Question about Logitech X-540 Computer Speakers
Speaker extensions I have the x540 computer speaker system, cant seem to find extension wire adaptors for the rear spakers, what size do I need, where can I find them?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Http://techgage.com/article/logitech_x-540_51_speakers/ has a great review of the components. Radio Shack could also tell you what you need. Avoid asking biggies like Best Buy or Circuit city, as their "little things" like extension wires are extraordinarily overpriced, compared to Target or Walmart.
Posted on Mar 02, 2008
I need extensions for the ADA745 rear speakers
Standard RCA extension cables should work.
May 02, 2014 | Dell ADA745 Computer Speakers
I have a 2003 Toyota Tarago GLi. I am trying to find out what size the factory speakers are (6 speaker system) and can't seem to get this information. It is not in the manual & cannot find any...
Try going to www.crutchfield.com they have an extensive library of vehicles to outfit. It tells you replacement sizes for the locations you are requesting. You can also get all the items you would need for a good install. Hope this hleps
Aug 31, 2011 | Car Audio & Video
I want to extend my speaker cables, how should i connect them
The ideal solution would be to swap out the entire cable for a longer one unless you have to...
It sounds like this isn't an option, so your next best choice is to get some extension speaker cable and cable crimp-on connectors or Wire cable connector blocks (see ebay URL with picture below ) from the wiring department at Radio Shack, Home Depot or your local hardware store. The crimp connectors are generally rubber shielded metal tubes that you insert the wires from the speaker and the extension speaker wire. You then squeeze the crimp-on connector with pliers to secure the wires in place.
IMPORTANT...During extension make sure the polarity (+ -) marekd with different color will continue from existing speaker cable.Otherwise you will loose the LOW NOTES -BASS
If you don't have any extra speaker wire on hand, you can pick some up at a reasonable price at Radio Shack or any hardware store. While there are many theories about what gauge speaker cable are best, you're likely starting with fairly thin wire coming from the back of the RCA home theater system, so crimping on a heavy gauge wire will do little to improve your signal quality. 18-guage speaker wire will likely do the trick in most cases. I would likely recommend a different solution if this were a component-based system with individually powered amps, but for an all-in-one system, 18-guage wire will be sufficient.
Crimp-on **** connectors come in a variety of sizes. Make sure the size you choose is appropriate for the wire you use to extend the length of your speaker cabling run. Here again, Radio Shack and the local hardware stores will sell the connectors you need for most of the common wire gauges.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://cgi.ebay.co.uk/SPEAKER-WIRE-CABLE-CONNECTOR-BLOCKS-EXTENSION-/280672581841
Jul 11, 2011 | Panasonic Home Theater System System
2002 hyundai elantra factory stereo wiring colors
2002 Hyundai Elantra Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Red
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Pink
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Gray/Orange
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Wire (+): White
Left Front Speaker Wire (-): Brown
Right Front Speaker Wire (+): Green
Right Front Speaker Wire (-): Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Wire (+): Yellow
Left Rear Speaker Wire (-): Black
Right Rear Speaker Wire (+): Orange
Right Rear Speaker Wire (-): Blue
Jan 25, 2010 | Car Audio & Video
Vt Holden Commodore stereo wiring diagram
head down to your local auto store and you will be able to pick up a wiring harness adaptor. you wire your stereo to this adaptor then you simply plug it into the wiring loom. no damage to the loom so if you ever need to reinstall the standard stereo its just an unplug and plug back in. its extremely simple and colour coded so there are no mistakes.
May 02, 2009 | GMC Jimmy Cars & Trucks
Need longer ribbon speaker wire for Acoustimass 16
I have the same question. I just called Bose at 1-877-210-3782 (prompt 6) and they have two solutions:
1. 20 foot Input extension - $25
2. Input adaptor - $12 (you can run your own speaker cable to the input adaptor)
Apr 10, 2009 | Bose Acoustimass 16 System
Logitech X540 PC speakers, rear speakers only working; LAPTOP
Goodday remmember that you have to have a 5.1 sound card to be able to use a 5.1 sorround sound system.the 5.1 has more plug inputs to plug all the speaker FRONT REAR and SUB.
Jan 03, 2009 | Logitech X-540 Computer Speakers
Extension speaker wire
Radio Shack is you're best bet. They have several different types of speaker wire. That is where I get most of my audio and video supplies.
Aug 25, 2008 | Panasonic Home Theater System System
Wired remote cable extension
Most monitor cables have only 14 of the pins connected, but if you get a fully wired svga extention cable it does work fine.
Steve
Mar 23, 2008 | Logitech Z-2300 Computer Speakers
Logitech X-540 Computer Speakers Logo
183 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
