Question about Irons
How safe our the irons with separate pressure vapour container???
  • Irons Master
  • 6,993 Answers
its about 95% safe.
Take care
Posted on Mar 08, 2010
I HAVE AN OLD BLACK AND DECKER 300 QUICK AND EASY IRON. DOES IT CONTAIN MERCURY?
I just looked up the manual. Unfortunately the best way to find out is to contact B&D.
This is from a recycling website.
Purpose of the Mercury: The reason that mercury tilt switches were widely used in irons and other appliances was because of the conductive and liquid-like properties of mercury. In a mercury tilt switch, as the switch is "tilted" the mercury flows with the switch to complete the circuit by conducting electricity and turning the appliance on or off. In irons the mercury switch controls an electronic shut-off timer, constantly resetting the timer when the iron is in motion. If a person leaves the iron turned on and motionless, the automatic shut-off timer turns the iron off after a certain amount of time, reducing the risk of a fire. If an iron falls, this feature will also prevent it from continuing to release heat potentially causing a burn or fire.
Potential Hazards: As long as the iron remains intact, there is a low probability that there would be a mercury release.
Recycling/Disposal: There is no easy way to identify whether or not an iron contains a mercury tilt switch. However, if the iron is more than 10 years old and it contains an automatic shut-off, consumers should assume that it contains a mercury switch and dispose of it properly.
Unfortunately, they keep referring to 10 years old, but it doesn't say when this information was written up. If it was written in say 2006, then it would be referring to 20 year old irons.
Jul 28, 2016 | Irons
My Black & Decker D2030 Iron fell on the floor and it is leaking water from the tank - can it be repaired?
if the crack is visible and isn't on a part that gets heated then super glue will work 4 you , plus if you cant access the crack a separate 99 cent squirt bottle kept handy will still allow you to use the iron ,just squirt and swipe the iron across the surface ,steam will be made if irons hot enough
Jun 03, 2016 | Irons
D2030 Iron: Iron keeps shutting off...like auto-shut off is al...
OK... quick disclaimer. Me = not responsible if you break your iron, set something on fire or electrocute yourself. If you're not sure what you're doing, find a qualified person to help or trash the iron. Getting hurt isn't worh a $40 iron.
That said, mine had the same issue... in my case, was a break in the cord.
Before you do anything that follows, don't forget to drain the iron. You'll have a big mess if you don't. :)
Accessing the cord connections requires a security screwdriver. You can buy one at a hardware or electronics repair store. OR if you're chep like me, make one yourself by using a Dremel with a cutoff wheel to cut a notch in a thinner blade, flat blade screwdriver. Any cheap flatblade screwdriver will do (eye protection recommended since you'll be grinding metal).
Unscrew the two screws in the back. Once removed, the colored plastic cover can be removed by inserting a screwdriver near the tabs that hold the cover in place and prying a bit.
Removing the inner cover is a little trickier.
The handle under the power indicator light (the red one) has an upper and lower section. Squeeze the lower portion of the handle directly beneath the light pretty firmly. You'll notice a slight separation between the back section and the handle. The back section is what you'll remove. I removed mine by squeezing the handle and pulling the power cord straight backward (I know that sounds odd, but it was the easiest way to get some leverage, plus it's already broken, remember???) Don't pull super hard, but firmly enough to separate the back panel from the back of the iron.
Once the back cover is removed, it's a pretty simple cord change. As there are a few more wires than some people are accustomed to, I recommend writing down the wire combos so you can reattach everything as it was.
If you have difficulty removing the crimped wire nuts (the plastic covers), you can use a pair of pliers to squeeze opposite the crimp and they'll open up enough to allow the wires to slide out.
From there, reassemble... opposite of the disassembly order.
Mine worked perfectly after this quick fix. Hope yours does too. Good luck and be safe!
May 18, 2010 | Black & Decker D2030 Iron
Iron puts out water which stains clothes. Steam is not dependable
Replace your iron. You can try cleaning the old one with either white or the stronger pickling vinegar, but for all the trouble that will be it is easier to just replace your iron. If future use ONLY distilled water, bought at any supermarket or water store, in your new iron.
Mar 27, 2009 | Rowenta Irons
Holes clogged with plastic
I would put the un-plugged iron in to the freezer so as to get the plastic as rigid as possible and then try to extract all of the plastic from the steam holes.
As far as cleaning the irons surface.
Step1 Place about a teaspoon of salt on a paper or cotton towel and run the iron over it on the high setting gently with the steam off. This will cause the dirt to stick to the salt and will wipe away easily. Step2 Rub the iron across newspapers to remove a waxy build up on the surface. Use the high setting with the steam off. Step3 Apply ammonia to a rag and use it to wipe the surface of the iron to remove oil. Use a separate cloth that is wet with water to rinse it off. Make sure the iron is turned off. Step4 Combine equal parts vinegar and baking soda and scrub the surface of the iron with it. Use a separate clean cloth to wipe away any residue. Step5 Heat in a saucepan a cup of vinegar and sprinkle in about a teaspoon of salt. Heat the mixture until the salt is dissolved. Use this to clean the iron's surface with a clean cloth. Use a second cloth to wipe away any residue.
Good luck
Aduz
Mar 22, 2009 | Tefal Ultraglide 1549 Iron
Instructions for use DiLonghi StiroMeglio compact iron (steam boiler Iron)
Is a long story but i make short.Don`t be afraid to leave your iron on.Is common to water tank iron to get working in more then 5-10 minutes.That machine are really safe since they do have more then 1 thermostat to control the water pressure.
How they work is pretty easy.The boil the water to a certan temperature and you know after certan F. the water become steam generatin pressure and steam.The thermostat control the heater and the electroswitch release the steam
If your in not making any steam after 5-10 minutes make sure you hear the electroswitch working.Sometimes they get cloght and even if the boil is under the pressure you can not get any steam at all
Good Luck
Jun 10, 2008 | Irons
Sunbeam 4214 Clothes Iron with Retractable Cord won't heat.
first, i'll apologize for not posting pictures with this, but i didn't have a camera handy when i "fixed" it. i'll do my best to explain the sitch.
i also have a sunbeam 4124 whose retractor was jammed...the cord would not release more than two feet or so, nor would it retract. i was able to disassemble it, but broke some internal retaining clips meant to hold the retractor housing to the iron. WARNING!! do not attempt this if you do not want to void your warranty. i can only assume that the manufacturer did not want you to disassemble the cord return housing and as such, hid the retaining clips where it would be impossible to disengage them. i got lucky and only broke one set of the retaining clips....if you carry on, you stand a chance of breaking both sets, which will not allow you to reattach the retractor housing to your iron securely. best thing to do is call sunbeam and have them send you a new iron, but if you're bent on fixing it yourself, here's how i did it (you'll need one medium philips head screwdriver):
1) remove the rubber feet from the bottom of the iron. this will expose two screw holes (the third foot under the retractor button has no screw; this is the side where the reaining clips are buried).
2) remove the two screws
3) WARNING! this is where you have a good chance of breaking your iron. pull the base of the iron really hard, rocking it from side to side. there are two sets of retaining clips recessed in the housing of the iron. the button will come with the base of the iron, the entire cord retraction assembly is self-contained. you can carefully use a screwdriver to pry the two halves apart. also, be careful not to pull too hard as the electrical connections between the iron and the retractor assembly has only about 2 inches of slack, though the connections are just wire-nut'd together and could be reassembled in a pinch.
4) after the retractor housing is separated from the iron, remove the housing cap by unscrewing the four screws.
5) carefully separate the two halves of the housing; the spring may be loose inside and could snap out at you.
here's where my iron was broken....the coil spring is contained by a plastic tray that had snapped, probably due to somebody pulling the cord out too hard. a section of the tray had jammed itself into the inside of the housing, immobilizing the winding mechanism. my only recourse was to completely remove the spring and permanently extend the cord all the way (not one of the features i bought the iron for anyway, so what the heck). PLEASE be careful unwinding the spring if you have to do it....wouldn't want anybody poking out an eye inadvertantly.
6) reassemble the retractor housing by screwing the cap back on with the four screws
7) if you're lucky enough to keep one set of retainer clips, snap the base of the iron back on and reattach the two screws located under the feet.
8) rubber pads back in and voila!
hope this helps!
Mar 17, 2008 | Sunbeam 4214 Iron
Iron
thats probably from the minerals in the iron?
try using distilled water with a low content in minerals.
or try to make sure there is no water left (use the vapour function) before you store it for next time.
Thats my 2 cents. Hope it helps!
R.
Jan 01, 2008 | Tefal UltraGlide plus 1656 Iron
Retractable cord
hope this helps!
Jun 12, 2007 | Sunbeam 4214 Iron
Irons Logo
15 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
