Question about Desa International CBN30T Central Heating System Heater
To get heat downstairs i have to turn raiators off
To get h
eat downstairs i have to turn raiators off downstairs or vic versa it is a heatline vizo 24 combi boiler
  • 3 Answers
Sound like a dirty system , power flush needed
Posted on Feb 07, 2010
  • Desa Interna... Master
  • 3,238 Answers
Hi check the water pressure in the boiler check the setting / speed of the pump see if this helps
2 level townhome- the upstairs is heating to 68 degree-thermostat is located but the downstairs is like 58 degrees.The vents are open in ceilings downstairs. How can we do to get more heat downstairs
close ceiling vents
the hot air down stairs rises through the vents and adds to the upstairs heating
same as hot air goes up the stairs to the upper rooms
Dec 27, 2017 | Heating & Cooling
Heatline vizo 24
Your cold water fill tube inside the tank is broken off near the top of the tank. Replace the fill tube.
Aug 26, 2014 | Water Heaters
Need to decrease pressure on a heatline plus 24 vizo? any ideas? also leaking small amount of water under boiler!
There is a pressure adjustment on the gas valve...make sure you set it with a manometer. If the water is just condensate, its ok except if you don't have enough combustion air for the btu rating of the water heater. If it is a leak, replace the water heater
Dec 11, 2013 | Water Heaters
I have a deluxe wired heat pump and am enquiring what the 2 zones" are
Debi - "2 zones" usually indicate, 2 separate areas of the house(upstairs & downstairs). But, this usually requires two separate heat pumps for each area. That is unless, you have an electronically controlled damper system in your home's duct work. If that's the case, when one area calls for heat or AC, the damper closes to the other area and vice versa. If both areas call for heat or AC, the damper stays in the neutral position.
Hope this helped you. Please let me know. Thanks.
Jun 20, 2011 | LG Heating & Cooling
I just turned on our heat unit "FA4A AC/Heat Pump"
There probably isn't a reset button=magic fix. With it in heat pump mode and tstat set above indoor temp, check your outdoor unit to see if it's operating. If not, check all breakers to it. Can you see any ice accumulated on the outdoor unit? If it is running and not producing heat, turn the tstat to emergency/auxiliary heat. and the heat pump turned off to prevent damage. You'll need a service tech.
Nov 04, 2017 | Heating & Cooling
Not enough heat
Take an Amp draw on all heaters and compare. If within 5%, they are working fine but you may have more open area downstairs than up.
Mar 03, 2010 | Heating & Cooling
I have 2 Thermostat's in my home. My heat works well upstairs but not downstairs. My thermostat downstairs won't come on but I unhooked the thermostat from downstairs and tried it upstairs and it worked...
Hi, sounds like you determined the problem is not with the thermostat. That leaves the furnace that serves downstairs. What type heating system do you have?
Jan 13, 2010 | Honeywell Programmable Thermostat Heater
I can only get heating to the radiators upstairs, not downstairs
balance the rads.
upstair radiators turn all valves off,heat will then divert downstairs,open valves upstairs 4 turns on locksheilds and number 4 on trvs if u have any.
then if that does not work get a combi or powerflush.
if u cant afford then drain a little from rads,get x300 sludge remover from plumb shop and put in header tank(not hot water tank).
then fill system up and repeat balancing.
www.jollygreenplumbingmachine.co.uk
Dec 26, 2009 | Desa International CBN30T Central Heating...
Hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Oct 13, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Open Questions:
Desa International CBN30T Central Heating System Heater Logo
199 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
