Question about Grundig GUFSAT02SD
Beep when changing channels
How can i turn off the beep that occurs when changing channels
Press menu, settings, key beep - can be toggled on or off
Posted on Sep 20, 2010
Sony 910 baby monitor makes loud beeping when turned on
The picture you posted looks like it has the channel setting option. Notice at the bottom there are three little holes that are (as I recall) either red, yellow or green. You have to set the channel on both the transmitter in the baby's room, and in the receiver you keep with you, so that they have the same pattern of colored dots in those holes. When they have the same pattern, they're on the same radio channel. If you can hear a neighbor's monitor, pick a different color pattern to change channels. As long as both units have the same pattern, you should hear the baby, not the beeping.
Aug 09, 2014 | Sony Ntm-910 Baby Monitor
Radio keeps beeping when I turn it on? I confirmed its not because of a low battery but something else.
A few thoughts:
If it is a long continuous beep this can be an indication of having the channel select set to a channel which is not programmed.
If it is a beep that only occurs when you press the PTT button, similar to the low battery beep, it could be a battery, battery contact, or internal battery contact issue. Clean battery contacts between radio and battery, as well as external contacts, with a pencil eraser to assure a good connection.
If it is a beep that occurs periodically when pressing the PTT button, it is possible your radio is programmed with busy-channel-lock-out (talk prohibit tone), which would not allow you to transmit on a frequency which is already in use.
Best regards.
Oct 11, 2013 | Motorola Mag One BPR40 Two Way Radio
Walkie talkies model gmr325-2 ic;513C-UT914 HOW DO I GET THESE TO TRANSMIT, MY HUSBAND HAS CANCER AND WE NEED THEM IN OUR BEDROOMS AND WHEN I AM OUTSIDE, TK U, TK U
In order to get the most out of your new radio, read this reference guide completely before attempting to operate the radio.
Turning the Radio On and Adjusting the Volume
1) Press and hold the key to turn the radio ON.
2) To change the volume level press the volume/monitor up or down key to increase or decrease the volume level.
3) Press and hold the key to turn the radio OFF.
Adjusting the Sound (Key Beeps)
Your radio emits a beep each time one of the keys (except for the PTT button and call key) is pressed.
The sound of the Key Beep will increase or decrease depending on the volume level setting.
To turn OFF this beep:
Press and hold the call key while turning ON the radio.
To turn ON this beep:
Turn the radio OFF and ON again.
Choosing a Channel
Your GMR325-2 radio has 22 channels you can use to talk to others. In order to speak to someone,
each of you must be set to the same channel.
To choose a channel:
Press the channel/scan up or down key to increase or decrease the channel number displayed.
Channel Scan Feature
Your GMR325-2 radio has a channel Scan feature that allows you to easily Scan all 22 channels. When an active channel is detected, the unit will pause on that channel until the channel is clear. Then after a 2 second delay, the unit will continue scanning.
Pressing PTT button while the Scan is paused on a channel will allow you to transmit on that channel.
To turn ON channel scanning:
Press and hold either the channel/scan up or down key. The channel number on the display
will rapidly cycle through the channels.
To turn OFF channel scanning:
Press either the channel/scan up or down key.
Talking on Your Radio
To talk to others using the radio:
1) Press and hold the PTT button and speak in a clear, normal voice about 2-3 inches away from the microphone.
While you are transmitting the tx icon is displayed. To avoid cutting off the first part of your transmission, pause slightly after pressing the PTT button before you start talking.
2) When you are finished speaking, release the PTT button.You can now receive incoming calls. While receiving, the rx icon is displayed.
Transmitting a Call Alert Tone
Your GMR325-2 radio is equipped with a call tone that will be transmitted when the call key is pressed.
To transmit the call alert tone, press the call key.
The tone will automatically be transmitted for a fixed length of time.
Auto Squelch Feature
The GMR325-2 is equipped with an automatic squelch system which shuts off weak transmissions
and unwanted noise due to terrain conditions or if you have reached your range limit.
Monitor Mode Feature
Your GMR325-2 radio allows you to listen for weak signals on the current channel at the press of a key.
To turn ON monitor mode:
Press and hold the volume/monitor up or down key. The rx icon will blink.
To turn OFF monitor mode:
Press the volume/monitor up or down key. The rx icon will stop blinking.
Automatic Power Save Feature
Your GMR325-2 has a unique circuit designed to dramatically extend the life of the batteries. If there is neither transmission nor an incoming call within 2 seconds, your radio switches to the Power Save mode. The radio is still able to receive transmissions in this mode.
KEYLOCK ON/OFF
Press and hold the call key until the "L" appears. After 1 second, the LCD will return to the channel display.
To exit Keylock on mode, press and hold call again.
Note: While in keylock on mode, it will still receive transmissions.
ROGER BEEP
Roger Beep is a BEEP that is sent to notify the end of transmission.
Roger Beep can be heard through the speaker when Key Beep is on.
Roger Beep is transmitted even if key beep is turned off. However Roger Beep will not be heard from the speaker.
To turn OFF Roger Beep: Press and hold the channel/scan up Key while turning on the radio.
Jun 21, 2011 | Motorola Walkie Talkies 2-Way Radio
I setup my motorola cls1110 to the same frequency as my other 2-way radios. (Freq 6, Code 10). When I try to push to talk all I get is a beep, and it won't allow me to talk. What can I do to fix this...
A beep when pressing the PTT button could be a low or bad battery indicator. It takes more energy to transmit than to rest idly or receive. Try a known good battery in the radio and see if it corrects the problem.
If the battery is not the issue, then you may have a programming problem. Typically radios with a blank or unprogrammed channel will beep when placed on that channel. Try programming the radio to a different channel and see if the beep still occurs. If the beep occurs on many program settings you may have a deeper issue.
Best regards.
Feb 15, 2011 | Motorola CLS 1110 (1 Channel) 2-Way Radio
It turns on but keeps beeping
The constant beep means that the channel you are on is not programmed. Try moving the channel knob to other channels. If it stops beeping, you are on a channel that is programmed. It is possible that none of the channels are programmed though.
Take it to a motorola dealer and they can program it for you.
Jul 15, 2010 | Motorola HT1000, MTS2000, MTX8000/9000...
I plug up the ps3 and when i hit the power button it beeps
This can sometimes occur when the system is hooked into a vcr or tv through the audio video cables. Make sure to check the channel for output some tv's have channel 3 and the vcr/dvd I have to turn it on and select L1 for line 1 input. Also I have experienced the actual audio video cable you get with the PS3 sometimes goes bad, so I had to get a new one. Another reason it may be just beeping is the software update did not complete and the system shut down or power outage occurs, if the above answers don't work check sony's website for more information how to fix a corrupt system update.
Nov 29, 2009 | Sony Playstation 3 (PS3) Console
Acu-Rite indoor outdoor thermometer won't stop periodic beeping
There is no way to turn off beeping. From this site: http://www.chaneyinstruments.com/FAQ.aspx
found solution - search for - Q: My wireless weather station periodically beeps, why?
A: .. unit's ability to detect a foreign radio frequency of another wireless unit when that unit transmits a signal. .. any wireless devices transmitting on a radio frequency have the potential to interfere with each other. Limit the amount of wireless devices to lesson the chance of interference. When beeping occurs, one device will need to be deactivated.
There is no way to turn off beeping, d/s designers forgot. I had the same problem, another external temp gauge showed up on the other channel, so my neighbor or someone is using the similar unit. MY SOLUTION: opened back of case and cut black wire to piezo speaker (at base if rear cover opposite side of stand-up prop) that creates beep. Don't use any sound features, ALL good now.
Nov 24, 2009 | Acu-Rite Audio Players & Recorders
Sony KV-27V22 scrambled picture and loud buzzing audio
the variation from higher channels from lower channels, few things changes eg frequency, voltage, and current.
take your tv to a w/shop and have the following
tunner voltage pulse variation on a avo meter has you change channels. if the difference of voltage is not unform when you are changing from to channel then you should change the control ic on the rf stage or check the capacitors a round the rf ic for variations in value.
Mar 25, 2009 | Sony KV-27V22 TV
Constant beep, channel number and tx flashing
Ok this problem is caused by the spring mic jack
Getting rusty
Oct 26, 2008 | Uniden Atlantis 250 Marine Radio
Grundig GUFSAT02SD Logo
246 people viewed this question
Top Grundig Televison & Video Experts
Henry  Thomas
Henry Thomas
Raj Patel
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
