Question about Panasonic CT-32SL15 32" TV
Panasonic Quintrex 32" 100Hz CRT
When I switch the TV on I get a picture, then after a few minutes it goes blank (sound still OK), then after about 15-20 minutes, with the picture coming on and off, it seems to kick into life and works OK.
Can anyone help?? My girlfreind doesn't want me to go and buy a nice new LCD TV yet until I can prove to her it's not fixable!!!
Thanks
Scott
  • Happyhank May 26, 2008
    Sharp 37"Aqua lcd tv. 1 and 1/2 years old. Turns on ok after 5 mins picture disapears, sound ok Turnoff tv. turn back on picture stays on for 30sec Repeats Help!
    Scholar:
  • 21 Answers
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
    Problem Solver:
  • 14 Answers
Use an uninterrupted power supply, UPS.
Posted on Feb 21, 2008
Panasonic tv goes blank after a few seconds when turned on no sound or vision, have to turn off and back on to work
the voltage regulator is probably going back. may or may not be worth it to fix. TVs are bigger better and cheaper now
Mar 12, 2014 | Apple iPhone Cell Phones
RCA DLP tv, the picture goes blank after a few minutes, and then comes back on and goes back off again...
Take it back to the store. If warrenty is expired then you will have to get a new TV or send it for repair . I don't know of anyone that comes to your home for TV repair. Sounds like picture tube is out of it.
Aug 17, 2013 | RCA Televison & Video
Bush tv
What is the exact model number to your Bush TV?
Apr 24, 2012 | Televison & Video
When switch on television picture blurred and image not clear. after some time around 20 minutes image starts to clear and tv plays normally, sound is ok
You have to check your capacitor may some of it have leak. May your picture tube have already a problem. Just check first the capacitor filter on the flyback that supply the power for the CRT socket of the picture tube.
Aug 13, 2011 | Panasonic TC-21Z88R 21" TV
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
TV picture blanks out, the restores
your tv has a loose board problem, its either in main board or CRT socket.
Apr 10, 2008 | Quasar SP-2719 27" TV
Guide plus
can you let me know if you got help for this? the gude plus menu is blank and keeps popping up in the middle of a show for no reason. then the picture goes out behind it. the sound works ok though.
Jan 10, 2008 | RCA F32649 32" TV
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Panasonic CT-32SL15 32" TV Logo
556 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
