Zanussi jetsytem turbodry1600...wj51665w
I have lost my service manual and all i need to find out is..what does E10 mean flashing on my washer drier please help thnx
  • Ron Coons
    Ron Coons May 11, 2010
    knowing manufacturer nad model would be helpful, every brand will have diff codes
    President:
  • 1,294 Answers
Click on 'washing machines' (below FIXYA )on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Posted on Feb 22, 2008
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
Zanussi washer iz 12 error e10
Switch off.
Press and hold the two buttons again and switch on.
The appliance will beep or flash, let go of the buttons, the leds will scroll.
Press and release the temperature button until the bottom led of the 2nd column is lit.
Let me have the error code.
Switch off, on and off again
Nov 28, 2010 | Zanussi IZ12 Front Load Washer
I am constantly getting a E10 error on my Zanussi w1042w. what could be causing this?
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 14, 2009 | Washing Machines
My Fridgidaire front load clothes washer model ltf2940es3 is showing error message e10
May 03, 2009 | Washing Machines
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi jetsytem fjs1225w
clean the draw out remove the top where the softner goes and clean under there.
Jan 22, 2008 | Zanussi FJS1225W Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
185 people viewed this question
Top Washing Machines Experts
