Question about Canon CanoScan 8600F Flatbed Scanner
How can you clean the glass on a Canon 8600F - Canon CanoScan 8600F Flatbed Scanner
Got this from Canon.com: The foggy haze on the glass is actually an anti-glare treatment that has been intentionally applied to the underside of the scanner glass. This treatment lessens the glare from the lamp under the glass and provides better image quality. This haze may not appear uniform because of the shape of the scanner base and the components under the glass. However, the anti-glare treatment has been uniformly applied and the haze is as expected.
Posted on Feb 22, 2010
Same problem here too, just posted this video on YouTube onhow to do it yourself. All you need is 10 min and a Philips screwdriver. Best of luck!http://www.youtube.com/watch?v=dAAB7dMbf-s&feature=youtu.be
Posted on Oct 23, 2011
2 Suggested Answers
SOURCE: when the lamp is on, a clouded area appears on the
To open the Canoscan 8600 to clean the inside of the glass: Gently pry off the silver "c-shaped" trim piece on the front of the scanner. Slide the silver trim pieces on each side of the scanner forward and remove them. Gently pry off the remaining black trim piece on the front of the unit. This exposes 3 phillips head screws at the front of the scanner. Remove them. Pull straight up on the rear lid of scanner (where the 2 hinges are) to remove the top. This exposes 2 screws at the bottoms of the wells that secure the hinges. Remove them. Now the top is held by only 2 clips - 1 on each side. Pull up gently on the left side of the panel, front and back, and slide the panel back towards the rear. That should free the clip. Repeat for the right side. Take it easy, and you won't break anything.
Posted on Dec 28, 2010
I have a CanoScan 8600F. When I want to scan I get the not enough space on the target disk
This seems to happen quite often with the Canon scanners. If you know you have enough space on your hard drive, open the CanoScan Toolbox, then click on Settings and change the folder where the temporary files are stored to another folder of your choice, or create a new one in your documents.
Dec 06, 2010 | Canon CanoScan 8600F Flatbed Scanner
Re: Canon 8600f scanner. How do I get this to file in jpg rather than pdf? How do I control scanned picture size? I get a full page (8.5" x 11.0") with a real size scan on top. Peter
My cannon 8600F was ori=ginally connected to my old laptop & I could scan any document and save as a jpeg file. This was with Windows XP Prof.
Mow my new laptop has Windows 7 & I downloaded Primo from the web. But now I am not able to scan a picture and save as Jpeg file.
Please help.
Aug 07, 2010 | Canon CanoScan 8600F Flatbed Scanner
When the lamp is on, a clouded area appears on the underside of the glass platen. How can I clean it - or is this necessary? I believe I left the power on for a long period - did this burn the...
Jun 21, 2010 | Canon CanoScan 8600F Flatbed Scanner
I have a Canoscan 8600F that hasn't been used for a while. Now that I want to use it but somehow cannot find the software on my computer (accidental deleted?). was able to download the driver but still...
Sorry, but I have been doing this for many, many years and sometimes... the scanner doesn't work anymore when you lose the disk. I did say sometimes. The HP I have is just like that.
May 11, 2010 | Canon CanoScan 8600F Flatbed Scanner
Fog build up on underside of glass plate.
I made contact with cannon and received this reply. I was satisfied with the answer but the question still remained on how to remove the glass should i wish to do so. Also after there answer... would there then be a problem if i did clean the reverse side. Their answer was initialy this...
expected.  The treatment should not affect the scan quality or output of
the 8600F.
Jan 04, 2009 | Canon CanoScan 8600F Flatbed Scanner
Lost setup CD
go to the canon website. There you find all the drivers and setup programs that were on the disk for download.
I did the search for you. Go to this link:
CanoScan 8600F support
Select your operating system and you will see download links appear.
Cheers
Critter
Dec 26, 2008 | Canon CanoScan 8600F Flatbed Scanner
CanoScan 8600F
Download the Scanner Driver here for Vista
http://driverscollection.com/?H=CanoScan%208600F&By=Canon
Click Windows Vista and then Download the right choice one for you.
If your don't know if your Vista is either 32-bit or or 64-bit download the second one which will work for either of the 2.
Good luck
Jun 18, 2008 | Canon CanoScan 8600F Flatbed Scanner
Canon CanoScan  8600F Flatbed Scanner Logo
1,153 people viewed this question
old marine
old marine
