Question about Kenwood Food Processors
Open th fp510 footprocessor
Open the fp510 footprocessor
Remove the 5 screws underneath, then remove the 2 screws that hold the motor onto the base by inserting a thin phillips/star screwdriver through one of the gaps in the plastic grid underneath the motor.
Posted on Jan 16, 2011
How do i open the kenwood fp370 food processor
Try to open this web address:
http://ecx.images-amazon.com/images/I/91BZWe69vqS.pdf
And you will find some basic tips to open and use this food processor.Thanks
Jun 01, 2012 | Kenwood Food Processors
Is there actually any one person in the entire world who knows how to take a Kenwood FP510 processor apart to change the drive belt? There are lots of queries on the internet but no solutions. Somebody...
I have solved it at last! Remove the 5 screws on the bottom. There are 2 more screws (which may be blackened with oil) located through the grille directly below the motor. They're stumpy little things with gripping washers. I had to bend the plastic grille thingys to get screwdriver in. Once released, these will enable the whole base to be removed. Then there are 3 screws to get the plate off to put the new belt on. Put the belt around the big cog. Replace the 3 screws of the plate. The motor drive is loose now so you can angle the drive cog to attach the belt to this. Using gravity by turning the processor on it's edge you should with some fiddling be able to put the stumpy screws back in - took me a couple of goes. Replace the 5 screws and robert is a very close relative.
Jan 29, 2011 | Kenwood Food Processors
This is an inquiry about Waring food processor model FP510; SN# 11FP10. I need a new driver (the thing with a hex head that fits over the axle or drive shaft (one side of the axle is flat) of the electric...
I broke mine too, but luckily I found an extra machine at a thrift store. The driver was missing (of course), but I cut the blades off (hacksaw, easy) and used the resulting shaft as a driver. It works well: better and tougher than the original! Though they are expensive, you can order a new set of blades and do the same thing with the blades you have now. -Paul
Dec 13, 2010 | Waring FPC15 10 Cups Food Processor
When i open the door only the light is supposed to come on. the light comes on but the fan and turntable run also.
This is a very hazardous condition. DO NOT stick you hand inside the unit as you may well get yourself burnd by microwave radiation. It appears that there is either a problem in your control panel assy or that you have time on your timer and the unit has a defective door switch allowing the magnetron to keep running with the door open. There are at least 3 protective micro-switches in the door closed and latched circuit. Very slowly depress your door open button or pull the door open slowly (depending on unit type) and listen for 3 distinct switch clicks. All 3 click should happen in less than one one half inch of the door opening. Try is sevral times and listen for the 3 clicks repeatedly. If you do not hear 3 clciks then you have a bad micro-switch If you hear all 3 clicks, more than likely your controll panel has a failed relay on it.
Jan 06, 2010 | Food Processors
My 4 piece blade has broken on my magic bullet blender.
http://www.buythebullet.com/ This is the website and you can go on and order a new blade but it comes with other things and costs $30. The package is called the deluxe upgrade kit.
Aug 11, 2009 | As Seen On TV Magic Bullet Food Processor
Won't come on
I have been having the same problem. I know on the chopper, it has to be locked in real tight or it won't go on, but right now, I am on line searching as I wanted to use the blender, and I can't get mine on. Kathy Kirk
May 01, 2007 | Bravetti Platinum Pro Quad-Blade Food...
Food Processors Logo
396 people viewed this question
Top Kenwood Food Processors Experts
Ross Keen
Mitch Vass
Mitch Vass
Are you a Kenwood Food Processor Expert? Answer questions, earn points and help others
