Question about Dynex Multimedia Keyboard
Dynex Multimedia Keyboard not working
My computer has faulty keys. I plugged Dynex Multimedia Keyboard into windows xp computer's usb hub. nothing happens when i type.
  • 542 Answers
Check and install drivers for your multimedia keyboard which is came along with the Keyboard. Also check whether the USB drivers has been installed properly and check the status of the same.
Revert back for more assistance. Also give your valuabale feedback/rating on the same.
Posted on Feb 07, 2010
My computer will not restore with the F11 key
Unless referring to the old legacy keyboard that you have already mentioned
Assume the USB keyboard was purchased & supplied with the Vostro 200?
If correct then it will have a USB 2.0 cable connector
Do not connect USB keyboard using indirect adapters/hubs etc.
Ensure the USB keyboard is connected directly to one of the USB Root Hub ports, (e.g. one of the rear panel USB ports) before you power on the PC
Does tapping the F2 key during boot loading allow access to System Setup (BIOS) Settings?
Ctrl+F11 will not work if you have previously done an XP Clean Install or deleted/modified partitions
If keyboard is OK then you may have to do a Windows XP Clean Install
Also note that tried to do a system restore by going into Start--> All Programs --> Accessories --> Systems Tools --> System Restore t
OR
If it is there you will have to start the computer, press F8,choose "Repair Your Computer"
Aug 01, 2013 | HP Pavilion Slimline s3700f PC Desktop
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
Need Dynex DX-WKBD USB Wired Keyboard Driver
Drivers for keyboards can be found on this webpage: Driver Update Software for XP Vista 7 8. Every driver related problem can be solved too...
best of luck
Jason
Jul 16, 2010 | Dynex Multimedia Keyboard
When I plug in the usb for Dynex Keyboard, it doesn't work.
Sounds like you've got a bad keyboard.
You should contact Dynex direct for in-warranty replacement.
You can reach them here.
  • usflagicon.gif1-800-305-2204
May 25, 2010 | Dynex Multimedia Keyboard
Dell SK-8115 USB keyboard on non Dell PC
This model keyboard has an internal USB hub and Windows only sees the hub when booting. The solution is to get a generic USB keyboard and boot into Windows. Once Windows has loaded the HID drivers for the sk-8115 keyboard then this Dell keyboard will work from then on.
Jan 16, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Bought HP S20 New in box on Ebay......installed software......powered up and linked USB......message "communication with scanner lost" cannot rectify
I use an older USB Powered Hub between my computer and the S20 scanner, a Belkin I found at a garage sale for $2 works fine. It is only rated for USB 1.1. The S20 is a USB 1.1 device. My computer was "too fast" with its USB 2.0 ports and it looks like I needed to "slow it down". There is no way it will worked plugged directly into the computer, but plugged into the hub, and then the hub plugged into the computer, it is very reliable.
Windows XP had nothing to do with it, from what I can see. I had Windows XP on a previous computer with only USB 1.1, and ran into the problem when I got a computer with USB 2.0 ports.
Jan 03, 2009 | HP Photosmart s20 Film Scanner
USB HUB, Receiver & Keyboard
dude
Try to update windows xp service pack, i guess usb root hub drivers is missing, when you updated windows xp they will get fixed by itself
Dec 18, 2008 | Microsoft Windows XP Professional
Usb hub
here's the compatibility requirements:
Compatibility PC with Intel® Pentium® processor; Windows 98 SE, 2000, ME or XP;
Mac PowerPC processor; OS 8.6-9.x, 10.X and later
http://www.dynexproducts.com/pc-357-2-dynex-7-port-usb-20-hub.aspx
you might want to update your drivers to the latest version
http://www.dynexproducts.com/t-drivers.aspx
Oct 14, 2008 | Dynex Computers & Internet
Dynex Multimedia Keyboard Logo
951 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
