Question about Samsung RS2630SH Side by Side Refrigerator
Has a lock code when power up - Samsung RS2630SH Side by Side Refrigerator
  • 572 Answers
Unlock the keypad. this is a child safety feature
Posted on Feb 07, 2010
I have forgotten security code of nokia 1280. My IMIE No. 351671/05/037339/1. Can some body help me to retrieve or reset my security code.
  1. Make sure that your device is on.
  2. Next press and hold * key + 3 key + Call button + Power button until you see logo Nokia.
  3. Now enter your lock code.
    * The default lock code is 12345
  4. Then your phone will reset and restart.
  1. second method if first dont work .
  1. Power on the device.
  3. Then type this code: *#7370#
  4. Now press your lock code.
  5. Afterwards your phone will reset and restarts.
  6. Done!
  7. Third Method:
    1. Press Power button until your phone is on.
    2. Then navigate to Menu -> Settings -> Restore Factory Settings.
    3. Now enter your security code.
      * The default code is: 12345
    4. After that your cell phone will restarts.
Oct 21, 2014 | Nokia 1280 Cell Phone
How to reset lock code of nokia5530
You can format your Nokia 5530 device by typing: * + 3 + call + Power on. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
If it is not working try this code:
You can format your device by typing *#7370# in standby mode. Before the device is reset, you need to provide the lock code. The default lock code is 12345.
Apr 29, 2014 | Nokia 5530 XpressMusic Smartphone
What does it mean when your laptop's power lights flash ? Including the power button?
"The following table illustrates the meaning of blink codes used on some notebooks with EFI environment.
The blink or beep codes on your computer may have different meanings. When you contact HP for
support, the agent needs to know the model of your computer and may ask you about blinking LEDs
or beeping tones to help troubleshoot a startup problem.Meaning of Sample Blink Codes for some EFI Notebooks Number of Blinks or BeepsLocation of Blinking LEDsComponent Being CheckedError Condition
Continuous glowBattery power LEDBatteryThe AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook.
1time---Caps Lock/Num Lock-----CPU------------------CPU not functional
2time---Caps Lock/Num Lock-----BIOS----------------BIOS corruption failure
3time---Caps Lock/Num Lock-----Memory-------------Module error not functional
4time---Caps Lock/Num Lock-----Graphics--------------Graphics controller not functional
5time---Caps Lock/Num Lock-----System board----------General system board failure
6time---Caps Lock/Num Lock-----BIOS-------------------BIOS authentication failure
Continuous blinkAC power adapter LEDPower adapter Insufficient power"
Nov 01, 2012 | Compaq Computers & Internet
Vchip reset? Inputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
Hello
If a power interruption occured to your household power supply, V-Chip has to be resetted. To reset the V-Chip do the following.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To change the lock code, follow the steps below.
Press the MENU button
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/ Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
Apr 07, 2011 | JVC Televison & Video
Touch screen is locked up can't type anything
Do a hard reset by holding down the power button for a few second and powering down. If that is not an option, remove the back covering and take out the batter for a few seconds. After a few second, replace the battery, and power up the phone. You should be able to type what you need provided you have your lock code if the phone is locked by your pass code. If it is locked by your pass code and you do not remember it, then you will have to contact your service provider.
Nov 22, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Jul 25, 2009 | Frigidaire FEB30S5D Electric Single Oven
I DONT REMEMBER THE LOCK CODE..
pls press the power off button once and go to lock phone and type 00000000.u will solve ur prblm...........
Feb 27, 2009 | Samsung SGH-i450 Cellular Phone
N-95 phone lock code.....
Sorry to say, if you don't know the lock code you will need to send to it nokia to get unlocked, you probably have to show them the proof of purchase (reciept) and most likely have to pay for it, unless you can find some dodgy high street fone repair shop to do it for you.
Jan 14, 2009 | Nokia N95 Cellular Phone
Need phone lock code
mechanic213 hello,
By default, all Sony Ericsson phones are locked with "0000" as a code.
Sep 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Samsung RS2630SH Side by Side Refrigerator Logo
183 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
