Question about Epson Office Equipment & Supplies
How do I get my epson sx600fw printer to recognise non genuine cartridges?
  • 677 Answers
You cant !
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 09, 2010
SX200 WILL NOT RECOGNISE NON STD INKS
Check your update settings in the printer software. Turn off any automatic updates from Epson. To get updates, put some old Epson cartridges, good or bad, in while you update. Epson will log on to your printer and kill your non-Epson cartridges during auto updates.
Apr 09, 2015 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
Epsom sx100 keeps saying cartridges are not compatatble but are using epsom inks
If you have Genuine Epson cartridges and they do not work, call Epson Tech Support. You have to be patient [they're in India] and you may have to ask to speak to someone in the US if you're getting nowhere with TS.
Oct 06, 2012 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
My epson printer does not recognise the ink and
this issue mostly shows when the cartridges are no genuine epson cartridges. if they are, you should return and exchange the defective cartridge with your supplier.
Mar 09, 2010 | Epson Stylus NX400 InkJet Printer
EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 29, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Epson sx600fw displaying paperjam, No sign of any jam
did it happen after physically cleaning/flushing the head? I've had this a couple of times and clearly no jam. I removed the cartridges again, ran the rollers backwards and forwards a few times using the white gears, and powered up .... it recognises no cartridge present so went through the replacement again and the fault then clears. I think the s/w gets its knickers in a twist Printer is a heap of poo, and clearly designed to use asmuch ink as possible as it needs cleaning far too often. Wasted too much time on gettingit to print
Jan 15, 2010 | Epson Office Equipment & Supplies
My printer will not recognise non epson cartridges
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!! How you were able to use generic is amazing. I was not able to do that!
TRYING PURCHASING GENUINE, and see what happens? This is the only advice I can give you. If you find this helpful, pls rate me.
Oct 27, 2009 | Epson Printer
Non recognition of genuine Epson cartridge which was already used
try this hold down all 3 bottons for 20 sec this will reset your printer
DONT FORGET TO RATE
Nov 24, 2008 | Epson Stylus Photo R220 InkJet Printer
My epson r285 wont recognise compatable inks
My Epson R285 will not recognise compatible cartridges,mainly the black.I ran out of black ink and installed a compatible cartridge but it did not recognise it.To get the printer running I had to buy a genuine one which worked.I then ran out of all the other colours soon after and installed compatible ones which were accepted.I have now ran out of the black again but the printer will not accept the compatible cartridge.How can I solve this problem as the printer has accepted black compatibles before.
Thanks Padgy
Oct 09, 2008 | Office Equipment & Supplies
Printer says "Install ink cartridges correctly and then hit ok"
Try putting genuine ink it. If it still refuses to recognise the carts then it need to go back to Epson for a warranty repair. As an Epson eng 90% of the time, rubbish compatible cartridges are the source of such issues. They can even make the printer stop recognising genuine carts.
Do not mention to Epson that you used compatibles or they may refuse the warranty repair.
Oct 18, 2007 | Epson RX620 All-In-One InkJet Photo...
400 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
