Question about Toshiba Satellite Laptop
Video card.... what that means Minimum Graphics Memory: 128 MB Maximum Graphics Memory: 1341 MB can increase one to stop working on 128 MB .. My configuration ...................................... Windows 7 Ultimate DirectX * Version: 10.0 Physical Memory : 2939 MB Minimum Graphics Memory: 128 MB Maximum Graphics Memory: 1341 MB Graphics Memory in Use: 27 MB Accelerator in Use: Mobile Intel (R) 4 Series Express Chipset Family Video BIOS: 1625.0 Current Graphics Mode: 1280 by 800
  • 457 Answers
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Posted on Feb 07, 2010
Testimonial: "ms"
Will a Samsung 256MB DDR PC2700 CL2.5 184 PIN work
No that memory is not compatible. The Precision 350 uses memory called RDRAM aka RAMBUS.
Here are the speeds and sizes that are supported.
Memory modules supported PC800-40: 64-, 128-, 256-, 512-MB, non-ECC or ECC
PC1066-32P: 128-, 256-, 512-MB, ECC and 64-, 128-
,256-,512-MB, non-ECC
Minimum memory PC800-40: 128 MB non-ECC and ECC
PC1066-32P: 128 MB non-ECC and 256 MB ECC
Maximum memory PC800-40: 2 GB non-ECC and ECC
PC1066-32P: 1.5 GB non-ECC and ECC
Sep 27, 2014 | Computers & Internet
My current video memory is 119 but max is 762. how do i increase it to max
If you are using a laptop the video card probably uses what is called shared memory for the Graphics Processor. Which means it pulls RAM from the system and uses for processing graphics. Typically the computer controls how much RAM to dedicate to the Graphics Processor. More RAM is always good. I would check in my BIOS. Sometimes they put RAM allotment for the GPU there. If they advertised that you can get a total of 762MB out of your GPU then it wouldn't surprise me. Just remember the more you dedicate to your GPU the less you have for your system.
Jan 18, 2013 | Computers & Internet
Increase graphics from 96 to 128
If you have insralled the correct video driver and you cannot increase the VIDEO RAM then it is not possible to increase the bit color from 96 bit to 126 or 256 bit color.
The only way to have a higher bit color is to install a new graphics card that supports up to 256 bit color (this video card will have large cideo RAM).
Mar 09, 2012 | Intel Desktop Board D865GVHZL Mainboard -...
I have acer 5745 model which is with intel HD graphics.When I go to graphics properties it shows minimum graphics memory of about 128 MB and maximum graphics memory 1051 MB. So,my question is does acer...
You may be able to increase the video RAM in the BIOS configuration.
The laptop's built-in video card most likely uses shared RAM, it uses part of the main RAM models and the more you grab for the video RAM the less main memory is available, You may need to install more RAM to make the laptop run better.
Feb 02, 2011 | Computers & Internet
Computer runs slow on some games HELP!!!!
In order to play RollerCoaster Tycoon® 3, you will need a PC running Windows with the following minimum requirements.
Minimum and recommended computer specifications are as follows:
Operating System: Windows® 98/Me/2000/XP (Windows® XP recommended)
Processor: Pentium® III 733 MHz or compatible (Pentium® 4 1.2 GHz or compatible recommended)
Memory: 128 MB RAM; 256 MB for XP (256 MB; 384 MB for XP recommended)
Hard Disk Space: 600 MB free CD-ROM Drive: 4X CD-ROM or faster (8X or faster recommended)
Video: Any ATI Radeon™ or GeForce™ 2 with 32MB or higher; or other video card with 32MB and hardware T&L (ATI Radeon™ 64 MB SDR or GeForce™ 2 Pro or other video card with 64 MB or more memory and hardware T&L recommended)*
Sound: Windows® 98/Me/2000/XP-compatible 16-bit sound card*
DirectX®: DirectX® version 9 (included) or higher
Apr 06, 2010 | Computers & Internet
Cannot install manufacturer driver
does the card support 64 bit windows ? their are a lot of issue using 64 bit windows
Mar 24, 2009 | Chaintech XGI Volari V3, (128 MB) Graphic...
Does my inspiron b130 laptop support s video output to my tv?
No. INSB130 does not support S-Video. Here's the complete specs of your system:
Processor type Intel® Pentium® M and Celeron® M
External bus frequency (front side bus) 400 MHz or 533 MHz
System chipset Intel 910GML Alviso
Data bus width 64 bits DRAM bus width Dual-channel (2) 64-bit busses Flash EPROM 512 KB Graphics bus Internal PCI bus 32 bits ExpressCard controller ICH6M ExpressCard connector One ExpressCard slot 54 mm Cards supported ExpressCard/34 (34 mm)
Expresscard/54 (54 mm)
1.5v and 3.3v Memory module connectors Two user-accessible SODIMM connectors Memory module capacities 256 MB, 512 MB, and 1 GB each Memory type 2.8-V SODIMM DDR-2 Minimum memory 256 MB Maximum memory 2048 MB Ports and Connectors :
Audio Microphone connector, stereo headphones/speakers connector
Mini PCI Type IIIA Mini PCI card slot
Modem RJ-11 port
Network adapter RJ-45 port
USB Three 4-pin USB 2.0-compliant connectors
Video 15-hole connector
Network adapter 10/100 Ethernet LAN on system board Wireless Internal Mini PCI Wi-Fi® wireless technology support
Video Type Integrated on system board
Video controller Intel Integrated Graphics Media Accelerator 900
Video memory Up to 64 MB of shared memory (when less than 512 MB system memory is installed)
Up to 128 MB of shared memory (when more than 512 MB system memory is installed)
If this is helpful, please rate it.
Dec 05, 2008 | Dell Inspiron B130 Notebook
Upgrade laptop
Hi
Only you can upgrade laptop ram and hdd. You cannot upgrade your graphic card, try to upgrade your ram it will improve speed....
Apr 01, 2008 | HP Pavilion dv6000z Notebook
New graphic card
ya go for it it will may lower card specks if u have any limitations but your ok agp 8x 4x slot
Jan 24, 2008 | Computers & Internet
Toshiba Satellite Laptop Logo
363 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
