Question about Brother DCP 115C All-In-One InkJet Printer
The printer is not printing although i already changed the ink and the cleaning was done. My printer's brand is MFC. please help
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
NO BLACK INK COMING THROUGH ALTHOUGH I HAVE CHANGED THE CARTRIDGE TWICE
It needs a new print head. Brothers are notorious for this issue. Especially if you are using generic ink and not Brother branded.
Nov 03, 2010 | Brother MFC-620CN All-In-One InkJet...
Printer would recognize black ink i have replace the in three times with brand new cartridges any idea what to do
Sounds like your new cartridges are not being recognized, correct?
If not done already please ensure each cartridge has any plastic packing strips (usually with a colored tab) off the outside of the cartridge. Vendors use these to cover the contacts and/or the print heads for shipping and can be tricky to see.
Otherwise please ensure no ink has spilled or leaked into the slot where your printer cartridge goes. Use good computer cleaning swabs or wipes to remove any ink spill or dirt there. Gold contacts should be clean. Good cleaning wipes or swabs will let you remove dirt and ink but not leave fuzz or strands of cloth in printer. At this time you can also ensure no paper or labels etc are left inside covering gold contacts.
Oct 21, 2009 | Brother MFC 420CN All-In-One InkJet...
Still not printing - HELP!
Not sure whether this applies to your exact siuation but may be worth a try:
Brother MFCs self clean excessively and when they've done a set number of self-cleans, they refuse to print and give an error message which leads you (unsuccessfully) to the Troubleshooting section.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Sep 15, 2009 | Brother MFC 210C All-In-One InkJet Printer
Wrong ink in slot
my brother mfc 6490 has stopped printing yellow, i've done number cleans and changed cartridges with no luck. has anyone out there got a fix for this?
Sep 13, 2009 | Brother MFC 6490CW InkJet Printer
"No Black Ink Cartridge" after a new cartridge has been inserted
It sounds like the actual ink sensor has failed. You can check if it has a print head cleaning routine in the software on the computer. Most likely the actual ink sensor has died though, I've seen this many times. Call Brother to confirm, or maybe if it's still under any kind of warranty: 877-276-8437
Aug 08, 2009 | Brother MFC 240C All-In-One InkJet Printer
My printer wont print even after changing ink and cleaning
When cleaning doesn't help, you need a new printhead. Around $89.00 now and then you add labor. They sell a new MFC 490 for around $120.00 with a year warranty.
Jul 01, 2009 | Brother MFC-3240C All-In-One InkJet...
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
Brother 5440 mfc printer
1. Make sure the cartriges are name brand
2. make sure that you are placing each ink in the right slot.
3. Unplug it and press and hold the power button for like 20 seconds
4. plug it back in let it go though it's cycle,
5. try test page
Hope these tips work, if not please write back before rating me
Mitch
P.S. Don't forget to leave feedback
Apr 14, 2008 | Brother MFC-5440CN All-In-One InkJet...
Help
Hi, Unfortunately, this is caused by the printer head. It will gradually stop working. However, some things to try is to clean the print head. This is literally opening the printer and cleaning the head. Also, avoid using refill ink cartridges as they damage the print head a lot quicker. Get brand new cartridge if you are using refills. If this still doesn't help, then the print head have already been damaged and need to be replaced. By the way, if this printer is still under warranty, brother should replace either the printer or the print head for you free of cost.
May 16, 2007 | Brother MFC 4820c All-In-One InkJet...
Brother DCP 115C All-In-One InkJet Printer Logo
249 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
