Question about Waitec Cameras
I have Caddy 338 cam, software of which was formatted, now it is not working
Would a 1.9 sdi caddy damage valves if the cam belt breakers
Autodata list an ALH engine code for the Beetle 1.9 TDI from 1998 to 2004 so ... CAUTION: This engine has been identified as an INTERFERENCE engine in which the ... Polo Classic/Caddy SDI: Inlet manifold upper chamber. Based on this, yes.
Jun 27, 2012 | Cars & Trucks
Hard disk faulty how to replace
The online guide is here:
http://www.scribd.com/doc/7994162/Compaq-Presario-M2000-Maintenance-and-Service-Guide
I would go to (page 2-5 of the manual above) first and run a Hard Drive test from the Tools menu, before replacing.
Then go to replacement procedures (Page 5-7 of the manual) and it will instruct you, it is very simple, usually taking out two screws, removing the caddy (plastic holder). You then unscrew the old hard drive from the caddy (four screws) and then screw in the new hard drive (four again), slide it in, screw the caddy in (two screws) and voila', your new hard drive is installed.
This does NOT include instructions on how to backup your files, re-install your software or anything OTHER than replacing the physical hard drive.
You will need to format the new drive and install an operating system and software.
If you need further instructions, please ask.
Sep 07, 2010 | Compaq Presario M2000 Notebook
Recently bought a LG DV 338. But the player does not play wmv formats. Kindly let me know how to resolve this issue.
it can only play files with .vob file format(that is mpeg1 or mpeg2 video encoding format)
or you can try .avi files(divx video encoding)
source:personal experience,i have the same dvd player
Aug 04, 2009 | LG Televison & Video
I can not get my 2.5 hdd caddy to work on my Mac
If you used it on a PC you need to format it to a MAC. You can do this by going to disk utility and erasing it.
Jun 25, 2009 | Apple PowerBook G4 Mac Notebook
DVD RAM PANASONIC DMR-E75V WON'T ACCEPT NEW RAM DISKS
Make sure the DVD RAM is in the plastic caddy that came with the unit, and make sure that caddy is marked unprotected.
Dec 14, 2008 | Panasonic DMR-E75V DVD Player/VCR
Burning CD's
The problem is the format, car stereos use a different format than computers do for reading discs. You can try formatting the burn process for the type of stereo (usually an MP format will work) or try different burning software, I've found that Nero works better than Windows for burned music CD's for the CD player in my Caddy, and I don't have to format. You might be able to find Nero at filehippo.com
Jun 30, 2008 | Computers & Internet
Pc suite
i need a pc suite
Feb 05, 2008 | NEC 338 Cellular Phone
Cameras Logo
Top Waitec Cameras Experts
Steve
Are you a Waitec Camera Expert? Answer questions, earn points and help others
