Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Our Bonaire Evap Cooler stopped after power failure
Our Bonaire Evap Cooler stopped working after power shortage. We reset the codes and now both controls are for our heating and no control runs for the cooling. Does anyone have any idea. Please
You need to turn off power supply to unit that works ok and leave other unit switched on and code it and test it then switch other unit back on
Posted on Jan 30, 2012
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Posted on Feb 09, 2010
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
I have a bonaire evap system cant get it to come on have changed batteries and reset it still nothing happens the remote is called bonaire comfort control have recently brought the house and cant find an...
Remotes are a pain. Can you get into the unit to see the control box? You need to see if the unit has power. If its new enough it will have some diognostic lights so you can see if it has power. Without that its hard to diognose. Unit Model number is also helpfull. if it looks like the one on this picture it will be etched into a badge on one of the corner pillars. if its a plastic unit it will be on a sticker inside the unit
Feb 24, 2011 | Mastercool 67471 Evaporative Cooler Air...
Our bonaire evaporative unit will not switch on. l rang customer service and they advised l reset the unit as we recently changed the batteries l did the reset but the unit still does not work and after...
try reset the controller. turn off power to the unit then remove batteries from controler. press the power button on the controller to remove residual power. turn on the unit then install batteries. turn on controller within 4 minutes of turning on unit
Nov 23, 2010 | Mastercool 67471 Evaporative Cooler Air...
Will not turn on after a blackout
Turn off your breakers and then back on. There are fuses located in the a/c control panel. Check them. If you aren't getting any power still, a board may have been blown during the storm.
Jan 30, 2009 | Mastercool 67471 Evaporative Cooler Air...
Bonaire Cooling system that stopped working after power failure..
Unplug the unit or turn off the breaker to the unit for at least 30 seconds. If this reset does not work, the electronics may be damaged and need a repair person.
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Jan 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
1,570 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
