Question about HP Pavilion dv4000 Notebook
I spilled soda on my key board not a lot i cleaned it off and turned off the comp for a few hrs will my comp be ok
I spilled soda on my comp i cleaned it off my keys and turned my comp off if it was damaged would i be seeing problems by now
  • 28 Answers
Yes, you would notice the problems immediately. The problems that would occur would be hardware short circuiting.
Posted on Feb 21, 2008
I spilled soda on my Macbook Air yesterday. Today, two of the buttons are jammed together. What do to? Help!
You have to be gentle but you can use a tech sized screwdriver and pull the key off. From there you can clean if up a bit more thoroughly.
Feb 28, 2015 | Apple MacBook Air
How to take apart canon pixma 432. Spilled soda in it, need to clean inside.
Hi Daniel,
Let me say, up front, that I am not a printer guru. My background is in biomedical electronics, but this procedure works in most applications. Take distilled water and pour a small amount into the area where the soda was spilled. Wait a few minutes to allow the water to dissolve the dried soda. Then pour in more distilled water to flush out the residual soda. Allow to dry. The water should rinse out the soda, and when it dries it will leave no contaminates of its own. This procedure works well on medical devices such as telemetry transmitters and cell phones that have been spilled on. I hope this helps. Thanks for asking Fixya. Dan
Dec 04, 2014 | Office Equipment & Supplies
Keyboard dont type
No matter how careful you may be, knocking a cup of coffee or spilling a glass of soda over your keyboard may happen. This does not, however, mean the end of your keyboard. If you act quickly, you may be able to fix your wet keyboard to avoid any corrosion of its electronic components or any short circuit which might render it unusable. By following a few recommendations, you should be able to fix your wet computer keyboard.
Unplug the keyboard from your computer immediately after the spill to avoid any corrosion or short circuit. If you spilled water over your laptop's keyboard, turn your computer off by clicking on "Shut Down" on "Turn Off" in the start menu, unplug the power supply and remove the battery. Turn the keyboard upside down and shake it to remove most of the water from it. Take a hair dryer and set it to its lowest temperature setting. Use it to dry any water which might remain under your keyboard's keys. Wait at least 12 hours before plugging your keyboard into your computer again. If your computer is a laptop, wait 12 hours before turning it on again. For Other Liquids Disconnect the keyboard from your computer immediately after the spill to avoid any short circuit or corrosion. Turn your computer off by selecting "Shut Down" or "Turn Off" in the start menu, remove the battery and disconnect the power supply. Place paper towels on a table, turn the keyboard upside down and shake it over them to allow most of the liquid to fall down. Take a few clean paper towels and wipe the liquid off your keyboard's keys. To clean between the keys, you can also use cotton swabs with just a little bit of water. If the liquid which you spilled over your keyboard contained a high amount of sugar, such as soda or sugared coffee, you might have to remove some of your keyboard's keys to clean the surface under the keys with paper towels or swabs. You can do so by lifting them gently with a screwdriver or by using a key remover, which you can find in some IT stores. Wait at least 12 hours before using your keyboard again. If your computer is a laptop, wait the same length of time before turning it on again. How to Clean Your Keyboard http://www.tucows.com/article/684 Fix Computer Keyboard Problems http://technologyandinternet.blogspot.com/2007/10/fix-computer-keyboard-problems.html
Apr 20, 2013 | E-Machines eMachines Desktop PC
Is there anything to do for when soda pop gets in camera and it doesn't work
Its depend on the quantity of the soda or drink spilled on the camera you are using. Use the blower to dry the liquid and do not use it at least 10 to 12 hrs. Allow more time to drying.
Feb 20, 2012 | Nikon Cameras
Spilled soda on toshiba laptop m505, keyboard is not working. keys don't stick anymore but not working. what do you recommend to fix it?
You need a new keyboard. The sugar in the soda caused the damage and will further corrode the keyboard.
I would also recommend that you clean the area where the soda may have spilled to on the system board.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 14, 2011 | Toshiba Satellite A135-S4527 Notebook
Inigition will not turn in park. bang on shifter to turn key and start car. 2000 grand am automatic
sounds like the shifter lock seliniod is sticking or going bad,you can try to open shifter area and clean and lube linkages,lots of time coffe or soda spills and make the linkage stick,
Apr 19, 2010 | 2000 Pontiac Grand Am GT
After spilling soda on my laptop it turns on and works fine for 1 hour, then screen goes black. I cleaned keyboard fine. Problem is there always. I have to wait for laptop to cool down(fans work fine),...
A soda spill will do this every time. As the Notebook recovers I doubt that the inverter board as gone. But the suger from the soda could be melting and causing a short. The only real solution is to completely dismantle the notebook and clean it with white spirit or similar. It will help if you can download disassembly instructions first! PS Try not to use it for too long without cleaning it.
Oct 29, 2009 | A.B.S . ABS MAYHEM G3 Eclipse R70 NoteBook...
Sharp calculator
I had the same problem happen to me. What I did was carefully take the calculator apart using a T-10 Torx screwdriver to remove the back cover. I then used a compressed air can and blew air into all the crevices and holes in the calculator. I was able to dry almost all of the soda the spilled, however some of the soda dried and turned into somewhat of a sticky mess. I was able to carefully wipe the sticky parts clean with a tissue. After doing all of that my calculator worked perfect.
Nov 15, 2008 | Texas Instruments TI-84 Plus Silver...
I NEED HELP
you pretty much wiped out the mother board you can take to the repair shop and they might be able to clean the soda residue out but soda contains sugar and when heated turns to carmel and fry the circuts
Aug 02, 2008 | Toshiba PSAFGU-058002 Notebook
Spill drink on Razor V3/
try cleaning the cell completed overhall check battery if it ok you can have it service before buying parts for the cell ask to have it service if other problems you can way the cost of relpacement
Aug 10, 2007 | Motorola Mobility RAZR V3c Cellular Phone
HP Pavilion dv4000 Notebook Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
