Question about Canon PIXMA iP6700D InkJet Photo Printer
Printer will not recognise Black ink cartridge
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
Why does my printer not recognise ink cartridges
there is a reset for that that comes with some carts or you can just order the reset mabye
Jul 25, 2014 | Cannon Office Equipment & Supplies
HP Deskjet 5940 won't recognise new black ink cartridge
Check to make sure that the contacts on the printhead carriage is clean.. Remove both cartridges. Unplug printer.Wait at least 3 minutes. Plug printer back in. Printer will turn on. Reinstall cartridges.
Dec 30, 2013 | HP Deskjet 5940 Photo InkJet Printer
I use 3rd party ink and why my color ink light up at my printer pixma mp 287
This will either be because your printer is having trouble recognising the cartridges or warning of low ink because the cartridges have been refilled. Connect a computer to the printer and it will hopefully give you more info.
If your printer cannot recognise the cartridges try wiping the contacts on the front of the cartridges and re-installing. If your printer still doesn't recognise the ink cartridges then sadly they will need replacing.
If it is just a low ink warning then carry on printing untill the printer thinks the cartridges are empty and prevents you from printing. You can them get around this message by pressing the stop/reset/resume button for 5 seconds and continue printing. More information on this can be found here: http://www.refreshcartridges.co.uk/igloo/the-infamous-canon-resumestopreset-button/
Hope this helps.
Feb 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
Black ink cartridge.
the printer only prints with all ink cartridge inside, back and color (use only original ink spares)
Dec 29, 2009 | Canon PIXMA iP1200 Photo Printer
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
Brpther DCP 330c does not recognise new black ink cartridge
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Jun 03, 2009 | Brother DCP-330C All-In-One InkJet Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
My epson r285 wont recognise compatable inks
My Epson R285 will not recognise compatible cartridges,mainly the black.I ran out of black ink and installed a compatible cartridge but it did not recognise it.To get the printer running I had to buy a genuine one which worked.I then ran out of all the other colours soon after and installed compatible ones which were accepted.I have now ran out of the black again but the printer will not accept the compatible cartridge.How can I solve this problem as the printer has accepted black compatibles before.
Thanks Padgy
Oct 09, 2008 | Office Equipment & Supplies
Does not recognise the smaller black ink cartridge
This machine is not meant to switch between the two black cartridges. The large one is used when you are using black only, and the small one is used when you are printing in color.
Jul 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA  iP6700D InkJet Photo Printer Logo
327 people viewed this question
old marine
old marine
