Back to:
Tags:
MicroNet Technology 7 Bays MicroNet DataDock 7000 Storage Cabinet
Micronet DataDock 7000 alarm
posted by elsinore on Feb 21, 2008
The alarm is beeping intermittenly. It stops when I press the alarm button, but it returns after about 60 seconds. What's it alamed about?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 29, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
If this is a RAID array, it means that one of the drives has failed. This condition is usually also indicated by LEDs on the front panel. Use the diagnostic utilities that came with the unit or Windows Storage Manager to determine which drive needs replacing.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Micronet DataDock 7000 alarm:
I don't want to Accept this solution
Can you Help with these Drive Cases problems?
Drive Cases
I have a bytecc backupstar me-808 and the drivers will not...
Drive Cases
I need to remove the hard drive from a Maxtor personal...
Drive Cases
I forgot to mention that the old hard drive in the...
Drive Cases
i need to fit seagate hard diive into new enclosure
Drive Cases
the connector to the plug appears damaged, blue light...
Loading problems.
Repair Service
Find Drive Case Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
