Question about Microsoft Windows XP Professional
When we try upgrading xp to windows 7 the upgrading failed because our cpu is old can i upgrade my xp to windows 7 using a old cpu or use a new cpu
    Problem Solver:
  • 10 Answers
By the time you upgrade everything to bring your computer up to speed for windows 7 you would spend probably more than a new one already with Windows 7 installed. Trust me ,been there done that, never again. Also make sure you like the windows 7 before you make your purchase. I hope that helped some.
Posted on Feb 07, 2010
  • 35 Answers
If you want to run Windows 7 , you need to have these system requirements
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver.
Check these the system requirements in Your OLD CPU or You can Upgrade the system or Get new CPU.
Thanks For using FixYa.com.
  • Microsoft Master
  • 12,061 Answers
NO you cannot, on that same computer, no matter what OS, because, you MUST change your central Processing Unit, CPU. To allow Windows 7 to work correctly.
I installed windows xp on my toshiba tecra m4. How stylus pen works?
Toshiba Tecra M4-S435 is Tablet PC. Windows XP (Profession) has no option of touch screen.
In order to use the feature, you need to install Windows XP Tablet PC Edition or you may install Windows 7, which supports this feature and you would definately be able to use stylus and touch screen, as I have installed Windows 7 and its working fine with all the drivers etc.
Hope it helps! Good Luck!
CreativeTECH
Apr 23, 2011 | Toshiba Tecra M4-S435 Tablet PC
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
My old computer that I have XP on is just too slow. I hate Windows 7 and do not care for Vista. My problem is that I am told that my new computer will not run XP because it is 64 bit. Two questions: Is...
Xp will run fine on any PC but it may not utilise all of your ram and CPU cores. You will get more performance from your machine if you use a 64 bit operating system but XP will run.
Nov 26, 2010 | Dell Inspiron 560S Desktop Computer (Intel...
Can i update window 7 ? now i hv window XP is there any effect of my files available in system during downloading wndow7
Windows 7 does not allow an upgrade from Windows XP. You would have to upgrade to Vista first and then on to 7. Also, it depends on which Vista you have that will determine which Windows 7 you can upgrade to. If you have Vista Home basic for instance, you cannot upgrade to Windows 7 Premium or professional. It is really screwed up. You can however do a clean install but you will lose all your old files unless you back them up on an external drive before running the new OS.
May 16, 2010 | Acer Aspire One PC Notebook
Tip
Perform a Custom Install to Upgrade from Windows XP to Windows 7
TIP1: If you are running Window 5 (XP) even with SP3 you will most certainly require a Custom Install, this is a 5 step complex process so don't rush it, to upgrade to Windows 7 if you just go ahead and expect that the upgrade CD will do everything for you dissapointment will most certainly be your results.
You will need at least 1GB of RAM ( or 2GB if you want to use the Windows (x86) 32-bit XP compatibilty mode on Windows 7 if your hardware won't support hardware assisted virtualization technology then this mode is not for you so 1GB will be fine) and a 1GHz processor and 16GB of free hard drive space if you don't have these forget it. Also you will require a graphics card that supports Aero for full use of all Windows 7 functionality so you might want to consider a new AGP graphics card as well your choice.
There will be several driver issues with webcams and other devices that will not work after the upgrade run the Windows 7 upgrade advisor tool before you even attempt it, you will also require the Windows Easy Transfer Tool later on so download this now.
I suggest that you first create a drive image using Ghost v14.0 and save a good image of your old WinXPSP3 partition prior to the upgrade. This will be your safety net restore points can't help you here. Its also worth using the preboot antivirus scanner bundled with Ghost before the upgrade you can use my autoupdater Antivirus Defintions CD creator to ensure you can scan with the latest defntions, download this from either LINK1 or rapidshare LINK2 these are posted exclusively for Fixya users.
Follow these instructions HERE in this PDF to assist you you will require an external USB and the I386 cabinet files from your OEM preinstalled version or from the original WinXP CD and the Windows 7 upgrade CD.
Also your WinXP must include the NET. Framework v2.0 x86 (32bit) runtime files and at least SP2 prior to the upgrade, I suggest you check using these NET Framework check tools to see what version you have. to check your service pack type c:winver at the run prompt
TIP2: If you have DRM (digital rights management) protected files from iTunes or similar download sites check that these can be restored after the upgrade if not back these up first as a matter of course.
TIP3: The upgrade from Windows Vista (v6.0) is a bit easier so if in any doubt upgrade to Vista first then Windows 7, if you miss out a step you can render your PC useless hence the first image step is highly recommended if the upgrade fails.
Good Luck !
on Dec 28, 2009 | Microsoft Windows XP Professional SP3 Full...
Hi i am trying to upgrade my window 98 to window 7 but explorer won't let me download it how can i upgrade my computer to window 7
:L You Cant Upgrade From WIndows 98 To Windows 7 Your Pc is too old and The hardware is Gonna be outta date
Nov 16, 2009 | Microsoft Windows 98 for PC
Hi guys, I'm new in this forum and I really need some help. I have a p4vmm2 motherboard with Intel Celeron 2.0 Ghz CPU and I want to upgrade it with Intel Pentium 2.4 CPU motherboard. I have already tried...
Whenever you try to upgrade motherboard and CPU's with Windows XP, you're probably going to have to format your drive and re-install XP. When you originally install XP it detects the motherboard and IDE controlers for your hard drives and installs the drivers needed but it doesn't install all drivers for motherborads and IDE controlers. When you swap out motherboards and the system tries to fire it doesn't have drivers available for the new motherboard and can't complete the boot into windows. Every once in a while you get luck and the new and old motherboard can use the same drivers but this is very rare. So when upgrading motherboards plan on backing up your hard drive of all files you need to keep and being prepared to format and re-install windows.
May 15, 2009 | EliteGroup P4VMM2 V8.1 Motherboard
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
Problem with mobo upgrade ... From Intel CPU to AMD CPU
hi dale, itsnot a good thing when you see the blue screen of death, cause recent changes hardware normaly maybeif you have changed from intel to amd using mobo and all parts are amd now , maybe if you reinstalled your operating system the new hardware that is installed will accept you software cheers steve good luck
Apr 26, 2007 | Jetway 939GT4-SLI-G Motherboard
Microsoft Windows XP Professional Logo
219 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
