Question about Sony Playstation 3 (PS3) Console
No picture, green splotches
I cant get a picture and have checked av cables and tv. sometimes it will turn on and then go blurry with green splotches. a few time i can get into the game then it freezes before the game starts
  • luckafrei Feb 24, 2008
    i will turn on the system, but it will freeze once i start playing a game. i reset and go back to the main menu and i get these green splotches everywhere and it will keep freezing. when it doesnt do the green splotches it looks like something from the matrix. ive tried the intercooler and keeping the vents open and away from walls but it still doesnt work
  • 4 Answers
Sounds fecked, have you tryed it on a different tv? if so then just phone sony.
Posted on Feb 22, 2008
We have a LG42lx6500. when you turn it on after being off for a few hours the picture colour is distorted for a couple of minutes before correcting. At times you can see the individual pixels. Sometimes...
Hello
Make sure TV is on the correct channel or input. Check the cables for correct routing from TV to any other devices. Check cables to ensure they are tight and secure.
An analog signal converted to high defintion resolution will cause lines, blurriness or fuzziness in the picture. Change the resolution to a lower or native setting using the media device (cable box, DVD,). This may be an issue that requires a service call to cable provider.
A problem on one channel may just be a error on that channel. If using an antenna, it might need to be adjusted in order to ensure good signal strength. For digtal channels, go into TV Menu. Check the DTV signal. Weak signal can cause picture distortion.
If another device is being used such as a cable box, DVD player or VCR switch between devices and test picture. Check routing of cables that are used to control the image. This should be a series of red, white and yellow cables.
If a VCR with a cable box, make sure the VCR and TV are set to the correct channels for video signal to pass through. If problem is still occuring, try another set of cables. bad cables can cause picture distortion.
Bad cables can cause picture distortion as well. Try another set of cables. If picture is better than when using the cables replaced, this was the issue. If cables are not an issue TV may require service.
Apr 26, 2011 | LG Televison & Video
Blurry picture
convergence problem...very common. An excellent TV, well worth repairing!
Jun 03, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My screen on my nes is blurry how can i fix that
If your screen shows a blurry image it can be a few possible things (and only these things).
1. The first and most obivous problem is being on the wrong channel - for example, if you are on Channel 3, but the switch on the back of your system is set to channel 4, you'll see a VERY fuzzy picture; simple switch to the other channel and it will come in clear.
2. Now...assuming you are on the correct channel, does your television receive other pictures clearly (for example if you change to a normal broadcasting station and it is still blurry, then it is a problem with your TV and not your NES system). Another way to test is to simply switch TVs and see if the same picture problem occurs.
If 1 and 2 are not the problem, them we know the problem is with your NES system and this should be an easy fix.
If you are using an RF Switch, then it is most likely the pin on either end of the switch has become bent (or was bent and now is bent back) and will no longer give a clear picture. The easiest way to test this is find a set of AV cables (any av cables - these are the red, white, and yellow cables that often hook DVD players to television). Find a set and just take one of those ends and connect it to the side of the NES system into the circle that says VIDEO and take the other end of that same color and put it into your TV into the circle that says VIDEO (note that the colors don't always match up on the newer TVs, just make sure that if you are using the yellow end of the AV cable and plug it into the video on the NES that you plug the other yellow end of the av cable into whatever color on the TV says VIDEO! Then change your tv to the cannel for that AV slot (usually AV 1 or INPUT 1). Turn the nintendo back on and see if the picture comes through clearly - if it does, it means you had a bad RF switch and you can either get a new one, or just use AV cables instead!
One of the above problems IS the problem - I've repaired over 1000 NES systems and 95% of the time it's just a bad RF switch (so the AV cable test works best)
Jan 14, 2010 | Nintendo NES Console
When I play Halo 3 it turns green. and other games get blurry in background, I just bought Fable 2 and I cant play that because it is too blurry, its not a scratched disc, and I rmoved dust in my 360
you may have a faulty AV lead, from xbox to TV.
or the graphics chip is failing, if you have a composite lead ( red-white-yellow-green-blue ) check that the switch is set to hdmi correctly. this is on the side of the oval connector from xbox outlet to tv lead.
try tuning into a different tv channel, check that the lead isn,t broken internally.
If this does not work, assume that the GPU Or graphics chip has come loose, and obtain A RROD repair kit.
Mike @ Compurepair.
Jun 12, 2009 | Microsoft Xbox 360 Console
I have audio but no video...
Deflection Board resolder all Pinns on (FBT) Flyback Transfomer.
Nov 02, 2008 | RCA D52W23 52" HDTV CRT TV
No picture yet i can hear sound green effect before it happend
First thing would be to make sure that you're only using the yellow, red, and white cables, but seeing as how you said you had picture before, I'm guessing that's not the problem. The 360 uses an automatic recognition for the hardware to make sure that it is set to the right input. So, in essence, it won't be that the settings were changed. I would say go pick up a new cable and see if that's the problem, it sounds like it is. If the cable doesn't solve it then I would say it's time to call Microsoft. For the guest with nothing working, call up Microsoft, I really don't know what else the problem could be except for hardware.
Oct 04, 2008 | Microsoft Xbox 360 Console
HDTV problem
You should test the TV set using a known good source such as a DVD player with RGB outputs to drive the set. If it is good, then this rules out the TV set from being at fault.
From experience, many times I found compatiblity issues between computers and TV sets. The computer's resolution and refresh rate must be set exactly to the TV's capability.
Jerry G.
Jun 26, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Green tv picture
sounds like the lvds cable has glue on it (some did) the glue has to be removed or the lvds cable replaced
Oct 11, 2007 | Samsung LN-S4051D 40 in. LCD Television
Tv on with sound but no picture
my jvc tv has sound but no picture. Sometimes when I turn it off for a few minutes it has picture then it goes black
Aug 07, 2006 | JVC AV-27230 27" TV
Sony Playstation 3 (PS3) Console Logo
52 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
