wall and turn on the black switch on the side. it shoud work.
check the timer after couple of hours. and make sure the timer is running correctly.
chances are there is a flat spot on the timer. it stops at a certain spot.
hope that helps
Apr 09, 2009 | Intermatic & Lighted Dial Timer
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
