Question about Kenmore Kitchen Ranges
Gas range moder kenmore 790.75851302 convert to lp
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
SOURCE: how to use the self cleaning feature of kenmore gas range
I NEED THE BOOK ON HOW TO USE THE OVEN ON THE STOVE RANGE
Posted on Nov 27, 2008
SOURCE: Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Posted on Jan 05, 2009
MNTECH
  • 1543 Answers
SOURCE: Converting a GE Profile Gas Range from LP to natural gas
GE ships gas ranges set for natural gas, with the LP orifices included, usually on a metal tab held with one screw right near the regulator (where the gas connects to the range). If the range was converted to LP, the person who did the conversion was suppose to put the natural gas orifices back in that holder. If they are missing, comment back on the exact model number and I can look up the part number(s) for you.
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Posted on Mar 22, 2009
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Convert maxitrol regulator#rv47cl natural to propane gas
Some gas ranges cannot be converted. If your model can be converted it normally requires flipping over the regulator diaphragm and also changing orifices for all burners, surface and oven. Most modern new appliances come with the LP orifices located on a card attached to the regulator.
Nov 18, 2013 | Kenmore 72132 / 72134 Gas Kitchen Range
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
How do i convert lp gas range to natural gas?
You must first convert the pressure regulator pressure pin by turning the cap over and re-installing it.
Then you buy NG orifices and convert each burner.
Then you adjust the bake and broil orifices outward for a clean blue flame about 1 inch long.
Sep 06, 2010 | Kenmore Kitchen Ranges
Gas stove need to switch to propane
Hotpoint supplies the orifices and instructions with each range for converting. It is just that it is hidden, they attach it to the gas regulator. The regulator is near the bottom back typically. Here is a cut out from your use and care manual.
CONVERTING TO LP GAS (or converting
back to natural gas from LP)
This range leaves the factory set for use with natural
gas. If you want to convert to LP gas, the conversion
must be performed by a qualified LP gas installer.
The conversion instructions and LP orifices can be found
attached to the range next to the pressure regulator.
Keep these instructions and the orifices in case you want
to convert back to natural gas.
May 13, 2010 | Hotpoint RGB745 Gas Kitchen Range
Gas range converted to LP gas huge flame in oven
was the injectors converted in both and was the regulator converted
Jan 21, 2010 | Kenmore 78530 / 78531 Gas Kitchen Range
How do i convert my 790.71011200 kenmore range from natural gas to LP?
After looking high and low for a conversion kit I finally looked up the installation manual for your range. AND gues what!! you have everything you need there!! Just follow the instructions in the installation manual for conversion over to LP.
Download the installation manual here if you do not have yours. The instructions are in the back pages 9 & 10.
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0207026.pdf
Have fun!!
Heatman101
Jan 19, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Need to convert from natural gas to LP. How?
I converted a gas range several years ago, and all that was required was that I had to 'seat' all of the orfices - or tighten them down so that they are completely seated (do not overtighten!). It has been working great for years!
Sep 07, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Jan 06, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
