Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Horbart dishwaser wont dran
Can some one help me it is under the counter its used for glass only about 6 years ald no m# or s#
  • RCKENG May 31, 2008
    Our dishwasher fills but does not drain. It's making a humming sound coming from the gadget to the right of the pump. Does anyone know what that humming gadget is? Does anyone know if the gadget in question is for draining?
    I tried to find a parts manual on the Hobart web page but no dishwasher section or model number exists . I have a ML-130017 LXiH Hobart dishwasher.
  • 640 Answers
Its a hobart correct?The data plate is on the bottom right front or on the door when opened on the left.If you dont see it then its been removed.Regardless does the display show a wash then rinse cycle?If so and it doesnt drain you either have a clogged drain hose or the drain valve is bad or stuck.If you use this just to wash glasses your model is probably a lxigc.If glasses are broken in the dishwasher which they probably are the glass has gotten into the drain body and is obstructing the valve from opening and closing.I work for hobart and services dishwashers alot.let me know.
Posted on Feb 23, 2008
The blue light and a red light under the glasses and plates signal is flashing and my dishwaser won't start.
does the door lock ?? if not try leaning against it when pressing the start button
Jan 21, 2015 | De Dietrich Dishwashers
How do I lift out built-in KitchenAid glass cooktop KECT 365 when mounting brackets wern't used
You are either:
A) missing the mounting screws and brackets that hold the unit in place
B) it is stuck and will require brute force to remove
C) both
Dec 30, 2013 | KitchenAid Cooktops
Locating dran plug for radiator
Year model? Which engine? Inline 6 4.0L?
Oct 06, 2011 | Cooling System for Jeep Cherokee Sport
Rubber nose piece has split - barely hanging on
Hi.
The part (or the glasses) must be replaced. Cheap repair done with superglue is not a good solution. Please contact Nike customer support using the link below:
Athletic Sport Sunglasses & Technology ' Nike
Mar 27, 2011 | Nike Counter Sunglasses
Magic chef dishwaser (old). White film on glassware after wash. The washer only takes powder. I use cascade. use
Try running a white vinegar wash. Add 1 cup to the unit and run a normal cycle. Also rinse agent must be used to achieve spotless glass. Water hardness can affect this as well.
Appliance & Refrigerator Repair How To
Mar 23, 2011 | Dishwashers
After a wash cycle my unit leaves a film on my glass'
first thing you need to do is purchase a bottle of dishwaser cleaner from your groc store in the diswasher detergent section red the instructions on the label add it to the cutlery tray in an empty dishwasher upside down remove the paper seal off the top of the lid do not remove the wax seal place the bottle upside down in your dishwasher turn on hot water tap and run till it is hot next turn on your washer set it to wasn and let it run a full cycle. when washer finishes open it up when it cools and fill rinse dispenser in door with a good quality rinse agent like jet dry close dispenser and when dishwaser is full of dirty dishes turn it on the jet dry will make your galsses come out crystal clear w no film and the dishwaher cleaner will help all your dishes come cleaner.Use the dishwasher cleaner aroun 4-6 wekks it cleans all the inside of the dishwasher and removes a lot of **** aND RESIDUE THAT ACCUMULATES IN DISHWASHERS OVER TIME
Dec 17, 2009 | Dishwashers
Loose/broken seel on inner door glass of oven
Yes it is still avalible I looked it up and there is one in Texas here is the number to order. Genuine Parts & Accessories (800) 935-0062 please rate if this helped.
Aug 07, 2009 | Whirlpool GBS307PR Electric Single Oven
Glass shelve on bottom over grisper is broken Sanyo SR-9510W
You didn't say what size or model Sanyo you have, but the solution is easy. I have a Sanyo under the counter refrigerator in which the glass over the crisper is 1/8" thick frosted glass, 16" by 6 3/4" with the two back corners cut off diagonally. The frosting is simply to prevent you seeing through into the crisper below. It is maybe fifteen minutes work with a piece of window glass and a glass cutter to make a replacement. My full size refrigerator uses 1/4" glass since it is much larger and I have replaced it myself this way. If you don't have a glass cutter -- they are cheap and available in all harware stores -- you should be able to get any hardware store to make the cuts for you. They are accustomed to making custom cuts for people replacing their own windows. The have, and I use, what is known as an oil cutter which is a lot easier to use than the little hardened steel wheel cutters you will get if you buy a cheap one. Those work fine for straight cuts. Oil cutters make curver cuts equally easy to do.
Dec 07, 2008 | Sanyo SR-9510W Refrigerator
Soapy water stains under sealed glass cooktop 4 rround burners about 6 years old
You should never use large amounts of water on any electrical appliance. If the moisture is under the glass, it will need to be replaced.
always unplug electricity before attempting to repair on any electrical appliance
Sep 08, 2017 | Cooktops
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
213 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
