WE NEED THE SCHEME FOR TV SEG 11 AK 53 - Televison & Video
My seg tv has sound but no picture
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 25, 2014 | SEG Seattle TV
My Sony KP53HS10 screen goes black but sound is ON
sonys generally run hot as a tv they are usually noticabley heavier due to extra internal tube screening this can cause the solder to crack or whats called a dry joint if tapping it on the side makes a difference or it comes back on briefly then this is almost definitely the fault, just need to find it and resolder
Jul 19, 2009 | Sony KP-53HS10 TV
ELETRIC SCHEME KP-53V35
Service manual pdf file of KP-53V35 is available in Manual Zone for small fee.
Mar 27, 2009 | Sony KP-53V35 53" Rear Projection...
The red square on the digital array alignment is moving up and down,but now side to side
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 04, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Need assistance
Dec 18, 2007 | Hitachi 53FDX01B 53" Rear Projection...
HITACHI 53" PROJECTION TV 53FDXO1B
Convergence amp ic bad
http://www.hdtvoice.com/voice/showthread.php?t=28929
Oct 11, 2007 | Hitachi 53UDX10B 53" Rear Projection...
53" Panasonic HDTV showing letters and shadow
maybe you have defective convergence correction circuit! replace a new one!
Oct 03, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
