Question about Powercom King Pro 1200VA (powkingpro1200va) UPS System
How can i connect my external charger with my powercom kin-1200ap ups.Im using external two battries of 12 volt 40 amp .
  • 348 Answers
Your charger should be 24v and more then that but how can you stop charging after full charging overcharge may damege the batteries
Posted on Apr 18, 2010
Where is the best place to buy a battry charger at a reasonable prise?
Cheapest.....Rural King or Harbor Freight. Better quality at Wal-Mart or Sears. don-ohio (:^)
Jan 05, 2017 | Drills
Okay, I'm working on a scooter for my nephew that originally came with (2) 12 volt 12Ah batteries minus the charger. and I know I need to replace them with (2) batteries of the same 12 volts and lets
not exact, to charge apropiate needs 10% more than nominal voltage. if not, will not charge the batteries.
And the charger its very important because you can over charge the battery.An example,if you have a 12 Amps Batteries each one if you put it in series will be 24 Volts.at parallel conection will be 12 volts but the double of Amps.
At serial connection will be 12 Volts the amps will be the same but the volts will be 24.
The charger at 12 Volts must be 13.8-14.5 DC Volts and divide the Amps in Hours.
The charger at 24 Volts must be 26-28 Volts. to charge well.
The charger for 12 amps batt example must charge 2 amps per hour at 6 hours = 12 Amps.(2 Amps Charger by 6 Hours Charging= 12 Amps.(Fully Charged.
3 Amperes Charger needs 4 Hours to charge 12 amps Batt.
5 Amperes Charger needs 2 Hours charging an a quarter
All of this is at DC Current.
Luck.
Oct 18, 2014 | UPG 12V 12Ah Electra Scoot-N-Go 88615...
Manaul for schumacher battery charger model se4020
Your battery charger supplier or manufacturer should be able to supply you with an operating manual.
Aug 14, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
How to replace batteries in powercom kin-2200ap
I think the product specification is the best teacher and approachable tool for you .
Feb 15, 2014 | Powercom KIN-2200AP King Pro 2200VA 1320...
Hi! Per our UPS problem is when open 3 or 4 hours, then auto Off the UPS. please let me know what the problem. And i need to change the PCB board or just repair the PCB board? Thanks Regards
If you unplug the unit and it powers your PC for 3 or 4 hours then turns off, it is because the batteries are empty and this is normal. If it is plugged-in with power and shuts itself off after a few hours, then the battery cells may be in need of replacing. You can purcase an inexpensive replacement battery here: http://www.upsforless.com/browseproducts/Powercom-Replacement-Battery-Kit-BNT-500A-BNT-500AP-BNT-600AP-BNT-800AP-KIN-425CSU-KIN-625CS.HTML
Dec 01, 2010 | Powercom BNT-600AP (bnt600ap) UPS System
Battries are discharged and now charger does not operate
The batteries will discharge below the reference voltage required for the charger to "see" the batteries if left uncharged for more than a month or more. You have to carefully bring the batteries back up to about 12 volts each for the charger to see them. The easiest way is take them to a qualified battery shop that has a step charger for sealed batteries. If you attempt to use a car charger on sealed batteries, you will ruin the batteries or even blow them up as the cases are sealed and the gas from charging has no way to escape. Some people have used a standard car battery charger on low only, applying a charge to one battery for about 15 minutes, then the other for 15, etc. until the batteries are back up to 12 volts, but again, using a car charger is dangerous and could cause the battery to explode.
May 20, 2010 | Jet 3 Ultra Power Chair
My kin-1200 ap doesn't charge the battery properly.
The reason for this is that the UPS, is unable to efficiently charge those BIG batteries, you see they generally only charge at a low rate, anyway, of say 10% - 15% capacity, of the-battery-usually-charged. Now with these BIG 40 Amperes by 2, well, there simply isn't enough "Juice" to charge them up... (Oh it might do in a month or so)... from that UPS's Charging Circuit. You will most likely have to rig up some other higher rate charger for those BIG batteries. OR modify the charging circuit IN the UPS. They need to be charged at about 1 Amp or maybe more. See it is simply Charge over Time... 40 amps at 1 Amp will take 40 hours.. 40A at 2A = 20H & so on. If only 1/2 flat 2A over 10hours.
Feb 07, 2010 | Powercom King Pro UPS System
When i connect 4 batteries in series for a total of 55 Volt, the ups tells me there is a problem with my battery. is the ups overcharging my battery or are the batteries overcharged. i bought them with...
I think UPS' are supposed to run on 12 volt batteries. You must connect them in parallel and not ie series as you are doing now. Connect all the Positives together and all the negatives together to give 12 volts and four times the amperage of each battery for longer backup. With series connection you may burn the system. Please check the manual that came with the UPS.
Nov 17, 2009 | Powercom King Pro 3000VA...
Powercom King Pro 1200VA (powkingpro1200va) UPS System Logo
166 people viewed this question
Top Powercom Computers & Internet Experts
vimal
vimal
Shekar Avadhani
Are you a Powercom Computer and Internet Expert? Answer questions, earn points and help others
