Question about Frigidaire GLEQ2152ES Electric Dryer
How do you get to back bearing - Frigidaire GLEQ2152ES Electric Dryer
  • 572 Answers
The back bearing is part of te rear tub shell. need to replace the tub
Posted on Feb 07, 2010
I took the ball bearings out cause the case was broke now i cant get everything back together and to get the tire on so i can drive what should i do?
I assume you are talking about a wheel bearing. The ball bearings are usually part of a sealed bearing unit. If that is so, you'll have to get a whole new bearing cartridge, pull out the race (part of the shell) from the old one, and set the new bearing back in. Is this a front or rear wheel? Is the "case" the axle housing, or just the bearing shell?
If your problem is just holding ball or roller bearings in place for re-assembly in a non-cartridge bearing, use the old bicycle mechanic's trick: load up the bearing race with grease, stick the bearings into the grease, then assemble the journal/axle.
Nov 19, 2010 | 1993 Buick Park Avenue
Left front wheel bearing replacement diagram
Removal & Installation Front To Remove:
The front wheel bearings are not serviced separately. If the front wheel bearings are defective, the hub and bearing assembly must be replaced.
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Lubricate the threads on the halfshaft with clean engine oil.
  3. Remove or disconnect the following:
    • Front wheels
    • Halfshaft hub nut
    • Caliper from the steering knuckle WARNING
      DO NOT allow the brake hose to support the weight of the caliper.
    • Brake rotor
    • Anti-lock Brake System (ABS) sensor from the backing plate
    • Hub and bearing assembly from the backing plate
    • Hub and bearing assembly from the halfshaft
To Install:
  1. Install or connect the following:
    • Hub and bearing assembly onto the halfshaft
    • Hub and bearing assembly to the backing plate. Torque the 3 bolts alternately and evenly to 70 ft. lbs. (95 Nm).
    • ABS sensor
    • Brake rotor
    • Caliper on the steering knuckle.
    • Halfshaft nut. Torque it to 118 ft. lbs. (160 Nm).
    • Front wheel. Torque the nuts to 100 ft. lbs. (140 Nm).
Oct 18, 2010 | 2001 Oldsmobile Aurora
Need to replace wheel bearing hub kit on 2000 s-10 2wd. is it a kit or just a bearing? What are the steps?
The bearing is "pressed" into the hub/spindle. On the 4x4 model the wheel hub is bolted onto the spindle from the back (remove wheel, caliper and bracket, axle nut, 3 bolts on the back and tap out). On the 2 wd model, It'll have to be pressed out, and back in. Remove the wheel, caliper and bracket. Follow the ABS sensor wire to the inner frame rail in the engine compartment and unplug it (along with removing the bolted clip on the upper "A" frame). Separate the tie rod end, upper and lower ball joints (won't affect the alignment) and remove the spindle. If you can locate a used one you can have it ready to put back in immediately.
Feb 25, 2010 | 2000 Chevrolet S-10
The blade falls off the bearings/guides
The blade is suppose to ride on the face of the bearing not the profile side. If you are looking at the bearing on a table flat with the hole in the middle, this would be the face. The blade makes slight contact with this bearing to back it up as it goes by. In other words the blade is not suppose to travel around the bearing as it spins. It is suppose to travel across the bearing. Take a look at the picture I drew below. Also review the instructions for the guide setup. You can view them online at : http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A27894,28-206%2028-276.pdf Page 19 is the page with the guide setup.
Oct 14, 2009 | Delta 28 276 14" Band Saw W/ 3/4 Hp Motor...
How to replace rear axle bearings 2004 vw jetta
take off rear hub u have a inner and outter bearing ..change bearing dont forget to pack new bearing well with a GAA Bearing Grease...and install wheel and tighten middle nut till wheel is tight...then back it off enough that wheel turn but not too freely about half a turn back....GL
Aug 30, 2009 | 2004 Volkswagen Jetta
How do i replace the rear wheel bearing on my peugeot 206 1.9hdi year 2002 my rear wheel bearing has gone on my pug206 and i want to know how to fix, replace and repair myself i have bought the rear wheel...
wheel off remove the tin cap in the centure of the hub undo the big nut put the wheel back on with just 2 bolts finger tight so you can pull the hub off.once the hub is off take the 2 wheel bolts back out.now look in side the hub were the big nut was and you will see a sir clip take that out.then use a socket and a bench vice to press the old bearing out.use the socket and bench vice to put the new bearing back in.
Jul 20, 2009 | Peugeot 206 Cars & Trucks
We replaced the bearings in the wheel hub.. we took the tire off, the hub off, and replaced the bearing inside of it.. put everything back together and now the wheel wobbles while it is on the jack.. bout...
The bearing is a tapered bearing did you put it on the right way round so that the largest part of the bearing is at the back
That then matches the taper on the wheel hub
That is so you can wind in the castellated nut with a torque wrench to set the pressure of the bearing according to the manual
Jun 24, 2009 | 2005 Chrysler PT Cruiser
Wheel bearing rear repair
well you should replace both of rear wheel bearings. most likly if one gose the other is about to.
what you do is
NOTE your bearing might be pressed fit. if you can't remove by hand you are going to need a shop.
1- remove the wheel and brake assembly,
2-remove axle flange from hub
3- bearing should be easyly pulled out.
4- clean out all old grase
5-pack new bearing full of new greas.***MUST DO*** put greas in your hand and scrap greas into the bearing till it come out the top.(or use bearing packing tool)
6- put the rest of the greas into the bearing retainer and reinstall.
7- YOU MSUT pre load the bearing after you put the bearing in and bolt holding it in you must pre load to 40 in'lbs then back of and hand tighten (or go tight 1/4 past, then back of 1/2 then tighten buy hand.
never stike the bearing with a hammer IT MAY EXPLODE
May 30, 2009 | 1994 Toyota Camry
Rfrigidaire dryer making a squeaking noise but works fine
hi. thanks for the question .the front bearing and the back bearing is worn. replace these 2 parts. to replace.lift the top. remove front. replace front bearing undo belt . remove the drum . replace the back bearing. thanks the appliance doc
Oct 06, 2008 | Frigidaire FEQ1442ES Electric Dryer
Dryer bearing
you need to oinstall the bearing little ball and bearing first then install the drum and belt the last thing is to rinstall the 3 screws inside the back of the drum to the bearing this is the easy way rather than tryingto get the bearing in the scoket while on the drum
May 14, 2008 | Frigidaire GLER341A Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
82 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
