Question about Kenmore 22812 Bagged Canister Vacuum
How do i get access to replace the belt?
I need to replace the belt, i dont know how to get access to the belt.{ open the cover to revel the belt and brush ]
    President:
  • 1,673 Answers
If it is the one in the picture above, then from underneath there are 2 screws to remove, then on the back there is 2 catchs, and on each side a catch, pry up slightly to release them and the top will come off. There may be a cover over the brushroll, there is a catch on each side to release and it will come off.
Posted on Feb 22, 2008
I have a Singer 478 sewing machine and need to replace the top gear on the verticle shaft. Is there a repair manual for doing this. There was not category expert on this so please direct to the correct...
This is an easy fix. a lot disassembly required, you will need to gain access through the belt side to the singer cover plate,four clips hold it on from the back side. Once that is off, two screw hold small access plate which is under the letters Sin, remove plate, rotate shaft to access screw through opening which holds Vertical Top Shaft Gear, Singer # 155819 in place. Remove bottom cover, locate belt pulleys (2), remove cam tensioner, with a hex wrench remove pulleys, this makes it easier to remove lower belt. with a long thin, blade screwdriver, loosen screw on gear (through small access cover), slide shaft downward Rand R gear, reverse process, done. Be sure you document removal, take pictures, mark references with marking pen.This makes reassembly easy. I just replaced mine, I am handy but not an expert, hope this helps you...
Jan 27, 2011 | Vacuums
Cant open roller assembly roller not spinning i dont see anything in the way
Turn the power head over so the bottom is facing up. On the bottom towards the back there are two holes (one on each side) where you can get to the access screws. Remove the two screws (you'll need a phillips screwdriver). With the screws removed you can now remove the top cover from the base by pulling out on the two clips on each side of the power head. With the top cover removed you can get to the belt and roller brush. If you need a belt for this model you can get it here:
http://www.vacbelts.com/20-5218-belt.htm
Don't forget to rate the answer!
Jan 07, 2011 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 18, 2010 | Vacuums
Changing belt on u5063-930
ok its fairly simple the belt you need is 38528-040. Start by first removing the little slide button from the height adjustment switch. just pull strait up and it will pop off. it will need to be out of the way. turn over the vacuum and there will be 2 spring clips that release the bottom cover and give you access to the brushroll. now you must remove the top cover. there are 4 clips, 2 on each side. Use a flat head screw driver to pry one clip at a time, it should pop fairly easy. now that you have all the clips free release the handle assy and the hood will lift off. inspect brushroll for wear and free rotation. if its bad replace it. now install the belt on the brushroll first, install brushroll and pass belt through belt channel. Stretch belt with your hands until you successfully get it on the motor shaft. (Its supposed to be pretty tight i guarantee its the propper belt) rotate brushroll to properly align belt then snap top cover, and bottom brushroll cover back in place and dont forget to put the small button back on top of the hood.
Jan 01, 2010 | Vacuums
Hi, my power head is not working on model 116 5416083 and I cannot open it up. I think there is a gasket that needs replacing.
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off from the base and you will be able to access the belt. Here is a link to the belt you need:
1165416083 Replacement Belt
Dec 03, 2009 | Vacuums
How does the bottom open on a Hoover Vac ModleU5064-930 to change the belt ?
If you flip the vacuum over there should be (4) access screws on the base plate that covers the roller brush. Remove those and you will be able to access the belt. The belt you need you can get here:
Hoover 38528027 Replacement Belt
Nov 06, 2009 | Vacuums
Need to replace belt on beater brush
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off and you will be able to access the belt. You can find this belt at www.vacbelts.com.
Jul 01, 2009 | Vacuums
turn it over on the bottom by the roller there is a cover with 5 screws take off cover theres the belt........hope this helps
Dec 17, 2008 | Eureka 5848AV Bagless Upright Vacuum
Belt broke
There should be an access panel on the top side of the cleaner. Pry this open with a screw driver and this should get you access to the area where the belt can be changed.
Apr 11, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Kenmore 22812 Bagged Canister Vacuum Logo
53 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
