Question about Karcher Hose Reel
Can thee hose be fixed if it has a leak.
Can the hose be fixed if it has a leak.The hose sprung a leak today in the middle of the hose.
    Scholar:
  • 114 Answers
If the leak is on the OUTBOUND side that is towards the Nozzle, it CAN be repaired but for safety I would strongly recommend a new hose. Main reason being that the pressure generated in that hose will blow MOST joints you put in there.
If it is the input side then just get a hose joiner and install it.
Posted on Feb 07, 2010
Car over heating and hoses springing leaks
Replace the radiator cap first (when it's cool and it's cheap). A coolig system needs pressure.
Next option is the thermostat. It is normally closed and will open at 180degrees (newer cars have higher temps). You can test by removing and then using your house stove and a pot of water see if the spring & valve open up as it gets near boiling. They are not very expensive either so it might be easier just to replace it as well. Make sure you run the heater at full to help get air out of the system.
If you check the oil and it looks high and weird then you could have a blown head gasket. This is much more $$$ to get fixed.
Mar 08, 2014 | 1989 Cadillac Sedan DeVille
Coolant leak at firewall (outside) on 1991 4.9 F150. Comes out at the bottom of the housing mounted to the firewall.
If hoses seem Ok and the clap is tight it may be the Heater Core has sprung a leak, although is leaking outside maybe the line where the hose attaches has a leak.
Oct 29, 2013 | 1991 Ford F150
I have a 2003 Impala. It hasnt rained for a few weeks and a leak has sprung by the glove box near the passenger side. I looked online and alot of sites said it might be the window not sealed correctly but...
There is a drain tube that clogs up. It is on the firewall under the hood on the passenger side. You have to access it from under the car. Use a stiff wire and clean it out. Sometimes you can clean it with a water hose and sprayer. Just don't put a lot of water in it. Spray a little, let it drain, Do this till you don't see any mold coming out. If it clears out and you still have water issues. Replace the heater core.
Nov 07, 2011 | 2003 Chevrolet Impala
1998 Dodge Durango heater hose
The metal section is part of the water pump. You can just replace the rubber section of hose.
Nov 01, 2011 | Cars & Trucks
Water is leaking from bottom of unit, getting worse everyday
Probably the hosse from the boiler inside the unit. Mine has sprung a leak too and on opening up the top of the unit the hose had sprung a leak within an inch of the steamer line it is connected to. Trouble is getting the hose. I cant find one in Canada where i am, but there is availability at http://www.shop.partsguru.com/16000190-Silicone-hose-each-High-temp-braided-16000190.htm Trouble is how long before the problem redevelops? I tried another hose, but it got way too hot that i didnt trust it and you could see a steam bubble sitting right where the original hose leaked, so it makes me think that is why the original hose leaked.
Dec 09, 2010 | Saeco Starbucks Sirena Espresso Machine
Some kind of oily coating inside of truck on windshield, 1994 gmc sierra stepup style, where are the air conditioner hoses? is it hard to fix this leak?
Sounds like the evaporator core has sprung a leak. On a scale of 1 to 10 this one has a 6 rating on difficulty.
Jul 31, 2010 | 1994 GMC Sierra
No power steering and smoking from hood
[1]the power steering pump might have siezed up causing the belt to slip to burn on the pulley. [2]or the pump broke the shaft internally and some fluid is leaking out and hitting the exaust[3] a hose has sprung a leak and it is spaying oil on the exaust manifold
Mar 22, 2010 | 1995 Jeep Grand Cherokee
I have a 1989 Nissan Maxima and water is leaking somewhere into the car my floor is always wet...wat do i do?
It sounds like the heater has sprung a leak. As a temporary fix you could completely take off one of the hoses leading to the heater. Then disconnect the other hose from the heater, take that end and connect it to where you disconnected the other end of the other hose (probably on or near the water pump or the radiator). That would leave no water going to the heater.
Nov 22, 2009 | 1989 Nissan Maxima
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
Karcher Hose Reel Logo
461 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
