Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Started good last night after sitting for a year, now I tried to start it and it is getting alot of gas coming out of the carberators and extreme backfire. Whats the problem?
    Problem Solver:
  • 6 Answers
Your carbs are out of tune
Posted on Feb 11, 2010
My starter is very hot is that normal?
Sounds like starter problems, maybe shorted out. Starters will get hot if operated a lot, but shouldn't get extremely hot. Manufacturers say this: do not operate starter for longer than about 15-20 seconds at a time, then let it cool off for about a minute before trying again. Otherwise starter will get too hot and burn out.
Take your starter off and have it tested-it is probably failed.
Is the distributor cap on securely now?
Jul 26, 2013 | Cars & Trucks
I bought a new apple airport extreme base station. I plugged it to my modem. A yellow light indicate that every thing is correct. An orange light flashes on the AirPort Extreme. When I go to the wifi list...
i have a 06 ford f350 dually 6.0 diesel i have problem sometimes it will start ok sometime it will not so had to put a rag in the air filter with gas on the rug to starts it but it does alot of hesitating when you're driving it. it just started doing hesitating now its doing this idoling up and down and when you crack it over alot the check engine light come on when it running but eventually it tunes off i was thinking about changing the fuel filters again to see if thats the problem because i think it started when i change the fuel filter i need a little help
Feb 11, 2013 | Computers & Internet
I have a 2006 Nissan Xterra that is a standard transmission. Recently, a screw fell out of the clutch (common problem apparently with this model). Last night, I was leaving the grocery store and was...
thats one hell of a common problem for parts to be coming out of the clutch, if the problems did not start before the clutch lost a screw or bolt i would have to say that the missing clutch is most of your problem. if the clutch slips you will have a lack of power you tell this buy starting off in 1st gear give it some gas to get it going then give it alot of gas if the motor revs up and the car does not gain speed as fast then your clutch has issues.
May 01, 2011 | Nissan Xterra Cars & Trucks
Ive been trying to start my buick century, it cranks strong, but it seems like its not getting gas, its been sitting for about 3 years.. i nee help as quick as possible... help please thanks!
I would say your gas is bad. Three years is way to long for sitting gas. You will need to drain the tank. Spray some gas into the carberator. Start it and see if it catches for a second. If so, then that confirms a fuel problem. The gas is not good my friend. Sorry.
Feb 10, 2011 | 1994 Buick Century
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
Starts and runs like **** then dies
filter maybe very dirty, you may need a new spark plug, you're carberator may have just a spec of debris in it , all things that happened to us also, this man is a wizard with small engines..www.belgiumsmallengine.com
Apr 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hello sir, I have olympus C-70 model which is working very good for last 5 years. I am on vaction to france and it worked well till last 2 days. I have switched it off 2days back and switched on last night...
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Aug 23, 2009 | Olympus Cameras
2005 chevy cobalt check engine light
make sure the gas cap is on tight. vapor recovery system depends on the closure of the gas cap. if that did not solve your problem, I would suggest to get a new gas cap first, before going to the dealer or any repair shop for a turn-up.
May 28, 2009 | 2005 Chevrolet Cobalt
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
130 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
