Question about Epson Stylus C86 InkJet Printer
Trouble in changing the ink cartridge - Epson Stylus C86 InkJet Printer
    Guru:
  • 302 Answers
Use the cartridge change option in the maintenance screen of your printer properties window.
Posted on Feb 07, 2010
Having trouble fitting new ink cartridge
Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
Instructions
Things You'll Need:
* HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
Close the print-carriage door.
You can also use this video clip to learn more:
youtube.com/watch?v=wVXUndG-o_Q.
Please don't forget to rate me thanks.
Thanks for using fixya...
Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
I cant change ink cartridge in my workforce500. the cartridge wont center itself so that i can open it and replace the ink
Epson has a Trouble Shooting Guide. Make sure that the 500 model number is showing on the top left. Select installing cartridges. Select Holder won't go to position. Then follow the rest of the instructions.
Here is the USER'S GUIDE, with instruction for changing the cartridges.
Hope this gets your printer working.
Good Luck
Feb 19, 2010 | Epson WorkForce 600 All-In-One InkJet...
Ink System Failure on a HP Photosmart C6280 All-in One
This is likely a cartridge problem except if the carriage is not moving at all. If you still have some of the used cartridges you can used them to trouble shoot by elimination ok. Or contact a nearby technician who has the cartriges to use them for trouble shooting. I strongly believe the one of the print carts is the culprit. Good luck
Jun 02, 2009 | HP Photosmart C6280 Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
HOW DO I CHANGE THE INK CARTRIDGE IN THE EPSON CX9400
CX9400Fax, All in one?  If so; download the manual and/or Q& A and /or trouble shooting guide for instructions:
Link
Feb 07, 2009 | Epson Stylus CX9400 Photo Printer
Pixma MP830 is printing things green that should be red
when you change all new cartridges (make sure all cartridge ok, and the cartridge pins connection ok) still red color lost, it is the trouble at print head ink chanel some of that is too dry for longer time less using , most CANON printer head is separated from the ink cartridge, two way you may try:
1) take out the ink cartridge, drop down a little the special cleaner (best clean tools buy from dealer), to the head ink chanel hole, then set back the ink cartridge and waiting minutes
2) try put the print head bottom surface touch a little cleaner or water 1-2 hrs, if you can take out the print head unit. still not fixed for some case that should change the print head unit.
Feb 06, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Ink cartridge
I will refer you to this Fixya link that I just posted a solution to.
http://www.fixya.com/support/t1217399-location
Oct 22, 2008 | Lexmark X2350 All-In-One InkJet Printer
I have changed all of my ink cartridges;but the black mode will not print,the color is working fine.
After replacement of each ink cartridge the machine will display "Did you change?" for each colour. If one or more do not come up with this message you may have a problem.
Check each cartridge for the black flag is moving up and down with the liquid in the ink cartridge. If it stuck firmly tap it on a table until it is freed.
Another problem if the black sensors in the ink supply unit are pushed back it may not read the cartridges. If visably they look pushed back (usually only two) I can let you know how to correct.
Finally the mainboard in the machine can fail causing some inks not to read but you can not resolve this yourself.
Jan 23, 2008 | Brother IntelliFAX 1840C Plain Paper...
Changing black & colour ink cartridge
My guess is that it will be the non gen carts they cause heaps of trouble, beleive me. Hard to tell you for sure but the first thing I would do if you brought it in for repair would be to put in manufactures cartridges.
Dec 01, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus C86 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
