Question about Compaq Computers & Internet
I have a compaq presario r4000 laptop. I restored to an earlier date. when i rebooted it wOULD not go to the startup menu. error code IERTUTIL.dll
  • 4,281 Answers
You need windows or recovery disk for fix this errors.
for that first insert disk into cd/dvd rom.
then when you power up the computer press F1 or F2 or "del" key to enter in bios then go to boot options then set first boot device as cd/dvd rom then save settings and exit.
Then it boot with that disk then follow the procedure enter in recovery console then type in prompt "chkdsk /r" then press enter in "y"
Then it fix errors and recovers the bad indexing unit on harddrive.
Then again restart computer then follow same procedure and choose repair options for repair previous windows then it repairs it then you get your windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Feb 07, 2010
On my windows 7 gateway laptop I am receiving the message "the ordinal 572 could not be located in the dynamic link library iertutil.dll. I ran a cmd scan and did not find anything. Any suggestions?
How To Fix Iertutil.dll Errors
Important: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  1. Restore iertutil.dll from the Recycle Bin. The easiest possible cause of a "missing" iertutil.dll file is that you've mistakenly deleted it. If you suspect that you've accidentally deleted iertutil.dll but you've already emptied the Recycle Bin, you may be able to recover iertutil.dll with a free file recovery program.
    Important: Recovering a deleted copy of iertutil.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
Feb 10, 2014 | Gateway Computers & Internet
How to restore to factory settings Compaq presario 3000
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot your problem should be resolved.
Sep 26, 2011 | Compaq Presario sr1303wm Computer - AMD...
Theres A Problem of My Computer How To Fix MY Computer The Eror Name is iertutil.dll Thats My Problem Eror
Iertutil.dll Error MessagesThere are several different ways that iertutil.dll errors can show up on your computer. Here are some of the more common ways that you might see iertutil.dll errors:
  • "Iertutil.dll Not Found"
  • "This application failed to start because iertutil.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\iertutil.dll"
  • "The file iertutil.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: iertutil.dll. Please install [APPLICATION] again."
Iertutil.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the iertutil.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Iertutil.dll ErrorsIertutil.dll errors are caused by situations that lead to the removal or corruption of the iertutil DLL file.
In some cases, iertutil.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Iertutil.dll ErrorsImportant: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source.Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  2. Run a virus/malware scan of your entire system. Some iertutil.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the iertutil.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the iertutil.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the iertutil.dll file. If the iertutil.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the iertutil.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to iertutil.dll. If, for example, you're receiving a "The file iertutil.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The iertutil.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if iertutil.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the iertutil.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The iertutil.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause iertutil.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual iertutil.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair iertutil.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid iertutil.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the iertutil.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the iertutil.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any iertutil.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Any doubts you can contact a technician through the website
www.thebestpcdoctor.com
Toll Free: 877 407 8229
Aug 11, 2011 | Microsoft Windows 7 Ultimate for PC
My presario cq40 doesnt turn on,,,charging light exist,but when i turn the power button on it wont turn on.what do you think the problem is?tnx
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
Aug 02, 2011 | Compaq Presario Notebook
My Compaq laptop fell over from about 1 ft and it now will not re-boot. It will atempt to reboot but will just shutdown w/o warning. If I leave it alone it will reboot to just about allowing me to open a...
Hi
Thank you for your query
Please try the following
1) Start Laptop
2) Continuously press the F8 key until a startup menu is repsented
3) Choose safe mode from the menu
4) Once safe mode has loaded up click on Start>Programs>Accesories>System Tools>System Restore
5) From system restore choose 'restore my computer to an earlier time'
6) From the calender presented please select a date in bold lettering back to before this fault was seen
7) Choose the date and click next..............follow the instructions through
If the system restore fails as above Try the following
1)Put restore CD into drive and restart PC
2) Choose repair from the options and then follow on the on screen instructions
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 24, 2010 | Sony VAIO GRZ610 Notebook
Acer Aspire 1640 startup issues
Hi, Can you please try these steps mentioned below.
1. Restart the PC and repeastedly hit F8 until you have a menu in front of you.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and Enter.
After these if you face the same problem then format the OS & install it again.Thanks & waiting for your feedback.
Feb 11, 2010 | Computers & Internet
I hve a compaq presario 5000 desktop. It will
if you can view your desktop and use the menus, go to start/all programs/accessories/system tools/system restore, if you had enabled this option earlier then you can restore the system to an earlier known date when you system worked.
else you can try installing winXP again, try the option to "Update" when the install option comes on.
else start PC, before the WinXp screen comes on press F8 key, use the Safe Mode to start PC, if you can see everything then shut down and restart in normal mode.
Dec 06, 2009 | Compaq Presario 5000 PC Desktop
Problem with compaq presario r4000 constant beeping no keyboard
Need to know the number of beeps. They're called beep codes. This page lists some of the Compaq beep codes and what they mean.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Nov 06, 2009 | HP Compaq Presario R4000 Notebook
PLEASE HELP
If it has been some time since it has locked up I would suggest that you power of the laptop with the power switch and then restart it in safe mode by pressing F8 before you see the Windows logo. This should bring up an Advanced Startup Menu. Choose Safe Mode with Networking using the arrow keys. Once you have it highlighted press Enter to start that option.
You will see files scroll down the screen. This is normal. After that you will see a dialog box asking whether you want to start in safe mode. Choose No so that you can start the System Restore Option. Then follow the instructions to restore your computer to an earlier time. Then from the available dates choose a date that was before the updates were downloaded.
Here are some screenshots of System Restore for XP:
http://www.theeldergeek.com/system_restore.htm
Hope this works. Please remember to rate this information.
Sep 08, 2008 | HP Compaq Presario V2000 Notebook
R4000
hi, u havent provided detail description of which driver of ur unit is missing,by the way if u have system restore utility in windows os u can use this to restore ur system to workin state.......as earlier but if this is not helping u can download drivers from hp's site at ur friends place copy it on a pen drive or a cd & intall it on ur unit.....
Feb 09, 2008 | HP Compaq Presario R4000 Notebook
Computers & Internet Logo
32 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
