I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light inside the Furnace flashes continuously after 2 attempts with the ignitor.
  • 1,420 Answers
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Posted on Feb 07, 2010
I have trane xe 70 furnace will not ignite. it clicks and you can smell the gas
Posted on Jan 27, 2015
  • Heating & Co... Master
  • 2,517 Answers
Hi it sounds like the pressure switch jump it out and seif it lights also clean the air filter an dclean the fan control could be dusty
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
Trane xe 70 cycles through the gas release cycle but fails to ignite the burners, upon inspection it appears that the igniter isnt glowing
Either the circuit to the electronic ignitor is bad or the ignitor (electrode) itself has failed. Either are not difficult to replace, but you will need a circuit tester to troubleshoot which part(s) needs replacing.
Mar 27, 2011 | Heating & Cooling
When turning on heat after a period of using air
It sounds like the fan limiter switch is going bad. This switch waits until the air temp is high enough for heating the house before allowing the fan/blower to come on. There is another switch that shuts off the blower when the air drops to a certain temp, or it may be the same switch that does both jobs. Hope this helps.
May 09, 2010 | Omega Trane Furnace Draft Inducer Blower...
It's not lighting it's not working I see motor is running and I think gas coming out but it's not lighting I turn off the funance
Turn the power off to the furnace, turn the thermostat to the highest heat setting then turn the power on. The fan may start for a brief period, then the combustion blower will start, after approx 90 seconds, the ignitor will light and heat up. You should be able to see a glowing in the burner lens. If you do not see a red glowing, similiar to a car lighter, that would indicate the ignitor may have failed. If after 3 attempts, the systems fails to light, there is a light on the circuit board that will flash, the number of flashes will indicate the reason for the fault.
Nov 13, 2009 | Goodman GMS90703BXA Heater
Electric furnace. Just replaced the controller board but no heat. The blower does come on when the thermostat gives the heat command and I was wondering if that means the relays to the furnace coils is...
On a Trane furnace the fan realy must energize before the electric strips will come on. On the thermastat. See if there is setting for electric heat. This will bring the fan on and the strips should come on. First just turn on your heat and and turn fan to on postion if it works you need to set tstat to electric heat mode. Most of the time there is sswitch in the back of the stat that says gas elec. Turn to electric. Rus
Oct 29, 2009 | Heating & Cooling
Igniter is glowing and heat is building up in the oven but no fan
Turn the gas supply valve off to the oven.
Remove the oven racks and base to access the burner and igniter. Place a clamp on amp meter on one wire of the ignitor.
Turn the oven control on and let the ignitor heat up. If the amp draw is less than 3.0 amps,replace the ignitor.
Oct 28, 2009 | Tappan TGF657 Gas Kitchen Range
Trane xe 1200, can i use the heat blower with out a working compressor, i need heat not air, thanks
you can switch the thermostat to "emergency heat" which will turn the outdoor section off and the thermostat will control the electric heat elements in the air handler if it has them.
Oct 19, 2009 | Omega Trane Furnace Draft Inducer Blower ...
I get 4 blinks it say open limit switch what does that mean
Your induce fan motor senor is out. The little fan motor that take out the heat has a sensor that tells the furnace thats its working. Some time it get stuck. Try blowing and sucking into the tube. you should hear a click
www.fastacservice.com
Oct 16, 2009 | Goodman GMS90703BXA Heater
Goodman forced air gas furnace not firing
if your power vent moter is not running you should not have have glowing ignitor.Frist the vent moter must close an air prove switch in series with the idnitor .seems you have a stuck air prove switch.Its the one with a hose attached
Apr 04, 2009 | Heating & Cooling
Goodman furnace
Check the roll out switch(s) and the lock out switches. They are a small disc looking about the size of a nickle, with with 2 wires attached on them. There will be a re-set button in the middle that resembles a small peg. Push this in to re-set. As the glow coil shorted out, the fuse on the control board may have blown. On the newer furnaces find the main board and look for a car type fuse. If blown, replace. You also have the symptoms of a bad limit switch, by the clicking noise (the heat fan relay) and the blower fan running instantlly.
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
989 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
