Hi. i'm joeff. i just want to ask how you will connect a two switch hub into a five desktop computer. using a straight through cable. is there a possibility that each computer can access to each other??
  • Bill Eager May 11, 2010
    Your loosing me Switching is speed Ports is connections Computers we will call units Straight cables are hub to computer "X" cables are special. Now try again?
  • 31 Answers
Hub is central control device so it in center of all the PC &all PC driect connet to hub
Posted on Feb 13, 2010
I have a gs724t and need to add a gs748t, what cable do I use to link them together??
Most switches are smart enough to detect and reverse logic if the wrong cable is used. If you want to be correct you would use a crossover cable.
Computer to computer, router, or extender (crossover)
Computer to switch or hub (straight through)
Switch/Hub to Switch/Hub (crossover)
Dec 30, 2011 | Computers & Internet
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
How to use cross cable and straight cables in network
ok, i think what you mean is this.  Crossover cable is for connecting 2 computers together without the need for a router.  also called pc-to-pc.  Straight cables need the use of a router or hub to connect 2 computers together.  Hope this helps, if not let me know more info.
Mar 06, 2009 | Southwestern Bell (S60802)
Lan cable Setting for Switch & PC to PC LAN Connection.
If you are asking about connecting two computers together with a hub or switch, plug them into the switch/hub with standard patch cables (cat 5e or cat 6).
If you are asking about connecting two computers together directly using a LAN cable, then you will need a "Crossover" cable (cat 5e) wired specially (oranges transposed at one end for the common -B pattern) for direct LAN connection.
Jan 01, 2009 | Computers & Internet
Networking
Hello koolboyvipin, you and your friend can connect your computers together using CAT 5 cable in cross-over mode[pin1A to pin3B, pin2A to pin6B, pin3A to pin1B, pin6A to pin2B].
To connect more computers, you need a hub, but I prefer a switch because switches are more intelligent in data receiving/transferring. But your CAT5 connection between your computers and the hub/switch must be straight cables[pin1A to pin1B, pin2A to pin2B etc.]
I believe this would satisfy your problem.
For further enquiries, kindly post your requests to our forum.
Best regards,
Tony
Nov 18, 2008 | Computers & Internet
Cable modems
I have heard of people doing it.
However, you will need to pay the cable company for an additional line / service, as the MAC address of the modem has to be registered with them in order for it to work.
Apr 22, 2008 | Computers & Internet
Creating a networking cable
Dear ,
for this you have to need a straight cable to connect your PC to Switch.
for detail of colour coding please check this site:
http://www.incentre.net/incentre/frame/ethernet.html
cheerup and Be Happy always
Apr 10, 2008 | Computers & Internet
Connecting campus wide networking to hub
Check the following:
Hardware First: Is Vista confirming LAN connection onn that PC, or is it showing disconnected cable?
Is the connection properties showing at least 100Mbps?
Are the RJ45 terminals okay?
Is the driver for the network card recognized by Vista and loaded?
If that is fine, then check the following in the network properties:
1. The IP address you are using
2. The gateway address: it must be the same as the gateway address in the other PCs accessing internet. Run and check
3. The Subnet mask. Use 255.255.255.0
4. HAve you Setup the Nework using the Setup Wizard, including Access INTERNET THROUGH A HUB THROUGH ANOTHER COMPUTER ON MY NETWORK?
Check those things and let us know. Ask for help from your network administrator about correct IP addresses on that LAN
Feb 26, 2008 | Compex MicroHub TP1008C Networking Hub
Not able to connect to the internet
Please list the model of the network hub you are using.  Also is a "hub/switch" or a routher.  Also are you using a DSL or Cable internet connection?  Please provide a little more details.
Oct 26, 2007 | NetGear (GS608UK) 8x1000 Mbps Networking...
Networking
This site will give you directions on how to make a CAT5 cable. http://www.computerhope.com/issues/ch000639.htm
Sep 17, 2007 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
