Toshiba Satellite M35X-S161 - No Video
I took my laptop apart to clean the fan, and when I put it back together I had no video display. If I connect an external monitor to the laptop, I can see what I don't on the laptop monitor. I tried to use the steps in resolving the Toshiba Black Screen problem (http://www.fixya.com/support/t225857-toshiba_satellite_a135_s2376_black), but Toshiba insists I use the Toshiba Power Management Software, therefore I couldn't follow the steps completely. I have purchased and installed a new video cable (still no change), and tested a new invertor board (plugged cables into it with no success). The monitor does appear to illuminate and the brightness does seem to increase and decrease. Is it possible the monitor went bad when I took the laptop apart?
  • 2 more comments
  • schnabs Feb 22, 2008
    Saigua, I'll check out the Function-Key combo and wires supplying power and video signal to the monitor next. Since I've used the Function Keys to switch the video from laptop to external monitor, I do see a change while using the combo. I'll verify that's still the case and report back. As for the utility program and BIOS setting, I'll check into that as well. Do you think the BIOS settings could be restricting the video from displaying, or is that something I should start adjusting once I get my display back?
    Oh, and I was originally going to just shoot compressed air into the fan, but was out. I was too impatient to wait until the next day, and took it apart. I know, bad idea.
    While trying the steps mentioned in (http://www.fixya.com/support/t225857-tos...), I used an external monitor using the function-key combo and couldn't really get those steps to work for me. I continued to explore new solutions, and thought that maybe the monitor display settings needed fixing in the Display Properties menu. I tweaked the resolution and display for a monitor 2 and hit ok instead of apply. It immediately told me about my mistake by telling me the resolution was at an invalid range. So, I now don't even have video through my external (funtion key combo) display. Do you know how I can restore/reset my display settings back to normal without being able to use my laptop monitor or external display, to see what I'm doing?
    Thanks a bunch.
  • wantedpsycho Nov 16, 2008
    i have the almost exact same problem except my video just went out outa no where when i was on my laptop, but the black light still worked, i took it to a friend he had it cleaned and outa no where the picture was back, worked fine for a bit then again outa no where the picture went away but back light still works, i took it apparent took a look a the wiring and still no video but back light is ok. i did hook up a desktop monitor and that works just fine with it. i suspect it is the cord, but i could be wrong.
  • Steve Nordquist
    Steve Nordquist May 11, 2010
    Of course it's possible you disconnected or destroyed your LCD! But that would suck (given that you can't just buy a 24" plasma screen replacement for the LCD, for $200, until 2013....)
    What happens when you use that function-key combination used for switching display modes between built-in and external monitors? If it's nothing, then take it apart and make sure those wires supplying power and signals to the LCD are not shorted (as they would be if you laid the exposed parts across each other instead of sticking up...) or cut (e.g. not the same RMS voltage with a 400-ohm probe at each end.) Some serial line responsible for the sleep state of that thing is probably buggered, and you'll have to mend or replace that.
    As for cleaning the fan; I wonder why compressed air did not do the job, as usual....
  • Anonymous Mar 18, 2014
    Replaced Toshiba L770 screen and it does not display, black screen, need help with connections, preferably an image or step-by-step
  • 981 Answers
There are generic (well, platform-agnostic) and free utility programs e.g. indexed on VersionTracker, used for fan control (FanGUI, smartFan, etc.) and power management which should work without interfering terribly with that Toshiba utility. Even so, it's possible you'll need to take out a misbehaving power-saving daemon (using Task Manager or whatever.) That suggestion to fiddle with the sleep levels is reasonable; another component you might update or refresh to work in concert with those tools is the system BIOS, which sets the addresses for all those sensors where Toshiba's tools can get at 'em.
Posted on Feb 22, 2008
  • Steve Nordquist
    Steve Nordquist Feb 22, 2008
    Okay should have done the same thing as Apply! (And; perhaps an old CRT type with wide scan range is handy in your neighborhood, to get a display back.)
    Well, perhaps it boots by default to a usable VGA resolution shown on the external monitor? In that case you can use safe mode or flash the BIOS and be okay; else, you can flash it blind or toy with the BIOS by booting with no videocard, powering off, reinserting it, and seeing if a better default comes up. (Yuck, more disassembly! Maybe you'll find the Marshmallow Peep you put in for Luck, though....)
More Specific Toshiba Satellite M35X-S349 assembly
The long thin wires are the aerial wires that connect to the wireless card. they are normally a black and a white wire and they have a connector that attaches to the wireless card.
Nov 06, 2012 | Toshiba Satellite M35X-S349 Notebook
Video Controller Satellite M35X-S161
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Video drivers.You can also try Driver Guide at:http://www.driverguide.com
May 06, 2012 | Toshiba Satellite M35X-S161 Notebook
CAN WE USE TOSHIBA SATELLITE M35X-S161 AFTER REMOVAL OF ITS TFT ( DISPLAY ) IF YES HOW TO REMOVE TFT ( DISPLAY ) KINDLY ANSWER ?
You don't need to remove the LCD display even if it is not working, provided the video card is OK to use the Toshiba without its display.
Just connect a monitor to the video port on the Toshiba, then power up the monitot then boot up the Toshiba. The video data should automatically switch to the external monitor.
Nov 04, 2010 | Toshiba Computers & Internet
My old laptop toshiba m35x-s161 won't turn on the light on the power botton turns on and it makes some noise but nothing more happens
Sounds like there is a faulty connection between the power switch and the computer. Probably why its making a little noise.
Take in for repair and replace power button.
Jul 24, 2010 | Toshiba Satellite M35X-S161 Notebook
Screen Issue
I would check to see if the RAM has become loose, if you can reseat the RAM. Do you hear any beeps when nothing is displayed?
Aug 18, 2009 | Toshiba Satellite M35X-S161 Notebook
I have a Toshiba Satellite M35X-S161 that will not stay turned on for longer than 15 minutes.
Check power management - clean dust from fan - full system virus/spyware/registry scan. Place external fan to help internal fan.
Apr 04, 2009 | Toshiba Satellite M35X-S161 Notebook
Toshiba M35X-S161 motherboard replacement issues
How to remove back cove rof my Toshiba M35X-S161 to get the charging input jack to repair it?
Mar 28, 2009 | Toshiba Satellite M35X-S161 Notebook
CAN'T PUT BACK HARD DRIVE (TOSHIBA M35X-S161) LAPTOP COMPUTER
Is this a IDE or SATA drive?
Is the drive (or connector) possibly upside down?
Dec 08, 2008 | Toshiba Satellite M35X-S161 Notebook
Computers & Internet Logo
1,344 people viewed this question
Alun Cox
David Payne
David Payne
