Error 6400 ink cartridges wont track accross
Hi, When printing my canon ip3000 came up with the message ''Error 6400 comes up says cancell print, turn off then turn on printer see if this fixes problem''. It doesn't. I then noticed that the ink cartridges cannot move accross track to set up for printing. Is this an easy fix or major problem?
  • 4,041 Answers
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Posted on Feb 07, 2010
Ive just filled my ink cartridges but have the following error message when trying to print: (see add details section)
You need to reset the chip in the cartridge that tells the printer when it's low. The part can be found on sites that sell refill kits.
Aug 07, 2015 | Canon PIXMA MG3150 Inkjet Multifunction...
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
I have a Canon Pixma MP 130/110 Printer. Machine is not printing. Have been through all the recommended cleaning/ maintenance procedures several times and fitted new ink cartridges all to no avail. Message...
Pixma IP3000
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!!!
Mar 06, 2011 | Canon PIXMA MP130 All-In-One InkJet...
Hi, We have had the Canon ip3000 pixma for about 5 years now. No probs., very pleased with it. It is sending me a message which I have never, ever seen before, and I can find absolutely no reference to it...
when you sprint something, there is some time delay in printer, wich is used by printer to replenish color on print head.That means that purge unit, purges the ink from print head, to optimize printing or just clean the print head. Then the waste ink, ink wich is purged goes into absorber, its some kind of absorbing cloth under purge unit.
After certain number of purging, printer will automatically report absorber full.
You can clear the error in printers service mode:
<Service mode operation procedures>
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The LED lights in green to indicate that a function
is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the
Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release
both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed,
the LED lights alternately in orange and green, starting with orange.)
4) When the LED lights in green, press the Resume/Cancel button the specified number of time(s)
according to the function listed in the table below. (Each time the Resume/Cancel button is
pressed, the LED lights alternately in orange and green, starting with orange.)
4 times Green Waste ink counter resetting
Green means LED .
But 100% soulution would be to replace waste ink absorber.
Hope that helped!
emma.servis@gmail.com
Jul 03, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print. color ink cartridge light keeps
..."Open the ink supply andgently move the ink cartridges to the left. Then reach in to the rightside and you'll find a small (1/2 x 1 inch) sponge. Push it down andoff/on the machine. try it now. or ...go to where I found out more than I should know about Canon's and where I got my quote...http://www.fixyourownprinter.com/forums/inkjet/39177 good luck.
Oct 21, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon pixma ip3000 won't print
Check usb cable if they are installed firmly and correctly. Check proper voltage input though designed as Autovolt system.
Try plugging the usb cable on another free usb port or you may try another computer to check if your printer works.
See if there are blinking lights and error codes. You can google for its error codes.
Check flex cable continuity, maybe some rodents have eaten it.
Remove ink cartridge, turn the power off and clean cartridge contacts including the holder contacts, turn it on and return cartridges. You may try borrowing a working ink cartridge of the same type from a friend.
Dec 08, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Nothing will print
5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
Mar 10, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
148 people viewed this question
jasbo
jasbo
