Hi, is leethedeuce out there. I got your response. I did connect the ps3 to the input on the receiver and the receiver to the tv. all the speakers are working (and the sub woofer) with the tuner fm stereo on the receiver. I can see the movie playing from the ps3 but have no sound. what so i do now??/?
  • angelaethan0 Feb 07, 2010
    michael34, got your response. thank you. I cant find xmb in the system settings on the ps3.
Go under system settings on the XMB, there is a toggle in there to turn HDMI sound on/off
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=853386
Posted on Feb 07, 2010
I want to connect a ps3 to my new pioneer receiver
Make sure that whatever input you are using is set for hdmi audio. You may have mistakenly changed the input mode.
Jan 10, 2014 | Pioneer Audio Players & Recorders
NO OPTICAL SOUND I connected HDMI from reciever to TV, HDMI from PS3 to TV, Optical from PS3 to Receiver (PS3 Sound settings switched to Optical, with Dolby Digital 5.1CH, and Dolby DTS 5.1 selected) ...
I think your problem might be at the digital audio setup at the receiver. To fix this, go into the setup under digital audio and make sure that the input that your connected to is set to optical, not analog or coaxial. Example if your plugged into video 1, make sure that the audio setting corresponds to the optical input where your connected. Video 1-optical-1.
Good Luck
Jan 07, 2011 | Samsung HTC5500 Theater System
I have no sound coming out of my speakers when I connect the receiver to my tv and ps3.
There's really not enough info here to answer your question. What outputs are you connecting to what inputs on your receiver? 1. Does the receiver produce sound from other inputs? If yes, then receiver to speaker is OK. 2. Do you have sound at a headphone jack but not speakers? This would indicate bad speaker wiring or blown output fuses.
A bit more info will help - maybe gathering it will lead you to where the connection is not correct.
Oct 22, 2010 | Sony STR-DH100 Receiver
Hi i can't get any sound thru my speakers. I have hdmi from ps3 to tv optical from ps3 to receiver. i have tried dvd video 1 video 2 what setting am i missing? thanks
first: make sure you have the audio output setting on the ps3 set to digital optical output
second: make sure you select whatever the optical input is assigned as, probably dvd. i think there is a button on the front of the receiver that says digital input, make sure you hit that. A little light on the front screen of the receiver will say digital.
May 09, 2010 | Onkyo TX-SR503 Receiver
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I can only get 2.1 sound from my Playstation3
optical cable connection in tv is only input and same in receiver it is both inputs.you need to find the right encoding in your receiver mode/set-up
Apr 21, 2009 | Sony DAV-HDX500 System
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
Jan 04, 2009 | Samsung HTP-1200 System
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Dec 12, 2008 | Denon AVR-2800 Receiver
Connecting to surround sound system
Hi to connect your ps3 to your tv all you would need is a hdmi to hdmi connector which would mean the sound would come straight out of your tv. The sound comes directly out of the hdmi cable. If you want to connect the ps3 to an external reciver you might want to get an AV reciver with HDMI inputs. This would connect to your tv and you can switch channels to different sources connected into the receiver, also they come with very good seperate speakers so you wouldnt have to use you telly speakers and you can connect your directv box into it aswell.
Alternatively you can connect the audio phono outputs from your AV multiout connector on your ps3 (the cable should be provided) to a seperate sound system with phono AUX inputs, these are found on most soundsystems but check with whoever your buying it from. But this means that you cant use the HDMI output of your PS3 for video just the AV multiout video signal (which is a bit rubbish, so I suggest the latter solution.
Hope this solves your problem
Rob
Nov 26, 2008 | Audio Players & Recorders
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
CABLE GUY.
Jun 24, 2008 | Onkyo HT-SR800 System
18 people viewed this question
 Grubhead
Grubhead
