Question about Cell Phones
When i use camera. display the message (please slide up)
Poor quality conversion from slides to digital
Specify the format : .JPG or whatever it is.. please try to be specific.. SD Card is not a format.. its a storage media..slides as well is not a format.. its a terms..
Dec 19, 2013 | Wolverine Data F2D200 Film Scanner (35 mm)
SD memory card is locked. How do I unlock it?
SD and Mini SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Jan 20, 2013 | Sony Alpha DSLR-A290L Digital Camera
Protect on display
Since you didn't specify the make and model of your camera or the full text of the message, I'm going to make some guesses.
I assume it's a camera that uses SD cards saying that the card is protected. If I'm right, take a look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If I'm wrong, please reply to this post, specifying the make and model of your camera and the full text of the message.
Jan 12, 2013 | Cameras
Sanyo VPC-T700 Memory Card Error. All of a sudden the camera is displaying "CARD ERROR" message. Camera works fine witout a card installed. Help me please
Hello Karen,
Please look for lock in memory card as in the above image. If the white latch is in downside position then slide it in up position. Also check that you are inserting the memory card in right position in the camera.
Jul 03, 2011 | Sanyo Xacti VPC-T700 Digital Camera
Protected card message
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jul 22, 2010 | FUJIFILM FinePix Z70 Z71 Digital Camera
CARD LOCKED
Pull the card out of the camera and slide the tiny slide switch on the card to the other position. All the SD-type cards that I have met have this lock on them.
Jun 27, 2009 | Samsung BL103 Digital Camera
Card Locked
The card in your camera should have a small switch on one side- try sliding it to the other side
Apr 08, 2009 | Pentax Optio 50 Digital Camera
Canon Powershot A560
Remove the SD card from the camera. Slide the tiny slide switch on the side of the card to the other "unlocked" position. Reinsert the card in the camera. That should do it.
Sep 07, 2008 | Canon PowerShot A560 Digital Camera
Camera problem
there is a little magnet inside the flip which has probably come loose,common fault
Oct 28, 2007 | Samsung SGH-D500 Cellular Phone
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
