Question about Beond Latte Communications iVu MP3 Player
The camera doesn't work! at all!
The camera doesn't work! I bought it, when it was fully charged (the first time that a charged) I try to enter to the camera and didn't work :( in the present the problem stills.
    Sniper:
  • 62 Answers
Try removing and reinstalling the battery. If that doesn't work, then try recharging the camera again. If still not working, return the camera for a replacement.
Posted on Feb 07, 2010
Iloilo city
try a different battery or use an external charger.... the battery could be faulty, or the camera charge function could be faulty.... a different battery will help you decide where the problem is.
Apr 05, 2014 | Nikon Cameras
My Kodak Easyshare M575 digital camera will not turn on. It turns on okay without the battery while plugged to an electrical outlet. I've tried charging the battery and that doesn't work. The...
If unused for any length of time, rechargeable batteries lose their ability to retain a charge. Try it with a brand new, fully-charged battery. FWIW, I recharge all my camera and flashgun batteries monthly.
Nov 07, 2017 | Kodak EasyShare M575 Digital Camera
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
Camera switches on for a second and then swtches off btterey is fully charged
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
When trying to charge battery green light flickers for hours
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EasyShare V1073 Digital Camera
My kodak easyshare V1003 camera will not turn on. It worked a few days ago and now it will not charge or turn on. I just bought new batteries and it still will not turn on. Any suggestions on how to fix...
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 09, 2009 | Kodak EasyShare V1003 Digital Camera
No lcd display on GE Intellicorder
For a blank LCD screen, the troubleshooting section of the manual says you need 3 new or fully charged alkaline batteries AND you need to firmly connect all cables.
What you have described certainly sounds like a power issue. Any chance the batteries are installed backward? Have you tried 3 brand new alkaline batteries?
This is from the manual page 17 found here:
http://fujidensha.com/Manual_sanple/0806_SCAM/0806e.pdf
Dec 26, 2008 | Jasco Ge Intellicorder
It wont work!
if it said fully charge its probably not yet.
could it be that you damage your camera in the first time that it was jammed?
Jun 22, 2008 | Fuji FinePix Z100fd Digital Camera
Beond Latte Communications iVu  MP3 Player Logo
54 people viewed this question
Top Beond Audio Players & Recorders Experts
William Miller
William Miller
Joseph Hoffmann
Are you a Beond Audio Player and Recorder Expert? Answer questions, earn points and help others
