Question about Dryers
Hi, I have a Zanussi TC482W which is spinning, but not heating up
Hi, I have a Zanussi TC482W which is spinning, but cold air is coming out, it's just not heating up. any ideas? thank you.
  • 269 Answers
Either the main heater has burnt out or the thermostat found inside drum housing above door.Also the water tank inside the machine could be full there is normally a small rubber cap with a wire clip on it at rear bottom of machine take this off and drain water onto a towel and gently tip back machine to get all out.The other fault could be the timer.
Hope this helps.
Posted on Jun 13, 2010
Washer skips rinse cycle
Possible defective washer control panel.
Jul 13, 2017 | Zanussi Washing Machines
My zanussi xc6 condenser dryer is blowing cold air,please help.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 08, 2010 | Zanussi Dryers
Dryer spins and drum turns, but only cold air c...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 20, 2010 | Kenmore 800 7982 Dryer
Cold air
It seems that it is more likely a Burned Out Heating Element.
Check and let me know if the problem still persists.
Hope i helped you.
Thanks for using " Fixya " and have a nice day!!
Jul 11, 2009 | Zanussi TD4112W Electric Dryer
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
Dishwasher not heating Zanussi
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
lmnbv
Mar 30, 2009 | Zanussi 23 in. ZDi6053SX Built-in...
Belt broke. zanussi tc482w belt no 125828800 1975h cant get one can u help
for a new belt for your tc482w tumble dryer contact service force spare parts phone number is 08444 776260.
Sep 03, 2008 | Zanussi Dryers
Indesit dryer IS70CS
sounds like the heating element or thermostat has gone in the dryer these parts can be bought from www.indesitservice.co.uk or www.espares.co.uk
Aug 02, 2008 | Zanussi TC180W Electric Portable Dryer
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Dryers Logo
141 people viewed this question
Top Dryers Experts
