Question about Music
I bought a Wurlitzer funmaker and after 2 days ALL of the G keys just stopped working. I put that down to bad luck, but I was wondering how I would fix it.
  • Music Master
  • 5,603 Answers
If the unit is under warranty make use of it.
If this is second hand, then open unit and look for a connector or cable that might be ajar.
The keys are often scanned in a matrix so a single wire will kill a particular note.
IF THIS is a tube organ or a vintage unit, is suspect one of the tubes has failed. They often had seperate oscilators for each note of the 12 so a single oscilator being dead will kill a particular note.
Note that often the tubes used are 12AX7, 12AT7, or 12AU7 and these will have TWO heaters glowing in each if they are not burnt out.
Posted on Feb 08, 2010
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Where can I get a users manual for a Wurlitzer Model 565 organ?
There is a Wurlitzer 565 in perfect condition onE bay with an owners manual. If you contact the owner perhaps they can give you some contact info inside the manual on where to get a duplicate. or for a fee perhaps they can make you a copy. If not The Wurlitzer Co. was originally from North Tonawanda, NY. I Lived there for years. It is now a museum. "The Wurlitzer Factory." If you google it you can contact them and they may be able to help you. good luck in your search.
Dec 21, 2014 | Wurlitzer Music
The top keyboard of 3 keyboards work, but not the middle and bottom one. There is a distort sound on speaker if you press one of the keys on middle and bottom one. What can be the problem Please ....
I haven't actually got the means to trace out diagrams on this particular model but I did find you a service manual if you have the technical skills to fix it.
https://celedoniaorgan.netfirms.com/cos2/index.php?main_page=index&manufacturers_id=19
Mar 09, 2014 | Music
What caused my wurlitzer model no. 625 to stop playing after removing the ear phone plug I had inserted? I get electric static when turned on so I know it's getting electricity.
Well if the removing the earphone plug and the unit no longer working aren't a co-incidence? Then perhaps the earphone socket has faulted and cut off the speakers, output. You see in an earphone socket there is an additional set of contacts, that makes & breaks the line to the speaker and routes it to the earphones, often these contacts will stay open, after the plug is withdrawn. and thus stop any output from going to the speakers. Or sometimes the solder join on the PCB can break and the effect is the same.
The only way to tell is to examine the unit and check this out. As mooted before though, i do wonder if this isn't a co-incidence, and the fault is to do with something else, often these units fail in the area of the output amplifier IC's. The unit really needs to be put through the troubleshooting procedures to exactly tell. If one was to attempt a DIY, then at the least one would need to obtain a service manual, for these steps and to obtain the parts numbers to buy any spare parts.
http://www.jukeboxparts.com/new_page_4.htm
Above is a place to assist you with a service manual, should you wish to DIY? However, Wurlitzer's are a complex device, and my professional recommendation is to get a "Quote" for any prospective repairs, from a Wurlitzer repairer.
Jul 25, 2011 | Music
Low sound an hum from turntable with cobra tone arm 1955 wurlitzer but when another source is plugged in to aux in works fine. What could be causing this? Changed all the caps in this unit.
Hi, I believe I know what's causing this-It sounds to me like you have an open ground somewhere between your cartridge and amp. A headphone cord should make an acceptable substitute for the original wire if exact replacement is unavailable. I have heard many a hum in my day. I think this helps, Good luck and thanks for asking FixYa, Prodzilla
Apr 19, 2011 | Wurlitzer Green Zenith Cobra Cartridge...
I have a Yamaha PSR-S700. Recently, the touch sensitivity in one of the keys stopped working. Very little pressure applied would cause the note to sound as if the touch sensitivity was off completely. Now...
You MAY be confusing touch sensitivity with VELOCITY sensing. Touch sensitivity is PRESSURE put on AFTER the note sounds that causes modulation. VELOCITY is what is used for example to control the loudness of pianoo notes depending how fast they are struck. VELOCITY sensing is done by using TWO contacts at every key... one closes first. IF one of these gets dirty, FULL velocity will be sensed and it will be LOUD. The contacts can be cleaned using ONLY 99% isoprophyl alcohol and Qtips after MUCH disassembly of the keyboard. The contacts are conductive rubber pills in silicone rubber domes. Clean boththe contacts and the circuit traces they pres down onto.
Apr 02, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
I have a Wurlitzer Funmaker organ that has no sound. Is there a reset or fuse I should be looking for to get this organ working again? I removed the back Panel and need some suggestions the light on the...
Contact Morelock's Organ Service, Rienzi, MS, United States Phone 601-462-7611. Provide them with the complete model number and expect to pay for a service manual if they have one. Start at the end of the power cord and work towards the amplifier section. You will want to establish that the power supply is working correctly. The light is only an indication that the power cord is getting power to the power switch. If the power supply is providing the correct voltages to the other circuit sections of the organ then you will have to trouble shoot each one separately. Check to make sure the speaker is functional. If it has a headphone jack test it also as it may cut the sound to the speaker out if headphones are plugged in. If it is faulty, sound may not get to the headphones or the speaker. You will also need tools. At least a volt/ohm meter.Remember not to work on the circuits with the power on unless you absolutely know how to do this safely. There are lethal voltages in the power supply.
Dec 18, 2010 | Music
I have a Wurlitzer Funmaker Organ Model 445 Super Sprite Syntha Solo with an earphone jack under the right corner of the organ keybed. I have lost the original earphones and can't find one to fit into the...
There are only a few sizes of jacks that are likely size in these units.
1/4. 1/8, and 5/32 plugs.
Radio Shack has adapters between almost any sizes.
I do not have one of these units and documentation searches come up empty.
Sep 10, 2010 | Music
Wurlitzer organ, highest key plays note one octave too low.
If this is the kind of organ with the wire sticking out of the key that makes contact with the bus bar to create the note you will have to make sure that key is operating the same as adjacent keys. The busbars have to be clean and the contact wires have to be clean. Sometimes when cleaning the wires they will spring out of place and not make contact with the appropriate bus bars. Check that key against the rest and see what you find. Hope this helps.
May 17, 2009 | Music
Wurlitzer 200a electric piano replacement transistors
do you have the numbers off the transistors? i can look up the data sheets and pick a suitable or improved replacement.
Jan 12, 2009 | Music
Music Logo
153 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
