Question about Garmin nuvi 350 GPS Receiver
Switch does not work,has been faulty for some time having had to hold down a long time to turn on or off
    President:
  • 1,738 Answers
Contact Garmin Customer Support to have the unit repaired.
North America - Consumer Products
Monday - Thursday: 8 AM - 6 PM, Friday 8 AM - 5 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Posted on Feb 08, 2010
AEG Lavamat 60810 E70 7Beeps Does seem to still work but display shows E50 and some time E70 and 7beeps over and over. Many thanks
First of all, read exactly alarm code.
Press "Spin/Rinse hold" button and "Prewash" simultaneously for at least 2 seconds: the LED switch off and then display the
sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down. During the time the alarm is displayed, the appliance continues to perform the cycle or, if it is in the
selection phase, it keeps in memory the options previously chosen.
E70 - Family alarm code
  • E71 - Washing NTC sensor faulty
  • E74 - Washing NTC sensor badly positioned
Causes: NTC sensor badly positioned; NTC sensor faulty; wiring faulty; PCB faulty.
E50 - Family alarm code
  • E51 - Motor power supply triac short-circuited
  • E52 - No signal from motor tachometric generator
  • E53 - Motor triac sensing circuit faulty
  • E54 - Motor relay contacts sticking
Causes: Motor faulty; wiring faulty; PCB faulty; current leakage from motor or from wiring
Dado
May 05, 2015 | AEG Washing Machines
Mg 5350 6502
Solution 1:
  • Unplug the printer.
  • Remove the faulty Cartridge
  • Plug in the printer and press and hold power button
  • Keep it held down. Press Resume twice, and this should reset the fault.
Solution 2:
  • The last cartridge installed may be faulty.
  • Install a new cartridge
Solution 3:
  • When error is indicated, turn power switch off so green light is extinguished.
  • Hold down resume button and hold down power button so both are held down at same time
  • When green light comes on, continue holding down power button and let resume button go, then press resume button twice.
  • Let power button go.
  • Press resume button four times, power button should be released before doing this.
  • Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on.
Nov 21, 2013 | Canon Office Equipment & Supplies
1997 olds cutless brake lights will not work. bulbs, fuse and switch are good
Its a faulty turn signal switch.Try this,push down and hold brake pedal while pushing on the hazard switch and if the brake lights come on then replace the signal switch.
Jan 29, 2012 | 1997 Oldsmobile Cutlass Supreme
No brake lights but have the three brake light works
You have a faulty turn signal switch.You can check it by pushing down on the brake pedal and holding it while pushing on the hazard switch.If the brake lighs come on then replace the turn signal switch.
Nov 02, 2011 | 1998 GMC Jimmy
When i switch on the canon ip4300 printer orange light flashing 5 times
5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Feb 28, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Wont Run unless hold start switch
You most likely have a faulty motor centrifugal switch. This switch is engaged when the motor starts rotating. The switch itself could be faulty or the inertia-mechanism that activates the switch could be faulty. The inertia-mechanism usually has two small springs that pull it back into its resting position when the motor stops turning. I have found that the springs will sometimes break and produce the symptom you have described.
Below is a diagram of common centrifugal switches. The switch will be mounted on the end of the motor.
Jun 21, 2010 | Kenmore 63932 Electric Dryer
2nd controller not working
Try this: Switch on controller 1 on, now hold down the PS button, now select Re-assign controllers and set this one as 1. Now turn it off.
Switch on controller 2 and do the same as above but Re-assign the controller as 2. Now power off.
They are both trying to grab the top spot at the same time.
If this doesn't work, connect that controller using the usb cable and do the same as above.
If the controller still has botth LED's lit when the usb cable is connected, then either the controller is faulty or the PS3 is at faulty and may have to but set back to factory defaults, do this first and if that doesn't sort it out then the controller is faulty.
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
My ipod wont switch on
I would suggest you take it in to the apple store for repair already. Most often this type of problem is hardware related already.
Mar 07, 2009 | Apple iPod nano MP3 Player
DRYER ONLY WORKS BY HOLDING DOWN THE TIMER BUTTON
You need to replace or repair the timer control, this is not a faulty motor control unit.
You find parts by entering model number here.
Dec 15, 2008 | Dryers
This Sounds Stupid =(
faulty power switch on the play button? Try reflashing the firmware most MP3 player companies will post firmware updates on their websites usually under "support" once you reflash the player try it again. If it still doesn't work i have one other idea although it may sound stupid. Did you put batteries in it or is it an internal battery?
Jan 03, 2008 | Nextar MA933A MP3 Player
Garmin nuvi 350 GPS Receiver Logo
49 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
