Question about Duravit 0910100005 Happy D Toilet Cistern - White
After flushing toilet server noise in pipes when filling up again
  • Anonymous Mar 19, 2014
    One flush plate is flushing and not returningafter flushi.e the small on and large flush plate is not flushing and not returning after flush/use. what it can be the problem?
Pagal
Posted on Feb 07, 2010
Why doesn't fill valve in toilet drop down after flushing
Likely corroded or warn out. In most cases replace the fill valve. I prefer Lavelle replacement fill valves. If toilet is an old 3.5 gallon or higher model or an early water saver, consider replacing the toilet with a latest generation name brand 1.6 or 1.28 flush model with a glazed trapway.
Oct 31, 2014 | Plumbing
Toilet wont flush
Main 3 (or 4) inch drain under the toilet is clogged. Requires removing the toilet and running a "snake" down the pipe. Alternately, you can (carefully) try manually filling the toilet bowl all the way to the top----to apply pressure to the clog....it may push it through.
Mar 04, 2014 | Home
When flushingtoilet water backs up inshower
You can try this, get a bottle of liquid plumber industrial or pro, and pour the entire bottle into the pipe in the toilet, when you remove the toilet cover you see a pipe that has a water line in it from the fill valve, if you can't pour the liquid into this pipe, then turn off the water to the toilet, flush it and hold the handle until all the water has emptied out.
Now while holding the handle, pour the bottle into the hole where the stopper is open, the hole where the water goes down.
Wait a hour, then take a bucket of hot water and fill the toilet water tank, flush it, do this again.
Now turn the water back on and flush. If the shower still over flows, you will need a plumber to come and snake the main line from the toilet down until the clog is cleared.
Unless he finds a close access near the toilet if this is on the first floor and he can do it from the basement.
Apr 13, 2013 | Motorcycles
When we flush machine runs and waste goes properly but waterlevel goes high . during flush time the toiletbowl filled with water
Sounds like your external pipe may have a blockage tap the pipe to see if your hear a thud if it sounds clear check the toilet outflow pipe the same.. You may need to have your external pipes rodded.
Jan 08, 2013 | Saniflo SaniPlus-Round SaniPlus Macerator...
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
Vent on top is blowing bubbles and toilet pan is filling up with effluent
If you have a Saniplus model then the vent connection is on the top right side of the pump casing if you are facing the toilet with pump sitting behind. The vent pipe needs to be minimum 1 1/2" and must be vented to the open air so air can flow in and out at all times. To the left side of the vent connection is the discharge pipe which should be a 3/4" or 1" discharge pipe. You can try disconnecting the vent pipe and run it with the vent pipe open, also you can disconnect the discharge pipe and put a bucket at the end of the discharge elbow and flush the toilet into the bucket, it will free flow into the bucket and there are no restrictions. That way you can tell if the problem is the pump or the installation set up.
Dec 20, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Toilet flushing fills up to level but emptying on its own but water level still at correct level . its a barcelona suite from b and q
If the water level is below the overflow pipe, you need to replace the rubber flapper. This is the part that lifts up when the toilet is flushed and then falls back to the original position after the tank empties.
Dec 27, 2009 | Ginger 31-910-SC15 Satin Nickel Barcelona...
Water pipes make noise after flushing
What you have going on there is called water hammering. The water flows at full force to fill the toilet tank and when the valve shuts the force that is created rattles everything. Begin by seeing that all of the nearby water pipes are secures to the wall or ceiling and not flopping around. Pipe straps available from any hardware are an easy fix for loose pipes.
And, in case you need to know more about water hammering solutions go to my link:
http://www.naturalhandyman.com/iip/infplumb/infwatham.html
Aug 16, 2009 | Home
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
Duravit 0910100005 Happy D Toilet Cistern  - White Logo
307 people viewed this question
Top Duravit Home Experts
paulcarew
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Duravit Home Expert? Answer questions, earn points and help others
