Question about Canon EOS 400D / Rebel XTi Digital Camera
I got error cf after shooting about 20+ pics on a new card. I formatted the card & it works again (i didn't format it to start with). Is it my fault for not formatting the card to begin with? Or would you return the card? I'm worried about losing more pictures. Should I be? Thanks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 164 Answers
Always be sure to format your card in the camera, and not in your computer. That ought to take care of it!
Posted on Mar 13, 2010
What happens if I didn't format my sdhc memory card and just started taking pics with it?
Exactly what happened to you. You start getting card errors and can't read/write the card.
Jun 29, 2012 | Lexar Kodak SDHC 8 GB Class 4 Flash Memory...
I was shooting yesterday with Canon 50D & a lens 18-55 & the camera started to give me error code 20; telling me switch OFF & ON or re-install your battery. i removed the battery & put it...
Error 20 didn't show up on a 50D error code search, however I've run into this before when the processing operation couldn't be completed meaning the memory card was corrupt.
The Canon 50D makes massively large files and several things can run you into problems the first I doubt but need to list and that is you are using a card with a slow write speed. Another is that you have been using that trash can icon and not formatting your memory card. The trash can deletes files yes but it leaves what I cal a residue (small amount of data) do this enough and your card fills with useless data. Still looking at the memory card, you possibly downloaded pictures to the computer and formatted the card in the computer, not a good thing to do. Error 20 is also a windows error code for corrupt files which will play havoc with your camera firmware.
Another possibility is you downloaded picture files to your computer and forgot to do a safe disconnect, eject or safely remove device what ever your camera computer uses for shut the device off before disconnecting.
After downloading your just placed the memory card back into the camera and maybe started shooting again with a "dirty" card. The correct practice is to format your memory card every time you have had it connected to the computer. Format not delete, format the memory card in the camera it is to be used in.
Clean up the card and your problem will go away. Error 20 is a processing problem, corrupt file(s) or a camera firmware problem. If the problem continues do a firmware update to your camera through the canon site it's free
Jan 20, 2011 | Cameras
When I insert the CF card, and then turn the camera on, I get a reading that the card needs to be formatted. I then try to format the card, and it says that the card cannot be formated. I looked inside,...
If trying another card doesn't work then reformat your CF card in your computer choosing a Quick Format option. Then place it in the camera, do an immediate card format in the camera. If you've got images on the card now DO NOT SHOOT ANYTHING on the card before running an image recovery program like Sandisk RescuePro. As long as you don't shoot anything new on the card RescurPro should recovery all the existing images.
Dec 25, 2010 | Canon EOS-5D Digital Camera
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
Im getting an Error 99 on my EOS-300D Digital Camera when I turn off my YN 465 Speedlite flash gun (still mounted) and then I start shooting manually without the flash. Help please, its a bit annoying, but...
To fix this err99 issue, do the following
1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera.
If it appears again, then proceed to next steps 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera.
If you still get the error you should send your product to canon for servicing.
Apr 15, 2010 | Canon Digital Rebel / EOS-300D Digital...
THE CAMERA DOESN'T READ THE CF CARD. i BOUGHT A NEW ONE BUT THE DISPLAY STILL SAYS CF CARD ERROR (OR SOMETHING SIMILAR)
Hi there follow the steps below.
1. Remove the card from the camera.
2. Make sure the card is unlocked. That lock key
present in side of the memory card.
3. fix it back in camera.
4. format the card from the camera. You can get the
option for format from camera settings pressing
after menu key.
5. After finish the format, restart the camera.
6. Now you can see that message has gone & its
start working. If you face the same problem then
the memory card is damaged or the camera card
reader is damaged. I hope you will not faced those
problems. Please let me know the result. If you
want to know more then ask me again .Thanks.
Apr 07, 2010 | Canon PowerShot A40 Digital Camera
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Nope, this is not card anymore.
As you know CF is card failure, sometimes this cause to start error 99 , that is lens error , even if there is no problem with the lens.
This happens because the built in software in the camera can get messed up after an error CF.
You fix the problem calling Canon, they will guide through upgrading the firmware in your camera.
First ensure that you are using the camera menu and command to format the new card, and that new cards are properly inserted into the machine.
Call Canon support to get a firmware upgrade.
Feb 13, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
When the CF card is inserted it says ERR CF There is a problem with the CF Card Replace the CF Card. However when I take the card to get pictures printed it seems to work......is it the card or the...
if card is clean with no pics on it format memory card in camera and see if message goes away-if not i would assume camera-remember format delets all pics!
Jul 20, 2008 | Canon Cameras
"card error"
Have you tried formatting these cards in your camera? You will find the setting in the menu as per page 26 of the manual. Also check that the correct card type is set for xD or CF as appropriate. You can download the manual from the link below: http://www.olympusamerica.com/files/EVOLT%20E-500%20Advanced%20Manual.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Olympus EVOLT E-500 Digital Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
